Old Nov 17, 2012, 05:42 AM
nabazul is offline
Find More Posts by nabazul
Joined Jun 2010
Originally Posted by jj604 View Post
If not, you could run the Tx off a 6v BEC from the 12 V battery.
which means again messing around with the radio. We need 12v at the module compartment.
EzUHF, TLRS, DragonLink, Rangelink ... all of them require 12v.
nabazul is offline Find More Posts by nabazul
Old Nov 17, 2012, 06:59 AM
nigelsheffield is offline
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
I think that providing 12v for a uhf module will not be high on the list and don't imagine that frsky will change their ideas on the battery just for that, most people will be happy with the standard modules.
One solution would be for the tx to have no set battery voltage requirement as long as it's over say 6v and put in a switching ubec to allow any battery that will fit to be used, but a switching psu would have to be well shielded and well made for reliablilty with the output smoothed so that NO interferance would be present.
But I think it would be a simple matter for anyone to do this themselves if they want to and frsky will just use a battery that will be around a 1 or 2 cell lipo or 2 cell life or 4 nimh, which would be simple and reliable.
I use 1 cell lipo as rx battery in my dlg and I can squeeze a 1200mah instead of 350mah 2 cell lipo or a 300 mah nimh and the resulting in play times increasing from 1:30hr to 6hr upwards! So a one cell lipo would be ok in my book, a one cell life would be even better if the voltage would be high enough.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Nov 17, 2012, 07:10 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Frsky has plans for his own LR module, so ...
renatoa is offline Find More Posts by renatoa
Old Nov 17, 2012, 07:46 AM
rajazo is offline
Find More Posts by rajazo
rajazo's Avatar
Chile
Joined Jul 2010
Ahhh...All sounds perfect...
I don't understand all the specific requirement from guys around... Long time ago in the thread these tx present really good specs...all my wishes was there:
More than 6 program mixes
10 memories or more
Customizable switches and channels
Telemetry display
Module based for future and past transmition protocol
Upgradeable software
Lateral slider
12V,6V who cares!!!
Go ahead and test it a lot... I can't forget the problems of the new turnigy x6 or the alzaimer in the T6 from flysky
rajazo is offline Find More Posts by rajazo
Old Nov 17, 2012, 07:53 AM
renatoa is offline
Joined Sep 2007
The only illness detected so far is a serious cognitive dissonance between the three models
Old Nov 17, 2012, 08:36 AM
nabazul is offline
Joined Jun 2010
ok so i will have to wait 2 years till they finished this before this radio is of any use for me. Seriously? Why having a module compartment when there are no working modules for it? That makes it totally useless.
What about adding a step up converter to the power supply of the moduleslot to convert the 2s to 12v. Still not a good solution because this will suck that small battery empty in no time but at least we can use modules.
Old Nov 17, 2012, 08:59 AM
renatoa is offline
Joined Sep 2007
The battery could be small as voltage, but as energy it is on par with the others.
Instead having 3s 2000mAh, Graupner for example use 1s 6000mAh. Same 20Wh energy packed in different way.
Nobody say to wait for nothing. But to complain about a not existing radio does not comply with a not existing standard powering system it's a bit strange, imo.
Old Nov 17, 2012, 10:00 AM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
And all older modules and receivers are planned to be upgradeable to PXX. At least this was the initial plan...
Great, thats what I wanted to know, been holding off on buying more Rx because I didn't want to deal with 3 or 4 different types of FrSky receivers.
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old Nov 17, 2012, 10:13 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
The radio has a JR module slot. So, the radio will supply it with what a JR module needs. That way, you'll get to use any existing or future JR modules, of which a certain number is available:
- Spektrum
- Futaba FASST
- Graupner HoTT
- Multiplex M-Link
- Jeti
- Assan
- Corona
- FlySky
- RMILEC LRS
.. and probably a few more I forgot, and not counting FrSky even if a 2nd FrSky module might even interest those in countries where recent regulation require dual transmssion for certain model categories.
I wouldn't really say there are "no modules for it", and as such it's not useless at all.
All those are external boxes you're supposed to take care of powering yourself. A radio manufacturer can't really design his radio based on whatever number of weird 3rd party things you might want to use with it. They chose a well known flexible and widespread standard, and went with it. Your job to use a 2nd battery, an UBEC, a step up converter or whatever is needed to comply with the requirements if they're not met. Or, to forget about those radios and go find one that suits you out of the box...
BTW, the TSLRS works down to 6V.
Kilrah is offline Find More Posts by Kilrah
Old Nov 17, 2012, 11:19 AM
P 51 Jockey is offline
Find More Posts by P 51 Jockey
Corona, CA
P 51 Jockey's Avatar
United States, CA, Corona
Joined Oct 2011
No. It has been stated that it will be backwards compatible. Besides, if it is module based, you can just plug your module in.
P 51 Jockey is offline Find More Posts by P 51 Jockey
Old Nov 17, 2012, 12:54 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
the dl also works on 2s (as written on the website...) and i bet others too.
CrashMeUp is offline Find More Posts by CrashMeUp
Old Nov 17, 2012, 01:58 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
Wish FrSky would give us a release date for the X9D. With the 9XR getting released next week (probably) it would be good to know if the FrSky is coming soon. I'm tossing up between the two but will probably go with the 9XR as who knows when the FrSky is getting released. I'm sure that many others would be the same.
BrettAltea is offline Find More Posts by BrettAltea
Old Nov 17, 2012, 02:08 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I was going for the 9XR until I heard of the X12D. X12D seems more up my alley.
Either way, I'm definitely not going to be ordering the first batch of the 9XR's. I held off on ordering the first batch of OrangeRx modules, and boy was I lucky I did.
acetech09 is offline Find More Posts by acetech09
Old Nov 17, 2012, 08:01 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Come on .. live on the bleeding edge. (my orangerx transmitter module arrived today)
scott page is offline Find More Posts by scott page
Old Nov 17, 2012, 09:36 PM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
Why not get both? More toys
tignmeg is offline Find More Posts by tignmeg
Discussion Frsky X12D renatoa Romania 22 Mar 15, 2013 05:01 AM
Cool FrSky Radio Sale Rotozuk Hot Online Deals 95 Apr 04, 2012 07:08 PM
Discussion New radio to go with FrSky Teamsherman Australia 37 Mar 28, 2012 05:36 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Discussion Ordering a new radio setup, 9x + frsky telemetry, am I missing anything? carl1864 Radios 8 Nov 28, 2011 10:53 PM
