Old Apr 20, 2012, 08:28 PM
easystarfpv4 is offline
Find More Posts by easystarfpv4
Joined Mar 2012
What motor is best to use for upgrading the Easystar?
I want more push for my EZ, the motor that came with it is not strong enough. Just wondering which motor along with the other components (esc, battery, ect.) would be best to use for upgrading my ez?
easystarfpv4 is offline Find More Posts by easystarfpv4
Reply With Quote  (Disabled)
Old Apr 20, 2012, 11:11 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
You want a 28 mm inrunner with a Kv rating of around 2200-2500, rated for 250-300 watts. Couple that with a 25-30 amp ESC, a 3S/2200 lipo battery, and an APC 6x4E propeller.
The 28 mm inrunner motor is a perfect physical replacement for the stock Permax motor, ie., it fits precisely in the motor mount cavity of an EasyStar. An inrunner is a very logical choice here because of the need for high Kv value (Kv = rpm per volt) which is in turn necessitated by the rather small prop that you're stuck with.
rafe_b is offline Find More Posts by rafe_b
Old Apr 21, 2012, 01:40 AM
hillbille is online now
Find More Posts by hillbille
AMA 884978/KK6NKY
hillbille's Avatar
United States, CA, Barstow
Joined May 2007
There are a myriad of options for the EZ-Star - IF - you are willing to do a little work and IF you keep an open mind and are willing to try "different" things.
You can "make" a mount by creating several "circles" (I think I drew around a quarter for mine) from almost any material - i.e. cardboard, foam, depron, plywood, balsa, etc., etc.. Then cut, drill or shape a square hole in the center to fit a simple 10mm X 10mm (3/8 X 3/8) motor stick. Push the circles into the EZ motor mounting hole at varying spaces and then insert a short motor mount stick to protrude out of the old mount by about 1" or so.
Use a plastic stick mount (the grey one supplied with TP motors is shown but any of the GWS mounts work too) and a small ply backing plate to afix the Bell motor of your choice to the mount. Simple three screw mount. Also you "can" (this is what I do) drill out the three mounting holes in the motors firewall mount plate to 3mm and then tap these to a 3mm thread. Use 3mm fine thread screws to mount the motor to the plate sandwiching the plastic motor mount in between the two. Works very well and is easy to change.
The "offset" of the plastic motor mount raises the motor about 1" above the old mount - and consequently allows a prop size much larger than before. This allows for a LOWER KV motor to be used which can be much more efficient and also will allow for a FOLDING prop to be mounted.
I simply velcroed my ESC to the fuse top instead of running the wiring through the fuse - better cooling anyway - but like I said you can put it into the place intended for it IN the fuse interior if you desire.
Photos below are (or should be! LOL!!) self explanitory.
Hillbille
hillbille is online now Find More Posts by hillbille
Discussion Best motor for fpv easystar 2 ? SkyShip FPV Talk 21 Sep 25, 2013 06:35 PM
Question Can I upgrade my Battery for my Multiplex Easystar? easystarfpv4 Electric Plane Talk 7 Apr 19, 2012 06:46 PM
Question What is the best landing gear for Multiplex Easystar? easystarfpv4 Electric Plane Talk 8 Apr 03, 2012 04:09 AM
Help! what motor for a FPV Easystar? lrplin Electric Plane Talk 24 Dec 13, 2011 11:34 PM
What would the best GWS style gearbox and ratio should I use for this bl motor? TeamTEOR GWS (Grand Wing Servo) 7 Jul 16, 2004 04:07 AM
