Old Apr 20, 2012, 12:40 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Mini-Review
Oversky 7A PnP Brushless ESC for Genius CP/Mini CP
Tom Z is offline Find More Posts by Tom Z
Old Apr 20, 2012, 06:41 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
Great review as always!
I would like to know the cost though. The cost of the cheapest walkera lt esc compared to the oversky esc.
mescalinedream is offline Find More Posts by mescalinedream
Old Apr 20, 2012, 09:28 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Thanks.
Cost: $32.00 - Oversky 7A PnP Brushless ESC for Genius CP/Mini CP
Cost: $15.95- WK-WST-10A-LT (ESC/Converter)
The extra cost is worth it for me.
Also the FET's wear out over time with heavy use on the Walkera ESC's.
I have to replace them after a while on all my helicopters.
I now only use the XP-7A or XP-12A when possible. Never had to replace one either. They keep working great.
Pros: - Oversky ESC/Converter
  • Fully programmable
  • Light weight especially if you direct solder to it
  • Small in size
  • More headspeed then the WK-WST-10A-LT
  • Starts the motor much better than the WK-WST-10A-LT
  • Better timing than the WK-WST-10A-LT
  • Made to run an outrunner motor
Cons: - Oversky ESC/Converter
  • Price
Pros - WK-WST-10A-LT
  • Half the price of the Oversky ESC/Converter
Cons: - WK-WST-10A-LT
  • Doesn't start a BL motor as well as the Oversky ESC/Converter
  • Not made for an outrunner motor
  • Timing isn't the best for an outrunner motor
  • Not programmable unless you send it to astroid-designs to have a custom
    chip installed and have it custom flashed from what I understand
  • More weight than the Oversky ESC/Converter
  • FET's wear out over time with heavy use
  • Less headspeed then the Oversky ESC/Converter
Tom
Old Apr 20, 2012, 12:02 PM
Joined Jul 2008
I wonder if this esc http://www.bidproduct.com/part/Produ...20ESC_186.html is the same as overskys? it says xp-7a also and is 12.00$
here is a tiny little 3.5 amp for 8.53$
http://www.bidproduct.com/more/cartview.php?id=5452
How many amps do we need if we are using them on the minicp?
Old Apr 20, 2012, 12:31 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
I think it is.
C05 Specs.
Weight: 4.6g
Kv: 11500rpm/v
Size: 17mm x 13.9mm
Max current: 6A/60W
Current: 4.2V/0.7A (No load)
Shaft: 1mm
Shaft length: 8mm
You will still need a BL converter for the two ESC's you listed above unless
astroid-designs flashes it for you. We still don't know for sure if the flash
will work on the Genius CP/Mini CP. I plan to test one and find out.
Tom
Mini-HowTo Fix: Tail drift problem on Genius CP and Mini CP bobepine Micro Helis 54 Dec 17, 2013 09:29 AM
Discussion Mini CP vs mCPx v2 vs Solo Pro 100 vs Genius CP Marioinc Micro Helis 96 Mar 28, 2013 01:54 PM
Sold Genius CP W/Brushless C05 and ESC for Devo MX48 Aircraft - Electric - Helis (FS/W) 2 Feb 21, 2012 09:59 AM
New Product 2 in 1 Double Brushless Esc For Genius Cp, Pm me for more info. f.a.r.m.e.r Micro Helis 113 Jan 03, 2012 08:08 PM
Help! is this the right brushless motor and esc for genius cp? f.a.r.m.e.r Micro Helis 16 Oct 07, 2011 03:40 PM
