Old Apr 20, 2012, 08:53 PM
kenzietech is offline
Find More Posts by kenzietech
Joined Sep 2011
Question
Do all RC planes have power switches? Or can I do without?
Sorry for another admittedly newbish question. (I AM learning, I promise!)
I was wondering if all planes have power switches on them to turn them on / off, even with the battery connected, or if some simply turn on when the battery is connected to the plane. It seems like such a simple answer, and I am just confusing myself!
My Wild Hawk has a power switch to turn it on and off, and even includes a motor reset push button, that sometimes you need to press to enable the motor to spin. However, I've seen videos from FliteTest where it appears that a lot of their planes don't have power switches, and that it simply turns on the minute that the battery is connected to the system! Where I'm confused, is that I burned out the ESC on my plane awhile back when the battery became dislodged while the motor was running (in a crash), and it smoked the ESC. So to me, it seems that the power switch is crucial to the safety and longevity of the ESC. But yet on FliteTest, it appears that most of them don't have a power switch!
The problem I'm having right now is that the power switch on my plane is starting to flake out on me. I crashed it upon hand launching twice today, when right after tossing it the power switch failed, and everything stopped, and it nosed into the dirt. I messed with it for awhile, had it going, launched it again, and right after launching it, it crashed again. I know that it's the power switch, as I can push on it and get it to stop working with a light pressure in one direction.
So I am contemplating getting rid of the switch altogether, and simply soldering the two wires together, and using the connection of the battery to turn on the plane. However, I am afraid of smoking the ESC again by doing so, and then disengaging the battery without turning the plane off.
Can someone please clarify my confusion? Thanks!
kenzietech is offline Find More Posts by kenzietech
Old Apr 20, 2012, 09:09 PM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
most planes don't. It is not needed. On/off is plugging in the battery. extra weight not needed.
Lammergier is offline Find More Posts by Lammergier
Old Apr 20, 2012, 09:24 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Ditch the switch if it's being a... female canine...
The vast majority of models just rely on the battery being plugged in. Nothing else is really needed.
Piece is online now Find More Posts by Piece
Old Apr 20, 2012, 09:37 PM
Joined Sep 2011
So even something as cheap as the Wild Hawk ESC shouldn't need a switch? Maybe I just ended up smoking the ESC because I had the motor running when the battery ejected itself?
Old Apr 20, 2012, 09:52 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
I don't have switches in any of my power planes. Just another thing to go wrong in a hobby that Murphy loves in the first place.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Apr 20, 2012, 09:53 PM
Joined Sep 2011
Haha! Then maybe I'll chance it and solder those together and just use the battery to control the on/off.
Old Apr 21, 2012, 02:44 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Most models don't use a switch for the very reason that you've discovered -- a switch is simply something else that can go wrong, and there's not many switches that can reliably handle the kind of amps that we use.
The only time I would suggest using a switch is if the battery connection is difficult to get at without putting your hand in the way of the propellor. In that case, instead of a switch, most people use an arming plug mounted externally. It's simply a standard battery socket (Deans Ultra, Power Pole, or similar) wired into the positive supply to the ESC to make a break in the circuit, with a matching plug with it's two pins shorted out, which you plug into the socket when you're ready to go. It's light weight, and it can handle the amps. There's a good picture of one in post #2 here http://www.rcgroups.com/forums/showt...rming+plug+arm
abenn is online now Find More Posts by abenn
Discussion A non-aerodynamic proof that a lifting wing pushes down on the earth aeronaut999 Modeling Science 2033 Nov 09, 2014 03:40 PM
Help! NAZA question about switching from 3s to 4s, do I have to change in software first. jasper7821 Multirotor Talk 9 Mar 09, 2012 11:07 AM
Discussion I have RC Car stuff I want to get rid of, cash or trader for plane stuff alexcarden Trader Talk 4 Mar 03, 2012 09:15 AM
Kudos RCG, All I can say is keep doing what you are doing KCV6 Site Suggestions / Complaints 1 Feb 27, 2012 08:34 AM
Alert Is there an ait plane i can build out of foam that can do 3D without going brushless? lttakas Foamies (Kits) 13 Nov 24, 2003 10:13 PM
