Old Feb 08, 2013, 05:19 PM
ak79 is offline
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
Comparing the brand new parts of my x2 3.5 and x2 3.8 there was a big difference in weight.
The center panels are the same on both but the 3.5 was 1 oz lighter. If it makes any difference the 3.5 is white, and the 3.8 is red with bare carbon bottoms with clear coat.
I suspect that the white paint coats better and is lighter, I also think the "naked" carbon with clear is heavier than just painting the bottoms red or white, etc....
So order a while one, it may be the lightest.
ak79 is offline Find More Posts by ak79
Site Sponsor
Old Feb 08, 2013, 08:25 PM
galenreed is offline
Find More Posts by galenreed
USA, CA, Visalia
Joined May 2007
I have a red fuse and a white fuse in my shop, weights are identical.
galenreed is offline Find More Posts by galenreed
Old Feb 08, 2013, 09:43 PM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Variation in production can cause a little more or less weight...
webbsolution is online now Find More Posts by webbsolution
Old Feb 09, 2013, 12:35 AM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
Clear coat is usually lighter than paint assuming you put the required amount of each. Its more likely that variation in the cleanliness of the build have more to do with the weight assuming there are no internal differences in construction
roydor is online now Find More Posts by roydor
Old Feb 09, 2013, 10:43 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Tighter fitting parts = less splooge, Roydor?
And/Or less splooge = lighter parts...
target is offline Find More Posts by target
Old Feb 09, 2013, 02:24 PM
P-51flyer is offline
Find More Posts by P-51flyer
P-51flyer's Avatar
USA, CA, San Jose
Joined Aug 2005
My 3.8 X2 came in at 62 to 63oz using 10g aileron and rudder servos. Awesome flying plane and my 2nd X2 just showed up! Love seeing that big brown box. Need to get building, Arizona is just around the corner!
Aaron
P-51flyer is offline Find More Posts by P-51flyer
Old Feb 09, 2013, 02:39 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
And help out your team mate and my flying partner, WD sub-40!
R,
Target
Old Feb 09, 2013, 03:36 PM
roydor's Avatar
Israel
Joined Nov 2006
The glue is usually heavier then the web for the spar so yes, tighter fit means less glue is required for a bond between the web and spar caps but it is also a question of excess epoxy inside the wing because it gets left inside the wing after closing without the possibility of removal.
Controlling the amount of glue for gluing both parts of the wing is difficult and requires "faith". Faith in that the miniscule amount of glue you want to use to glue everything will be enough. Sometimes we don't have enough faith so we use more than is needed, sometimes it's a question of how much microballoons was added to the mixture (more microballons equals lighter glue for the same volume but more brittle glue as well...) and sometimes it's just a question of a bigger\smaller hole in the bag\syringe used to apply the glue.
In the end, 2 oz (weight) is just 1-1.5 oz (volume) of more epoxy for a 3.5-4 meter wing. Thatís NOTHING! and is in the manufacturing tolerances. In fact, I'm surprised it's not more than that.
Roy
Old Feb 09, 2013, 03:47 PM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Roydor,
Thanks for sharing some manufacturing truths and helping to dis spell very common misunderstandings. Placing the tiniest of beads of "splooey" to bond the spar to the cap is always scary. How much is enough? How much is too much? Once it's done, it's in there. Tight fit or not... There are also items in our models that the manufacturer has little to no control over the weights. Most manufacturers use balsa for spars. Go to the hobby store and weigh each piece of 1/2" balsa. What are the variations?
The weight tolerances held by manufacturers today are pretty amazing in my book. You're not going to miss your time because of an extra ounce or 4 in your airframe...
dp
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Feb 09, 2013, 04:14 PM
P-51flyer's Avatar
USA, CA, San Jose
Joined Aug 2005
WD it's in good hands! Guess I should post a teaser picture of what came in the big brown box....
Can't wait to fly this one! More to come.
Aaron
Old Feb 10, 2013, 03:18 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Roy
I have 3 Xplorers and while the weights seem to be in tight tolerances there are clear differences in manufacturing. For an example, microballoons are much more liberally used in the spar/core bond of my 4m Xp2 compared to the 3.8m. Both are still ok and quite acceptable, but it looks like some NAN workers like the white stuff more than others... Or maybe the the 4m Xp2 spar was just slightly undersized?? This plane is one of the from pre-production prototypes.
Tuomo is offline Find More Posts by Tuomo
Old Feb 10, 2013, 01:45 PM
Joined Jul 2007
Aaron
I am hoping mine arrives Wednesday which gives me a day to put it together - and a few days to trim it out before the Phoenix event Weather permitting - I am also finishing abuild on my Fosa Lift which I dont expect to be near as ready for contest flying but who knows!
Old Feb 10, 2013, 05:06 PM
P-51flyer's Avatar
USA, CA, San Jose
Joined Aug 2005
Currently working on mine. Fly next weekend then pack it for AZ! Beautiful plane.
Aaron
Old Feb 11, 2013, 01:22 PM
xplorer F3J is offline
Find More Posts by xplorer F3J
xplorer F3J's Avatar
Belgium, Vlaams Gewest, Aalst
Joined Sep 2011
When installing my new X 2 I have noticed that there is play between the wingjoiners and the wings, there is still someone who has this problem??
xplorer F3J is offline Find More Posts by xplorer F3J
Old Feb 11, 2013, 03:02 PM
Joined Jul 2007
You may find that certain joiner positions offer a better fit that others - you have 4 variations by swapping the joiner from left to right and then each joiner can be reversed - Thats what I do to consider which fit is tight but not too tight. If all 4 are loose then you can always wax the joiner to tune the fit.
I had a tragi 801 I sold and a more accomplished pilot and builder did that to get the tips fitting perfectly.
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 04:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 08:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 12:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 03:35 AM
