Old Apr 20, 2012, 09:38 AM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
Question
Seeking Sea Plane Plans
I've been wrestling with building a sea plane for several weeks now, and I'm having some difficulties deciding. Thought the "collective wisdom" of the group might shed some light on my pre-conceptions.
First of all, I have built a number of EPP foamies -- mostly pusher type wings or prop-in-slot delta's. I really like fllying with elevons vs. RET. Like the
"smooth and sporty" way you can carve the air with an elevon plane.
I first thought about adding pontoons (floats) to a high-wing plane (think super cub on floats) but I'm thinking that the extra drag of the floats will cause the performance of the sea plane to be much less than that of the "land plane".
From those with experience, is this true?
Then, I thought more about the "flying boat" style (think the parkzone ICAN). I like the idea of having the fuse also serve as the "float". Should be more aerodynamic.
Thought about just buying the ICAN, but the price is a bit steep.
Are there any PLANS out there for something LIKE this plane?
I've looked at the Polaris plans, but I'm a bit hesitant on a plane with the motor so far back. Like the idea of a "mid mount" motor. Seems to be more "balanced" than a tail mount.
Does anyone know of a high wing flying boat style sea plane with a mid mount motor that is close to the wing line? Perhaps you can point me towards some plans...
Finally, I've previously built entirely out of EPP because I like the "bounce". Played a bit with Depron, but find it more stiff and "breakable". HOWEVER, I've also read that EPP is bad for water. Is there any good way to SEAL EPP, or do I bite the bullet, build from Depron, and hope for the best?
Thanks for reading my ramblings. I'd appreciate any advice.
Steve
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Apr 20, 2012, 09:50 AM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Steve: the roughness and open cell structure of epp doesn't work for seaplanes, i'm afraid. DS1sfb's SeaBB is an easy build good flying seaplane based on the Blubaby design. I put foam floats on my 42" BB, and it flys essentially same with as as without floats.
springer is online now Find More Posts by springer
Old Apr 20, 2012, 10:10 AM
Rocketman1092 is online now
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Give the Polaris a second thought - it's easy to build and flies great. The tail-mounted motor doesn't cause any issues.
Rocketman1092 is online now Find More Posts by Rocketman1092
Old Apr 20, 2012, 10:11 AM
CaseySP is offline
Find More Posts by CaseySP
CaseySP's Avatar
Canberra Australia
Joined Feb 2007
Build a Polaris.
Nothing wrong with the motor in the tail. 10,000,000 (so it seems) Polaris owners can't be wrong.
CaseySP is offline Find More Posts by CaseySP
Old Apr 20, 2012, 12:50 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Hello Flyboy Steve!
I wanted the Icon A5 as well, but was not willing to pay either.... so I made one!
Link to thread, plans, and pics:
http://www.rcgroups.com/forums/showthread.php?t=1606211
The plans are still in the alfa version, but they will be updated once the 2nd prototype is built. The first one was 40" WS built from Dollar Tree Foam. The 2nd prototype is 52" built from Model Plane Foam (MPF) -- www.modelpanefoam.com.
It's a great flier, and a lot of fun. Even if you don't have water, its a blast to just scoot around on the grass.
This is not a trainer, and I would classify it more as a sport seaplane - as it is pretty fast and maneuverable. I'm having a lot of fun with the 40" version and can't wait to complete the 52".
The most challenging part was waterproofing the hull -- and I am still researching in that department.
Best of luck in your search! Happy building and flying!
SNice is offline Find More Posts by SNice
Old Apr 20, 2012, 01:47 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Steve the Sea BluBaby has been on my wish list for a while
Snice ICON
The SeaDart
The Drongo
Drake
Darrow
BE-103
CL-415
Wilfor is online now Find More Posts by Wilfor
Old Apr 20, 2012, 06:03 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Steve
If you want to try a kit / ARF the Great Planes Seawind makes a great first floatplane. Maybe cheaper than ParkZone's Icon A5. Its good with 'bank and yank' type carving around the sky flying. Not exactly and aerobat but handles well. As a flying boat its very robust and forgiving and can teach you a lot about flying from water.
Grejen is offline Find More Posts by Grejen
Old Apr 20, 2012, 06:05 PM
billwhit is offline
Find More Posts by billwhit
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
Hi Steve,
If you aren't adverse to a dual prop plane, you might consider a Grumman Goose. Much like you said, I prefer float planes in which the fuse is the main float. The GG is a great looking plane that gets lots of attention!
Bill
http://www.rcgroups.com/forums/showthread.php?t=1171221
billwhit is offline Find More Posts by billwhit
Old Apr 21, 2012, 11:01 AM
Joined Nov 2007
Lots of info -- THANKS! I'll spend some time today reviewing and digesting it all...
Steve
Old Apr 21, 2012, 08:02 PM
Jhon-Jhon is offline
Find More Posts by Jhon-Jhon
Used Register
Jhon-Jhon's Avatar
Quebec
Joined Nov 2008
Steve, Maybe that one,Seamaster made of EPP :
http://www.rcgroups.com/forums/showthread.php?t=1340319
Jhon-Jhon is offline Find More Posts by Jhon-Jhon
Old Apr 21, 2012, 08:18 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hello Steve,
I've had several sea planes which have never really panned out so I too was searching for a "good" flying seaplane. I watched many videos and this one met my requirements.
Good on water handling
Good in air handling.
Foam construction
Good looking
Here she is. http://www.rcgroups.com/forums/showt...ghlight=sea+bb
I'm making mine from $Tree foamboard.
hoppy is offline Find More Posts by hoppy
Old Apr 22, 2012, 01:56 PM
Joined Nov 2007
I'm leaning towards the Sea Baby too! Looks simple to build and looks like it should fly well.
Thanks for your input!
Old Apr 22, 2012, 02:00 PM
Joined Nov 2007
Hi Jhon Jhon! Just looked up your thread and I'm impressed with the Sea Master. Haven't read through it all yet, but just wondering: How do you use EPP (which I really LIKE -- it bounces!) and get it WATER PROOF?
Got lots to read -- THANKS!
Old Apr 25, 2012, 08:27 AM
indyemmett is offline
Find More Posts by indyemmett
Joined Aug 2011
The Icon A5 is sweet - I know someone who owns one. While not foamies - the Grumman Widgeon looks nice. There are also plans available for the Grumman Goose.
Widgeon http://www.rcgroups.com/forums/showt...rumman+widgeon
Goose http://www.modelaviation.com/goose
indyemmett is offline Find More Posts by indyemmett
Old Apr 25, 2012, 10:50 AM
warhead_71 is online now
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Goose
Sikorsky S-39
Beaver (with optional floats)
Drake II
Tiger Moth TM400 with floats
Or like others have said, just put some floats on an old trainer or something that is easy to fly... much less learning curve if you are already familiar with how the plane flies.
P.S. - be sure to check out the waterplane forum.
warhead_71 is online now Find More Posts by warhead_71
Discussion seeking plans for simple woody runabout JayJay76 Dock Talk 8 Feb 03, 2012 08:22 AM
Discussion newbie seeks lobster boat plans Grammie Dock Talk 7 Oct 13, 2011 10:14 AM
Build Log Seeks depron trainer plan for my configuration bilax Electric Plane Talk 4 Oct 12, 2011 01:24 PM
Need Sea Gull plan or any other bird plan absolute-zero Slope 2 Nov 05, 2005 08:57 PM
seek for EDF 50 jet plan pkpichit Electric Ducted Fan Jet Talk 2 Jan 21, 2003 02:46 PM
