Old Jan 15, 2013, 04:05 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Depends on the wheel/disk.
I have used lots of things with buttons, a DX8 and a couple of Multiplex transmitters - and I'm an older guy.
The Multiplex disk adjustor is far and away my favourite system. It separates the push and the rotation axis very clearly. Gives you very rapid access through complex hierarchical menus while keeping a very discrete selection process.
Everyone will have their own views - just don't put a touch screen on it please! Touch screens are great for complex positional info, sealing the device from the outside environment, and (the main reason) keeping the manufacturing cost down since you can do all the design and configuration in software and change your mind afterwards when you didn't do it properly the first time. They are poor for choosing between discrete options if screen real estate is limited. Ask anyone with less than perfect eyesight and hand control who has to type on a smartphone.
Originally Posted by A10FLYR View Post
I hate wheels! I have a hard time making them turn WITHOUT pressing hard enough to activate the switch!! Older guys can relate to this I'm sure.
jj604 is online now Find More Posts by jj604
Old Jan 15, 2013, 06:33 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
I have a A9, T8J, FF6, 9XR, Optic 6, also used DX8.
By far my favourite is the A9. If you want to change an option, just tap it. No scrolling back and forth missing it, or wondering if you can change it. Just tap it! If it doesn't select, then its not a changeable option. Also I like the fact that its a resistive touch screen as well, as a capacitance screens (i.e. modern smartphones - iPhone, etc) you can't use through a lot of gloves without modding them.
But then as Wayne shows, not everyone likes a touch screen...
However this does show that everyone is different and that not everyone can be satisfied.
I don't like spinney things, I tend to spin past them too often and it annoys me. Also you can either have the turning thing too hard or too soft. I do think the T8J joystick is pretty easy to use though...
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Jan 15, 2013, 09:14 PM
crazy8s is online now
Find More Posts by crazy8s
crazy8s's Avatar
Pennsylvania, USA
Joined Sep 2008
Si.
+1 Simon. I have the A9 and a few Evo's and my son has the DX8. I can't stand using the DX8 when I'm programming it for him because of that slippery chrome plated (what a dumb idea) rotating drum. I'm always pushing it in too far while trying to rotate it and selecting the wrong screens. And yes I know all about rotating it from the bottom and pushing it in from the top. Doesn't help, especially when the weather gets a little cooler and the humidity levels drop and the dried out skin on my fingers can't get a grip! There is nothing better than the big touch screen of the A9 hands down!
crazy8s is online now Find More Posts by crazy8s
Old Jan 16, 2013, 12:23 AM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
When my hands are just a little cold I can't roll the roller side to side unless I put pressure on the roller and then I have to be real carefull that I don't push to hard 'cause then I press down and switch between screens. Dry skin just does not work well. At least for me.
A10FLYR is offline Find More Posts by A10FLYR
Old Jan 16, 2013, 01:17 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Agree 100%. The roller and the wheel are totally different in action. The Multiplex wheel is moved by the rim so there is no force pushing it down. Then you can move your finger/thumb over and press it without rotating it. In practice it is very quick, particularly if you are moving through a long list of values or accurately adjusting a % scale. IMO touch screens are not good for that.
The roller relies completely on you being able to judge the force against the spring between rolling and pressing even if you do roll the "non-moving" end. Doesn't separate the adjust and select actions as well as a wheel. Quite different in practice.
Old Jan 16, 2013, 11:35 AM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Look to some of the nicer digital cameras for really nice selectors. Heck, even the cheap Casio I have sitting on my desk has a nice simple selector that works well.. No spinning, it is an outer ring that is 4 position buttons and an inner button in the center. Simple and easy. sometimes simple is best.
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Jan 16, 2013, 11:53 AM
mihlit is offline
Find More Posts by mihlit
Joined Oct 2011
Well, digital camera is different. There is some menu with just a few items and every item has just a few options.
On the other hand, in transmitter you often set values -150..+150 %. That's a lot of click, click, click, click, click, click, click, click, click, click, click, ... Sure, you can push and hold. a) it does not speed up = takes too long, b) it does speed up = you are going to overshot (with bad acceleration value, you can overshot several times). With rotational encoder, you are not waiting (getting the "everything takes too long" feeling), you are active (in control) and given you can rotate it with different speeds (different increment), you don't have to click (rotate) like crazy.
So I prefer rotation encoder, but I can live with buttons too. Best option - rotating ring (no push) with push button in the middle (no rotation).
It seems, that to make as all happy, FrSky has to put touch screen on X16D, but with sw that allows to configure everything without touching the screen. Just using standard buttons or encoder - with both of them present. I guess not everyone will be happy
mihlit is offline Find More Posts by mihlit
Old Jan 16, 2013, 12:44 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
What? No mouse option?
Site Sponsor
Old Jan 16, 2013, 12:46 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
laptop touchpad mandatory
renatoa is online now Find More Posts by renatoa
Old Jan 16, 2013, 12:57 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Yes, on your laptop connected through a USB cable
I only make "urgent" fixes in the field (ie never).
Scott
ScottSails is offline Find More Posts by ScottSails
Old Jan 16, 2013, 01:14 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
I'd also like a fold out, full sized keyboard on the back with one of those little jiysticks built into it. :P
Site Sponsor
Old Jan 16, 2013, 01:43 PM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
And don't forget the hot drinks dispenser, essential in this weather
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 16, 2013, 03:38 PM
ChrisJ800 is online now
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Bluetooth and a Siri counterpart so I can talk to the tx
ChrisJ800 is online now Find More Posts by ChrisJ800
Old Jan 16, 2013, 03:44 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Me: "Hello Siri, please reduce expo on the elevator by 20%."
Siri: "Did you say turn off power?"
Me: "NO!"
Siri: "Turning off power. (in a very low voice) I never liked that plane... It had a bad attitude."
Site Sponsor
Old Jan 16, 2013, 03:49 PM
jkishan16 is offline
Find More Posts by jkishan16
Getting Somewhere :D
United Kingdom, England, Loughborough
Joined Dec 2012
Hi guys
Just wanted to ask If we can still expect the March release date for the X9D to be reliable and accurate?
jkishan16 is offline Find More Posts by jkishan16
Discussion Frsky X12D renatoa Romania 22 Mar 15, 2013 05:01 AM
Cool FrSky Radio Sale Rotozuk Hot Online Deals 95 Apr 04, 2012 07:08 PM
Discussion New radio to go with FrSky Teamsherman Australia 37 Mar 28, 2012 05:36 AM
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Discussion Ordering a new radio setup, 9x + frsky telemetry, am I missing anything? carl1864 Radios 8 Nov 28, 2011 10:53 PM
