Joined Aug 2011
You are trying something I've thought about but haven't figured out a solution yet. I like my little depron wings and would love to fly them off the water. If you raise the thrust line over or near the CG, like on a wing, you create a huge pitch down rotational moment. To eliminate the rotation you angle the thrust vector down. As you angle down you reduce your forward thrust component and create a large down component. This down component conteracts lift. Think of it as flying a heavier plane with less thrust. A wing relies on reflex for level flight and generating the necessary reflex without a tail is almost impossible.
On the Polaris and Sea Dart the motor is located much farther behind the CG so you don't need as much down thrust vector to get everything balanced. On my Mallard Duck, when the head is up, I have a lot of up thrust vector to prevent down pitch. This is a motor above the wing but well in front of the CG. So on the Mallard I get the effect of added lift with a little reduced forward thrust. This might work on a wing but the overall handling qualities might be poor. I've been thinking of a configuration mechanism like on the Duck for a wing so that once your off the water, the motor is moved to centerline.
A couple of things. The myth that epp does not make good seaplanes, is just that , a myth. A flying boat is much moe aerodynamic than a pontoon plane. Here are a couple of EPP seaplanes of mine. Both made from 1.9 pound EPP. Some video of each.
Joined Nov 2007
Is this the motor you used? (The link in the video was no longer valid)
http://www.aero-model.com/Hacker-Brushless-A20-20L.aspx Anyone know of a less-expensive alternative that would work here? |
Pretty sure Don will have a Keda 20-20 that will work . Check out his site and send him an email http://www.strongrcmotors.com/Motors.htm
steve: back on your wing off water idea, there's a pretty fundamental issue beyond the thrust line, and that's in my experience for water maneuvering, one needs a rudder (either a water rudder or the plane's rudder) and your wing is an elevon setup isn't it? If so, then it'll go either straight (if there's no wind) or wherever the wind takes it.
Latest blog entry: OSE One Sheet Edge 540 Video
| Thread Tools | |
| Discussion seeking plans for simple woody runabout | JayJay76 | Dock Talk | 8 | Feb 03, 2012 07:22 AM |
| Discussion newbie seeks lobster boat plans | Grammie | Dock Talk | 7 | Oct 13, 2011 09:14 AM |
| Build Log Seeks depron trainer plan for my configuration | bilax | Electric Plane Talk | 4 | Oct 12, 2011 12:24 PM |
| Need Sea Gull plan or any other bird plan | absolute-zero | Slope | 2 | Nov 05, 2005 07:57 PM |
| seek for EDF 50 jet plan | pkpichit | Electric Ducted Fan Jet Talk | 2 | Jan 21, 2003 01:46 PM |
