Old Feb 06, 2013, 09:28 AM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
tignmeg is offline Find More Posts by tignmeg
Old Feb 06, 2013, 06:22 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
A10FLYR is offline Find More Posts by A10FLYR
Old Feb 06, 2013, 06:57 PM
CiprianGugu is offline
Find More Posts by CiprianGugu
Look Up
CiprianGugu's Avatar
United States, TN, Jamestown
Joined Nov 2003
Ugh, I missed it. I always do.
CiprianGugu is offline Find More Posts by CiprianGugu
Old Feb 06, 2013, 07:06 PM
igorp is offline
Find More Posts by igorp
FPV Crash Dummy
igorp's Avatar
United States, CT, Bloomfield
Joined Aug 2007
Sooooooo. Hopefully new FrSky receiver won't use a name that is already used by another receiver company, that would be mess in an already confusing arena of names. Hitec already didn't think it through when they released their new tx with the name 9X.
igorp is offline Find More Posts by igorp
Old Feb 06, 2013, 10:10 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Name looks a bit different...they just posted this...darn it, now I have to get a new module and receivers if I want to use the new stuff...always something...I know I can use the current items too, but there's a bit more stuff built in which looks interesting. Maybe they should just be called xjt8, xjt9 and xjt12 to get rid of all those x and r's after the numbers..unless the tx is going to be called something else...well you know what I mean. I like to keep things plain and simple. Tx maybe should just be called...frsky 8, frsky 9. frsky12. Why 3 different radios, don't know, or it could just be one called frsky 1 since you can get all the features in the same one...just making suggestions...but what do I know...
http://www.frsky-rc.com/ShowNews.asp?id=91
efx is offline Find More Posts by efx
Old Feb 07, 2013, 02:32 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Auto-detect the firstly received signal after being powered on and act as conventional digital servo, SBUS compatible servo or CPPM compatible servos.
I don't understand why you need a servo to do CCPM seeing as every modern radio and all FBL controllers do that anyway.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Feb 07, 2013, 05:50 AM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Agreed - the UN should pass a resolution that the number 9 and the letter X are globally banned from all future TX and RX releases by every manufacturer!
MattyB is online now Find More Posts by MattyB
Old Feb 07, 2013, 05:56 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
CPPM is a bit different from CCPM
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Feb 07, 2013, 06:47 AM
microtechnics.eu is offline
Find More Posts by microtechnics.eu
Joined Feb 2013
Don't worry, there is NO number 9 in future FrSky radio's name !
No X either...
microtechnics.eu is offline Find More Posts by microtechnics.eu
Old Feb 07, 2013, 07:00 AM
igorp is offline
FPV Crash Dummy
igorp's Avatar
Joined Aug 2007
No what I was referring to was x8r. A receiver by that name already exists from assan! So now there are two x8r receivers on the market.
Old Feb 07, 2013, 08:51 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
CCPM: Cyclic/collective pitch mixing
http://en.wikipedia.org/wiki/Cyclic/...e_pitch_mixing
To drive the swash servos on a CP helicopter.
CPPM: Combined PPM
Means that the entire PPM stream (all 8 or however many channels) is available from a single output on the receiver, by contrast with the usual splitting up into separate channels for the various servos.
Daedalus66 is offline Find More Posts by Daedalus66
Old Feb 07, 2013, 09:22 AM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
New module and rx's
What frequencies do the new X8R and L9R operate on? They both claim long range:
"Longer operating range: three times of the operating range for V8 or D series."
...though in the module description, only the L9R (when in LR12 mode) is described as being long range.
Since the module is backwards compatible with V & D series rx's, I assume it is 2.4Ghz. If so, how are they improving the range 3X?
TNug is online now Find More Posts by TNug
Old Feb 07, 2013, 09:26 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Better receiver input processing, low noise amplifiers and filtering.
These have effect in non urban environments, sure. Flying in a high noise floor environment will not let the receiver to raise the gain to maximum level.
This is also the reason of so great advertised range, 4-10km, depends very much on environment congestion.
renatoa is online now Find More Posts by renatoa
Old Feb 07, 2013, 09:43 AM
TNug is online now
Waypoint Collector
TNug's Avatar
Joined Feb 2012
Cool. Thanks for the confirmation. I'll look forward to some real world results once these are available.
Old Feb 07, 2013, 11:02 AM
igorp is offline
FPV Crash Dummy
igorp's Avatar
Joined Aug 2007
Renato,
Do you know if on the new x8r channels 1-8 can be accessed traditionally, while getting access to 9 and up can be done with the sbus decoder?
Discussion Frsky X12D renatoa Romania 22 Mar 15, 2013 05:01 AM
Cool FrSky Radio Sale Rotozuk Hot Online Deals 95 Apr 04, 2012 07:08 PM
Discussion New radio to go with FrSky Teamsherman Australia 37 Mar 28, 2012 05:36 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Discussion Ordering a new radio setup, 9x + frsky telemetry, am I missing anything? carl1864 Radios 8 Nov 28, 2011 10:53 PM
