Old Jan 29, 2013, 07:01 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Are you going to use the aluminum frames with the bearing to mount the flap servo, Tuan?
I sprung for a set with my 4.0, and glad I did. Between that and the full sized 6125, I have not yet had to touch my flap setup since I built the plane, and its still quite tight.
R,
Target
target is offline Find More Posts by target
Old Jan 29, 2013, 09:36 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
R,
Target
Those would probably be a bit of overkill for the X's. The linkages are not so short like those on an F3B plane where the pushrod compression forces are huge and thus transferred to the servo arm, bearings, case, mounting frame, then skin.
I am doing the flap servos with the wood frame, but block them so they tie into the upper skin and the main spar. I would think this method yield less flex than using the aluminum mount without tying into the spar or upper skin.
The bearings would be beneficial as they do provide extra support, however the amount of time the J planes are in high speed mode is but a few seconds here and there and one never pulls enough flaps in the high speed case that would make the extra support of the external bearings a necessity if the rest are solidly installed.
Bottom line, for me at least, is that I would worry more about the arm slipping on the output shaft than the flex of that final gear if there was that amount of compression force on the servo.
I'd actually like to use some flat carbon pushrods with holes at the ends that a rod slides into. the rod is held in place by carbon tubes at the flap end and an aluminum servo arm. The thicker wing allows this system to work very nicely.
Like that in the picture courtesy of fly-up85
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 29, 2013, 10:29 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Ok.
R,
Target
Old Jan 30, 2013, 12:08 AM
ak79 is offline
Find More Posts by ak79
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
I did a build recently with metal trays and extra bearing supports, added over 1.5 oz to the build, I don't know if they are worth it in F3J models.
ak79 is offline Find More Posts by ak79
Old Jan 30, 2013, 01:33 AM
J. Wydronek is offline
Find More Posts by J. Wydronek
J. Wydronek's Avatar
United States, AZ, Buckeye
Joined Mar 2010
That's what I was wondering. Thanks for giving the weight of the increase.
Joe
J. Wydronek is offline Find More Posts by J. Wydronek
Old Jan 30, 2013, 07:56 AM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
These guys have some nice frames, including some with a bearing. John at HKM-USA can get them.
http://shop.rc-electronic.com/e-vend...&c=1158&p=1158
Silent-AV8R is offline Find More Posts by Silent-AV8R
Old Jan 30, 2013, 08:38 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I used the metal frame on JUST my flaps of the 4.0.
Each frame weighed 7g (I weighed them). I added 14g (1/2oz) to my plane, and helped prevent the shaft from rocking.
For me, the extra 1/2 oz and $35 was totally worth it.
R,
Target
Old Jan 30, 2013, 10:34 AM
ak79 is offline
ak79's Avatar
Joined Apr 2006
Aha! Now those look good, and you know the wood must be lighter than the metal frames.
Old Jan 30, 2013, 11:26 AM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Bearings
Howdy,
These work quite well with most any frame..
http://www.soaringusa.com/External-B....0mm--4pk.html
Best,
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Feb 01, 2013, 12:25 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Here are some pics.
Old Feb 01, 2013, 10:34 AM
SoaringDude is offline
Find More Posts by SoaringDude
Team Hello Kitty
SoaringDude's Avatar
near Sacramento, CA
Joined Aug 2010
Very nice work Tuan. You may be an fnnwizard but you have the heart and skills of an engineer. In the immortal words of Dr McCoy: "I know engineers, they love to change things."
Chris B.
SoaringDude is offline Find More Posts by SoaringDude
Old Feb 01, 2013, 03:21 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Chris B.
Thanks Chris, you can definitely call it out of necessity that I try to optimize where I think it pays the most dividends.
One of my thought process on this (and I would love to hear the true experts' opinion on it as well) is that removing weight from the " 4 corners"... nose, tail and tips helps the rudder to yaw the plane quicker which in turn helps to keep the fuse on avg more inline with the airflow which keeps the airflow more perpendicular to the wing... especially in the low level saves.
We've all seen planes go on drastic diets in the last couple years and it's a great thing. However a big portion of that weigh is not proportional to the 4 corners of the aircraft so the moments of inertia for the aircraft has actually gotten worst. Couple that with a slower airspeed and now the rudder becomes less powerful in a given thermal. It also becomes much more non linear. We might have to kick the rudder more in the begining (reverse expo mix)
Couple this with a lot of people still not using their rudder thumb adequately (can we mention adverse yaw here and incorrect slip?) and you get the "too light" for right observations.
Most people won't realize this at all but on these lighter planes, we will need to mix in more rudder throws for the given ail throws becaseu of airspeed. Not only during roll maneuvers, but also during the steady banking because for the same amount of bank angle, the plane flies at a smaller diameter = more in rudder to keep that airflow perpendicular to the wing. How much more, I don't know right now.
I'll know in a week or 2 if the rudder of this new 3.8X might be on the small side or if it is large enough to be effective in the low level more turbulent stuff.
So, I am satisfy being able to get rid of any amount of weight at the front and rear of this baby... now what to do with the wing tips ....
Old Feb 01, 2013, 05:04 PM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Tuan, you're dead on. The fin size on my 67 oz X1 was marginal. Same fuse, same span, same planform, same fin and rudder, and my 53 oz X2 was vastly underfinned.
And you're also right, most won't notice it.
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Feb 01, 2013, 06:11 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Get the 3.5?
Tom
Kiesling is online now Find More Posts by Kiesling
Old Feb 01, 2013, 06:33 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Originally Posted by Kiesling View Post
Get the 3.5?
Tom
Hahaha, I was contemplating doing rds to the 3.8 tips as I did to my first and 2nd Xplorer to keep the ail servo in the center panel. If not then what servo linkages I would use (MKS 6125 minis or Atx809's or ???). Decisions, decisions, decisions, arhgg.
Thanks Daryl for confirming this! So my observations aren't just from lack of thumb exercises this past year
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 04:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 08:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 12:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 03:35 AM
