Old Apr 20, 2012, 01:42 AM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Build Log
F35 70mm EDF Profile
I have been building a profile based F35 70mm EDF out of 1/2" Dow blue foam, 1" R tech 25psi white foam and 1 piece of dollar tree. I have the log in power point. The plane is almost done and I am going to try to post the power point on here for your comments. I have not tried to do this with power point so I will see what happens. If it doesnt work I will have to just post the pictures and text normally. This will be the first build log I post so please bear with me.
Lt599 is offline Find More Posts by Lt599
Old Apr 20, 2012, 02:09 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
The presentation was excellent! I'm no guru on these, but on page 38, rear view of body tube, I would call it a thrust tube, but it has no taper!! You will have no velocity to speak of. Go here and download the FSA calculator, to. figure out what you FSA is. I'm nor sure what its supposed to be, 85%, at a guess, but check tht out. Other wise. it looks good.http://www.rcgroups.com/forums/showp...11&postcount=4 good luck.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Apr 20, 2012, 02:27 AM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Thank you for the input. I dont have the measurments with me but I tried to make the opening at 90% of FSA, but I did the calculations by hand. Thank you for the info on the calculator, that will definately be more accurate for my next build.
Old Apr 20, 2012, 12:24 PM
Joined Dec 2008
Read post 7-8. http://www.rcgroups.com/forums/showt...m+fan+exit+dia
Sold Cyclone 64mm EDF fan unit and Chagesun 70mm EDF fan unit The Don Aircraft - Electric - Jets (FS/W) 2 Jan 25, 2012 04:14 PM
Sold SkyAngel F35 50mm EDF BNF with 2 Batteries dawjr Aircraft - Electric - Jets (FS/W) 3 Sep 27, 2011 08:27 PM
Sold 70mm Mig 15, 70mm F16, 64mm F35 The Don Aircraft - Electric - Jets (FS/W) 9 Mar 26, 2011 09:57 AM
Sold Hobby Lobby 70mm F35 Fuselage only New In Box rccrazee Aircraft - Electric - Jets (FS/W) 7 Oct 18, 2010 02:57 PM
For Sale Mr. B's Composite 70mm JSF F35 c Mr. Boogie Aircraft - Electric - Jets (FS/W) 6 Oct 05, 2008 08:22 AM
