Old Apr 20, 2012, 10:34 PM
lktroiani is offline
Find More Posts by lktroiani
"Get 'er Up"
lktroiani's Avatar
Wichita, KS
Joined Nov 2008
Video
Spoiler servo install for Houston Hawk
Video & photos of Hitec HS-55 servo installation for spoilers in Houston Hawk wing. Carbon matte was applied to underside of spoiler stock for increased rigiditiy and warp resistance:
lktroiani is offline Find More Posts by lktroiani
Old Apr 21, 2012, 03:16 PM
WesternFlyer is offline
Find More Posts by WesternFlyer
WesternFlyer's Avatar
United States, AZ, Chandler
Joined Mar 2007
Sweet setup.
WesternFlyer is offline Find More Posts by WesternFlyer
Old Apr 22, 2012, 09:19 AM
isoar99 is offline
Find More Posts by isoar99
Joined May 2006
I am going to use this on my next bird. Nice simple install.
isoar99 is offline Find More Posts by isoar99
Old Apr 25, 2012, 08:00 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I am at a point in my build of a different plane that I need to consider mounting the servo and stuff. Looking at your video it looks like you installed the servo in a way where once the plane is finish there is no way of replacing the servo if need be.
Is this how you do it normaly or because of the nature of this model.
freechip is offline Find More Posts by freechip
Old Apr 28, 2012, 08:19 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
If you mount the servo on a 1/16th thick piece of plywood that you screw onto the bottom of the wing, you can gain access to the servo by removing the plywood plate.
Alan
The pictures at http://www.rcgroups.com/forums/showp...&postcount=171 do not show the plate but do show another example of the same type of installation that uses magnets at the spointer's tips to keep them down flat
Al Offt is offline Find More Posts by Al Offt
Old Apr 29, 2012, 10:50 PM
"Get 'er Up"
lktroiani's Avatar
Wichita, KS
Joined Nov 2008
That's exactly how this spoiler servo is mounted, just glued to 1/16" ply mounting plate which is screwed flush to a custom made "frame" on the lower surface of the wing. Good access to the servo as you suggest.
Old May 01, 2012, 07:56 AM
"Get 'er Up"
lktroiani's Avatar
Wichita, KS
Joined Nov 2008
pics above
Old Jul 20, 2012, 09:01 PM
jdveirin is offline
Find More Posts by jdveirin
Zeus
Joined Jul 2006
I like that setup. I am building a Windlord flying wing (build log at www.rcgroups.com/forums/showthread.php?t=1680750). I am going to use your installation method for the spoilers. If the Hitec-55 is sufficient for Hobby Hawk spoiler, it should be enough torque for the Windlord spoilers.
The blue Hitec HS-55 looks cool. But, due to the brown laser cut edges in my partial kit, I am going with opaque covering. So, I may use Futaba S3114 servos since they are about the same weight with a higher torque rating, albeit $5 more per servo.
Futaba S3114 - .21 torque, .28 oz weight
Hitec HS-5 - .1527 torque, .27 oz weight
jdveirin is offline Find More Posts by jdveirin
Sold Houston Hawk NZ7C Aircraft - Sailplanes (FS/W) 2 Mar 10, 2012 05:21 PM
Discussion Bubble Dancer v Houston Hawk v Yardbird 2 Kookaburra Thermal 20 Nov 04, 2011 01:46 AM
Sold NIB Houston Hawk short kit and plans from Mountain Models NZ7C Aircraft - Sailplanes (FS/W) 3 Oct 28, 2011 08:45 PM
How to instal a single servo for both ailerons on a GWS Mustang? JustFly GWS (Grand Wing Servo) 2 Jul 20, 2005 03:09 AM
Rave I need a link to a site showing spoiler instal. sa-woody Sailplane Talk 2 Jun 03, 2005 03:23 PM
