Old Dec 18, 2012, 08:36 PM
ChrisJ800 is online now
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Why? The 9xr handle with built in antenna is an upgrade over the 9x aerial with better signal strength (per HK) and harder to break than the folding type or one sticking out from a module. I thought I read here that frsky will be releasing a 9xr module. Yes the currrent DJT module will work with the extra aerial but hk already have a turnigy dsm2/x module without an extra aerial and that's 2.4ghz
ChrisJ800 is online now Find More Posts by ChrisJ800
Old Dec 18, 2012, 08:40 PM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Here a pic with 9xr compatible modules from the turnigy9xr.com site
http://www.rcgroups.com/forums/showp...postcount=1610
Old Dec 18, 2012, 09:41 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
I see the DJT twice in that photo and a bunch of garbage in between them.
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Dec 18, 2012, 09:58 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
this is eye candy!
Flazo is offline Find More Posts by Flazo
Old Dec 18, 2012, 10:47 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Originally Posted by flazo View Post
this is eye candy!
Flazo, you need to crop out the website addy in that picture. I'm pretty sure you can get banned fom RCG for that.
Just some friendly advise, as you may not realize.
KC
KC is offline Find More Posts by KC
Old Dec 18, 2012, 10:49 PM
Flazo is offline
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
got it! : )
Old Dec 19, 2012, 07:17 AM
jhsa is online now
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Well as far as I understand, there are some kind of contacts for the antenna??
that would not be safe.. or maybe I got it wrong..
jhsa is online now Find More Posts by jhsa
Old Dec 19, 2012, 05:05 PM
Jayman72 is offline
Find More Posts by Jayman72
Note to self, put on pants.
Jayman72's Avatar
Australia, VIC, Frankston
Joined Mar 2012
Need some friendly advise.
I have a 9x running er9x but still using orig flysky stuff.
Time to get in on Frsky.
Should i just get the module for my 9x, Get the 9xr when its out and module, or wait for the X12D which sounds so far the best option but the wait may be long by the sound of it!
I want to keep flysky going for my little stuff.
Jamie
Jayman72 is offline Find More Posts by Jayman72
Old Dec 20, 2012, 04:36 AM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
It was posted a few times already.
Common modules with a removeable antenna (frsky, DSM, ...) have a connector on the PCB for the coax pigtail, and a connector to screw the antenna on. This will have one to connect the module to the antenna (pictured here) and maybe one to connect the pigtail to the PCB in just the same way. How is that any different?
Kilrah is online now Find More Posts by Kilrah
Old Dec 20, 2012, 05:37 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
well this one looks like it works a little like a jack plug.. when you insert the module it also makes the connection for the antenna.. It just doesn't look very safe for 2.4GHz IMO
Old Dec 20, 2012, 05:55 AM
nigelsheffield is online now
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
Jamie
I f you can wait and make do with what you've got I would hold out for the x12d or of course the x9d which will be out sooner.
But if you NEED the frsky stuff NOW and you have er9x installed on your 9x a module would be cheapest and of course the 9xr is untested and unknown, if you do the module in 9x then you will be swapping modules though to keep your flysky and use 9x.
I f you get a 9xr then you will have a separate control still for flysky and frsky-soooo, basically it's up to you what you want lol.
I'm still using dx6i and waiting for the x9d or if that does not live up to expectations on the forums then the x12d but who knows maybe by the time the x12d comes out something else will be on the cards which is even better lol-it goes on and on lol.
I just get what I NEED now when I need it rather then trying to have the latest and greatest. Just fly and enjoy yourself!
nigelsheffield is online now Find More Posts by nigelsheffield
Old Dec 20, 2012, 06:02 AM
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
It looks quite like an SSMB connector. Industry standard for about what, 40 years? And rated to 12.4GHz.
Old Dec 20, 2012, 09:02 AM
bpr is offline
bpr
Find More Posts by bpr
bpr
United States, IL, Oak Park
Joined Jan 2005
A hard wired antenna is more reliable because it has fewer movable parts on which it depends. Reliabliity is relative.
One failure example, not the only one:
The modular design shown is pretty good, but can fail if, for instance, the plastic clips which hold the module in place become loose or busted. In that case the module can move a little bit with use and handling, and can cause wear on the various connectors. The best solution to that scenario is to replace the tx case, which can be a pain.
I have had this happen in well abused 72 mhz trannys. The long pins which supply power and get back signal from the module can be loosened at the board - the solder joint. This has happened due to simple insertion and removal of modules, and is much more likely in the abuse scenario. In either case, intermittent loss of rf. Ugh.
Again, the modular design is good, but a fixed design is slightly better.That's one reason the the in-case antennae are an improvement over removable or even projecting antennae. Not an enormous improvement, but ...
bpr is offline Find More Posts by bpr
Old Dec 20, 2012, 10:36 AM
jhsa is online now
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Well they might be rated for that frequency, but for how long and how much plugging and unplugging?..
For the reasons stated on the post above, I hope that frsky doesn't make the same mistake..
Old Dec 20, 2012, 11:28 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
I agree taking modules in and out repeatedly will eventually lead to failure, but how many times will the average user actually do this? If I get an X12D I'll be using the inbuilt FrSky RF the vast majority of the time, just switching to an Orange or Spektrum DSM2/DSMX module for UM BNFs if I get one or two of those. Result - I'll be fitting my module then forgetting it, number of cycles = 1!
Sure that may be one extreme end of the spectrum, but I don't think most people will be regularly using their FrSky TXs with three or more different RF protocols (inbuilt plus at least 2 modules, thus requiring regular swapping). Given the FrSky RXs are so affordable, won't people just sell off their least prevalent RX type and standardise on no more than 2 protocols?
MattyB is offline Find More Posts by MattyB
Discussion Frsky X12D renatoa Romania 22 Mar 15, 2013 05:01 AM
Cool FrSky Radio Sale Rotozuk Hot Online Deals 95 Apr 04, 2012 07:08 PM
Discussion New radio to go with FrSky Teamsherman Australia 37 Mar 28, 2012 05:36 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Discussion Ordering a new radio setup, 9x + frsky telemetry, am I missing anything? carl1864 Radios 8 Nov 28, 2011 10:53 PM
