Old Nov 21, 2012, 08:04 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
I was thinking about the circuitry at the model end.
Do the sensor exist or are we still expected to make our own
No I'm not using a 9x but an Optic 6 with a module. when I bought it I went for the V8 as there was no instrumentation available at that time. So I'm wondering if that still teh case, there is no point in a fancy transmitter if the airborne equipment isnt available
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Nov 21, 2012, 08:12 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The altitude sensor exists, but was discontinued, to make room to a new device, a full featured vario with bip beep beeeep... and all the buzz. The older sensor was useful for altitude only.
renatoa is offline Find More Posts by renatoa
Old Nov 21, 2012, 08:44 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
I bought all my system with sensors back in February. They've been there for quite a while.
Kilrah is offline Find More Posts by Kilrah
Old Nov 21, 2012, 10:52 AM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Terry
Terry,
Yes, it is all pretty much plug and play these days. Some of the features you requested do not exist at this time, but will in the new Transmitter that will be available very soon. (Alarms for most anything, true vario.)
Here is a complete list of sensors that are available today:
http://www.alofthobbies.com/radio-ge...y-sensors.html
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Nov 21, 2012, 11:08 AM
UK, Bedworth
Joined Apr 2004
Thanks Wayne
I see you need to use a hub to connect everything it looks pretty substantial but I note the weight isnt listed do you know what it is ? I fly small light models (300 - 600 grams) so carrying an extra 50 or 60 grams of electronics will notice.
Terry
Old Nov 21, 2012, 11:15 AM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
The hub is pretty light thing, but all of the wires and such can get messy in a small plane. If you just want to monitor voltage, you do not need the hub. If you are going to monitor voltage and amperage, you do not need the hub. Most of the other sensors do require the hub.
With that stated, FrSky is working on making hub-less sensors. You will be able to daisey chain your sensors together. These "smart sensors" will cost a little more, but gets rid of limitations of the hub. These new sensors will start hitting the shelves a little while after the new transmitter is out. The nice thing is you will not be limited to the number of plugs on the hub, so if you want to run 5 temp sensors, you can. (I get the occasional request for folks flying scale 4 engine bombers that need to monitor each motor.)
-Wayne
Site Sponsor
Old Nov 21, 2012, 01:40 PM
rajazo is offline
Find More Posts by rajazo
rajazo's Avatar
Chile
Joined Jul 2010
Terry, as rotozuk said , basic functions don't need the hub. I use the volt meter only and the module beep when reach lower volt or the rx has problem with signal (different beeps programed with a PC).... Really useful on small planes...
Just buy the USB interface to program all...
The telemetry hub is reserved for my future FPV
rajazo is offline Find More Posts by rajazo
Old Nov 21, 2012, 02:44 PM
UK, Bedworth
Joined Apr 2004
So if i'm understanding you all correctly I don't need a hub for signal strength and battery voltage. But if I want a readout of mAh used or a variometer then I need to wait for the new designs of sensors.
Terry
Old Nov 21, 2012, 04:13 PM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
You can do vario now by wiring in the Thermal Scout vario to the FrSky hub and there are several youtube vids of folk doing that but Im looking forward to the new hubless vario too!
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Nov 21, 2012, 07:29 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
With all due respect....I found that combo rather worthless for me. I was able to see the glider rise in the thermal before the vario sounded. It needed to be more sensitive for my taste but yes it does work.
A10FLYR is offline Find More Posts by A10FLYR
Old Nov 21, 2012, 07:47 PM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
ok good feedback and I will definately wait and buy the Frsky hubless vario when it gets released.
Old Nov 22, 2012, 02:04 AM
Kilrah is offline
Happy FPV flyer
Kilrah's Avatar
Joined Sep 2006
mAh used needs only the current sensor, no hub required. It's quite heavy however.
Old Nov 22, 2012, 02:14 AM
Zeeland is offline
Find More Posts by Zeeland
Joined May 2012
Yes, the FAS-100 is a bit heavy. But on FrSky Facebook there are another FAS-40 (40A Maximum) is available, pretty much "pocket side" compared with FAS-100 (11.4g vs 24g).
https://www.facebook.com/FrSkyRC
Zeeland is offline Find More Posts by Zeeland
Old Nov 22, 2012, 03:32 AM
renatoa is offline
Joined Sep 2007
Same size, 38*30*10mm, only weight is half.
Still not able to fit in many planes, unfortunately, and frustrating, when we see around half sized similar units. The added data cascading logic seems too much for this approach.
I would suggest to redesign the layout as two boards, the sensor itself, and additional logic on a second board, the whole having a layout as close as possible to a cylinder, like 20*30*15mm, where 30mm is the length, along the connectors/wires direction.
Old Nov 22, 2012, 10:19 AM
UK, Bedworth
Joined Apr 2004
I'm starting to think that the weight and complexity of the on board electronics will make telemetry too complex expensive and heavy for the type of flying I do (parkfliers , a thermal soarer and a camera equipped easy star all flown LOS)
Terry
Discussion Frsky X12D renatoa Romania 22 Mar 15, 2013 05:01 AM
Cool FrSky Radio Sale Rotozuk Hot Online Deals 95 Apr 04, 2012 07:08 PM
Discussion New radio to go with FrSky Teamsherman Australia 37 Mar 28, 2012 05:36 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Discussion Ordering a new radio setup, 9x + frsky telemetry, am I missing anything? carl1864 Radios 8 Nov 28, 2011 10:53 PM
