Old Jan 25, 2013, 03:16 PM
Michael V is online now
Find More Posts by Michael V
Michael V's Avatar
United States, CA, Torrance
Joined Apr 2012
A few more points:
- FM signal always selects the strongest, so while antenna direction in close proximity may not be an issue of range, it still is a factor in resistance to noise pollution.
- Diversity units with multiple antennas is a good solution (chooses the best signal out of multiple antennas) that is typical on some FPV receiving stations. It may that Rx with two antennas use diversity, but I'm not sure. In which case put one wire horizontal, the other vertical, or at 90deg of each other, each has its advantages (except parallel is not as good)
- What I meant thus is that you may have one plane or one flying session for which horizontal is best and another for which vertical is best. There is no perfect for all. Or one can just choose one and make it the best compromise.
Michael V is online now Find More Posts by Michael V
Old Jan 25, 2013, 06:41 PM
Teambarger is offline
Find More Posts by Teambarger
Teambarger's Avatar
USA, MA, Townsend
subd
Teambarger is offline Find More Posts by Teambarger
Old Jan 25, 2013, 08:33 PM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
Michael V
Thank you for your effort. It was very informative.
The key bits I got out of that was that you should 'try' to optimize orientation but most users would not notice the improvement and diversity is well worth the effort/cost. This explains why some high end receivers have multiple antennae / satellites.
A pity some in this forum would much prefer to flog us off saying it is far too complicated for posting in a forum. When it is more likely that they themselves don't understand it.
tignmeg is offline Find More Posts by tignmeg
Old Jan 25, 2013, 08:35 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by Fly2High View Post
Now, if I am up such that I am in a thermal turn and the carbon fuse blocks one antenna, couold you not have the other receiver antenna pointing straight at the transmitter causing it to reeiver the worst possible signal?
I'm starting to prefer FRP to CF in my helicopter frames. Only a few grams weight difference, more durable in a crash and it won't shadow the radio. Less expensive too.
And you can get them in colors other than boring black.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jan 26, 2013, 04:41 AM
nigelsheffield is online now
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
All this talk of antennae position makes me wonder why we can't have diversity on our tx as well as on out rx.
I have my antennae horizontal as more likely that I will fly high over my head then far away out to the side, but on occasion if I am laying down with plane thermaling I have to think about the orientation a bit to be safe.
Is there a reason we don't have 2 tx antennas?
nigelsheffield is online now Find More Posts by nigelsheffield
Old Jan 26, 2013, 05:37 AM
Mikarro is offline
Find More Posts by Mikarro
M$ Security
Joined Jun 2010
I disagree
Mikarro is offline Find More Posts by Mikarro
Old Jan 26, 2013, 05:48 AM
xairflyer is online now
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Multiplex do
xairflyer is online now Find More Posts by xairflyer
Old Jan 26, 2013, 01:31 PM
Michael V's Avatar
Joined Apr 2012
This is my theory, but it could be wrong:
One can only have one antenna active at the time. That's what diversity does, pick the one with the strongest signal.
So you cannot have two antenna active, and while it's easy to pick the strongest signal when receiving, when transmitting there is no reason why one would be stronger than the other unless you get feedback from the receiver (and constantly pulses both) or you know where the receiver is at least. That is why.
Now I don't know what the 2 antennas purpose is on the transmitters pictured below, but I'm curious. Anyone knows?
Old Jan 26, 2013, 01:40 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Transmitter diversity...
WimH is offline Find More Posts by WimH
Old Jan 26, 2013, 01:58 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
The transmitters using two antennas use them switched, not simultaneously.
Using both in the same time will make multipath even worse.
When you see two or more antennas in professional tower, those are antenna arrays, and the placement is uber critical to make hem work as only one.
renatoa is online now Find More Posts by renatoa
Old Jan 26, 2013, 09:25 PM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Whats a pity, is people want to be spoon fed on a forum, without doing the research themselves, and actually learning!!
Regardless, everything Ren and I have stated still holds true!!
Even when considering Rx diversity, and the way most people fly, if the antennae are placed at 90deg., the average position of the two, with an acceptable receiving pattern will be vertical. Even if one is pointed down, its still vertically polarized. There are some cases where the average will be horizontal, but that should only apply if you were careless in you Rx antenna placement.
KKUSA is offline Find More Posts by KKUSA
Old Jan 26, 2013, 09:54 PM
tignmeg is offline
Registered Adict
tignmeg's Avatar
Joined Jun 2012
Maybe that would have been true if there had actually been anything said that was actually constructive.
Luckily, most who have posted here are smarter than me and just ignored the rhetoric and arrogance.
Old Jan 26, 2013, 10:13 PM
BrettAltea is offline
Find More Posts by BrettAltea
Australia, VIC, Melbourne
Joined Aug 2011
Maybe KKUSA you're talking about Rx with two antennas. Mine only have one.
BrettAltea is offline Find More Posts by BrettAltea
Old Jan 26, 2013, 10:52 PM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
Originally Posted by xairflyer View Post
Multiplex do
As does the Futaba 8J and the Spektrum DX18.
pach is offline Find More Posts by pach
Old Jan 27, 2013, 04:30 AM
Joined Dec 2011
Originally Posted by Mikarro View Post
I disagree
CF's greater stiffness actually makes it more likely to shatter in a crash than an FG or plastic frame.
Discussion Frsky X12D renatoa Romania 22 Mar 15, 2013 06:01 AM
Cool FrSky Radio Sale Rotozuk Hot Online Deals 95 Apr 04, 2012 08:08 PM
Discussion New radio to go with FrSky Teamsherman Australia 37 Mar 28, 2012 06:36 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 07:08 PM
Discussion Ordering a new radio setup, 9x + frsky telemetry, am I missing anything? carl1864 Radios 8 Nov 28, 2011 11:53 PM
