Old Dec 31, 2012, 05:49 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Originally Posted by ak79 View Post
I felt as if my x2 3.8 flew better than my 3.5, almost identical settings. So I checked CG's again and the 3.8 is at 123, where the 3.5 was at 118. So I think Web is right on the CG thing, for my tastes anyway.
I was able to shift my 3.5 CG back to 121 with a lighter fuse harness, but I will have to add tail weight or ditch my switch to do it without adding weight. Looking forward to flying them back to back soon.
AK, how about trying the 3.8 with the 3.5 stabs. See where the new cg is (I would recommend 118-120). I would love to hear your flight reports on this setup.
To date, I have only read from Webbie on his experience, but I think he had the cg far too forward at the time he tried it to get best use out of it.
Thanks.
fnnwizard is offline Find More Posts by fnnwizard
Old Dec 31, 2012, 06:17 PM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Thanks.
is there a 4th set of stabs out there or what ?
I have the molded set that came with my 3.5 - I have a molded set that came with my 4.0 - I have the foam sets from the SL series for the WC - those are the same size (PLANFORM) as the 4.0 -
So is there another size just for the 3.8 because I was not aware of that.
webbsolution is offline Find More Posts by webbsolution
Old Dec 31, 2012, 06:32 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
No, just the original 3.5 stabs which is the one I always refer to as the smaller stabs.
Old Dec 31, 2012, 07:00 PM
ak79 is offline
Find More Posts by ak79
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
I may try the smaller stabs on the 3.8 next time out. But then I won't be color coordinated.
ak79 is offline Find More Posts by ak79
Old Jan 02, 2013, 12:18 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Ok, finally had some time to work on my fuses and I am thinking about this mod.
Using just a kevlar string in the pushrod guide to actuate the Hstab for up and an extension spring for down.
It looks to save a net of 12g of which most is towards the rear of the fuse.
The srping pulls about 8oz of tension on the ele servo in neutral and 12oz at full up ele so the servo works all the time. So far that is about the only negative I can think of.
Old Jan 02, 2013, 04:33 AM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
Pull-spring works well in DLG but I'm not sure I would use it in an F3J model, the loads during an aggressive launch might mess up your launch trim.
If you do decide to try pull-spring, use a very strong spring, you can add a counter spring on the servo side to balance the load on the servo so that no force is applied on the elevator servo at the neutral position. I've use this with great success in DLG when a stronger spring was needed. This will also reduce power consumption and prevent the servo from heating which will extend the life of the servo etc.
roydor is online now Find More Posts by roydor
Old Jan 02, 2013, 07:27 AM
Kiesling is offline
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Tuan,
From an engineering perspective, I don't see this as being worth the risk to save 1/3 of an ounce. If you really want to save some weight, consider building a lighter stab. The big solid core stabs Nan made for the World Championship models weigh around 30-35 grams. Bagged 3.5 size stabs could be lighter if done right. Depending on how much nose weight you have, this could knock off a full ounce or more. Much better return on investment with lower risk IMO.
Anyway, the stock models I think are light enough as is.
Tom
Kiesling is offline Find More Posts by Kiesling
Old Jan 02, 2013, 10:55 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Originally Posted by Kiesling View Post
Tuan,
Tom
Happy New Year Tom!
Yeah, you are probably right. I am "thinking out loud" about this mod because the way the linkage/stab is setup, it is very condusive to the spring thing.
I am definitely looking at the possibility of lighter stabs too. Hmm.. what if both were done .
Originally Posted by roydor View Post
... you can add a counter spring on the servo side to balance the load on the servo so that no force is applied on the elevator servo at the neutral position. I've use this with great success in DLG when a stronger spring was needed. This will also reduce power consumption and prevent the servo from heating which will extend the life of the servo etc.
Great idea, thanks Roy!
Old Jan 02, 2013, 02:55 PM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
You'd need tail weight to balance it....
satinet is online now Find More Posts by satinet
Old Jan 03, 2013, 01:58 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
I think we'll be alright, I noticed on the current fuses, there is very little nose weight (lead shot) built in so not much work to dig em out if needed. If that is not enough, I'll move the battery back.
So why am I oing this? Well, the biggest reason is to get rid of any slop in the stab linkages. I tested the setup last night and have 100% faith in it.
The stab on the X naturally wants to deflect down in every case due to the cg of the stab behind the pivot (and to a slight degree the pivot being in front of its a/c) and the added weight of the connecting rod on the bellcrank. So, if the spring breaks in normal flight, I am sure the plane will still be flyable and landable.
I can only imagine the response from ele input will be better and if I can throw on lighter stabs from the factory (or another source) it would be amazing... provided your ele servo has capable resolution .
Old Jan 03, 2013, 02:13 PM
ak79 is offline
ak79's Avatar
Joined Apr 2006
Yes but the down side is you will have to butcher a fuse to set it up.
Old Jan 03, 2013, 02:46 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Yeah, you do have to do some minor surgery. 10 minutes top if doing precision work, and maybe 3 minutes butchering .
http://static.rcgroups.net/forums/at...%20details.jpg
Old Jan 03, 2013, 02:56 PM
Kiesling is offline
San Diego
Joined Aug 2004
What if the pull cord breaks? Probably not likely, but something to think about.
I also wonder about the flutter response of such a soft system.
I also wonder about the power of down input - especially at full down. It would suck to soften the down response when you push into the bucket before the zoom.
I know you're going to do it anyway but I'm still not sure what problem it will solve (the linkage on my Xplorer stabs is plenty tight).
Let us know how it goes!
Tom
Old Jan 03, 2013, 03:35 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You will save more weight by simply ripping out the (IMO heavy-ish) stock pushrod housing and replacing the whole shooting match with some etched teflon tubing and a small-ish diameter CF rod (maybe .050"?)...
If you want to run a light spring also, then you will eliminate any possible (but likely improbable) double centering, and STILL have the capability of pushing with the linkage if the spring ever comes loose or breaks.
My 2 cents.
R,
Target
target is offline Find More Posts by target
Old Jan 03, 2013, 03:56 PM
tewatson is offline
Find More Posts by tewatson
Team JR Air
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
+100. This is a high-risk, very low-return modification (I would even argue that someone flying a properly set up stock plane and one with this setup could not feel a performance difference, in any way). In addition, most of the fields we fly in SoCal are surrounded by residential areas. I would hate to see a plane go in to one as a result of a quest to drop a few grams from an 1,800 gram airframe.
Tom
tewatson is offline Find More Posts by tewatson
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 04:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 08:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 12:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 03:35 AM
