Old Feb 11, 2013, 04:42 PM
ak79 is offline
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
Originally Posted by xplorer F3J View Post
When installing my new X 2 I have noticed that there is play between the wingjoiners and the wings, there is still someone who has this problem??
Why don't we get those stripe's in the US?
ak79 is offline Find More Posts by ak79
Site Sponsor
Old Feb 12, 2013, 01:23 PM
xplorer F3J is offline
Find More Posts by xplorer F3J
xplorer F3J's Avatar
Belgium, Vlaams Gewest, Aalst
Joined Sep 2011
We order directly from Nan models and so we get what we ask colors and stripes or whatever you want
See pictures of Xplorer2 from a friend !!!
xplorer F3J is offline Find More Posts by xplorer F3J
Old Feb 12, 2013, 11:19 PM
ak79 is offline
Flightcomp.com
ak79's Avatar
Joined Apr 2006
Wow! That looks awesome!
Site Sponsor
Old Feb 12, 2013, 11:22 PM
Avaldes is online now
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Bob at SUSA will be happy to order custom colors for you. You just have to wait the extra time to have that model built.
Also, to the poster who questioned the joiner fit, there is some amount of thermal expansion that will play into the slop seen in wing joiners. If it is room temperature in your shop, in the summer time the joiners will likely be quite a bit tighter in the sun.
Avaldes is online now Find More Posts by Avaldes
Old Feb 12, 2013, 11:25 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Xplorers
Howdy;
Aaron called it, EXACTLY spot on...
Best,
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Feb 13, 2013, 08:46 AM
Joined Sep 2011
Hi We have also almost five months to wait before delivery !!! :-(
And yeah in summer when wings are heated up would be better !!!
But it was still a shock when I saw how much play on the wing tips and center part
I had already thought about the end of the joiner a layer of glue to submit to it a little thicker
Old Feb 13, 2013, 10:24 AM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
The thermal comments are really quite practical - assess this in flying conditions before you adjust it.
NOT GLUE! -
Use wax or something you can tune/remove. Carbon sands MUCH easier than glue so if yo use glue you will invariably be sanding away some needed carbon if and when you need to remove some glue for a perfect fit. Keep in mind that the play might be at the ends of the joiner boxes with the entrances being a perfect fit - use glue and you might not get past that part...
webbsolution is offline Find More Posts by webbsolution
Old Feb 13, 2013, 12:24 PM
Joined Sep 2011
NOT GLUE! -
Yeah you're right the play is not on the entrance bud on the end of the joiner boxes , and if you swapping the joiner from left to right and turnover you can find find a lesser clearance as you already suggested thanks bro !!! and i wil try soms wax !!
The CG for the new X2 wil be the same as the X1 ???
Old Feb 13, 2013, 12:58 PM
SoaringDude is online now
Find More Posts by SoaringDude
Team Hello Kitty
SoaringDude's Avatar
near Sacramento, CA
Joined Aug 2010
The absolute best semi-permanent solution to joiner wiggle is a trick I picked up from Tony Kilwein: use 1mil 1/2" Kapton tape (~$9 from Amazon). The tape material is very dense and highly thermally stable but its thickness is consistently precise. Including the silicon adhesive the tape is 2.7mil thick.
I had to use it on both my Xplorers to eliminate the joiner wiggle. On my X1-3.8 it took a piece on both the top and bottom of the wingtip-side of the joiner while on the main wing panel side it only took one piece on top of the joiner. Now it's a nice snug fit with zero movement.
As to thermal changes in the clearance I have not found temp to change the fit with the Kapton tape (or without).
Chris B.
SoaringDude is online now Find More Posts by SoaringDude
Old Feb 13, 2013, 11:10 PM
Avaldes's Avatar
Joined Aug 2006
Kapton tape is very handy, as is "Flash Breaker" tape...the blue stuff. A well equipped garage should have both of these items.
Personally I just use a wipe of thin CA to build up a joiner if needed.
Old Feb 13, 2013, 11:26 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Ok, one 3.8 X2 completed.
MKS 6125 for Flaps
MKS 6125 Mini for Ail
JR 3517 for Ele
Atx 94809 Rud
CG 120.
Before and after weights. Maiden tomorrow at local park.
fnnwizard is offline Find More Posts by fnnwizard
Old Feb 14, 2013, 12:13 AM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
Thanks for the weights. I am going to build a 4.0 x2 and will do the same thing you did here. I just hope putting 2the servos in the center section doesn't feild a 4 oz increase.
Joe
J. Wydronek is offline Find More Posts by J. Wydronek
Old Feb 14, 2013, 12:22 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Joe
It'll be close. 2 servos and frames, linkages, db9 connector and all that wiring and more connectors, servo covers and epoxy.
Old Feb 14, 2013, 12:31 AM
Joined Jul 2007
Joe
I just finished my 4.0 wing - will take that and stick it on the SL fuse I have in Phoenix - I only have a sport tube and I dont want to chance the new fuse getting the fin smashed as its a tight fit in a sport tube.
Old Feb 14, 2013, 01:09 AM
ak79 is offline
Flightcomp.com
ak79's Avatar
Joined Apr 2006
Get rid of that DB9, you can save some more weight there.
Site Sponsor
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 04:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 08:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 12:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 03:35 AM
