Old Oct 28, 2012, 10:04 AM
freddan2244 is offline
Find More Posts by freddan2244
Joined Mar 2011
Originally Posted by Tuomo View Post
The behavior you describe is like elevator stalling (inverted) in slow flight. This can happen with very forward CG in slow speeds. Though to my experience Xpolorers are not prone to this. You must have an extremely forward CG?
Xplorers seem to fly fine with CG from 115-130mm. I think Dave's recommendation is the middle of the road solution. One might also want to use different CG in light wind plane and strong wind plane - elevator trim and requirement for stability is different.
Calm autumn days are technically good fro trimming, but to get the plane really trimmed you must fly it in all conditions. It takes plenty of work to get a F3J plane fly well.
Well, I'm no expert by I think that when I did the first couple of hand-launches with a slightly forward CG, probably around 115 to 120mm, the plane tended to need much more elevator input from me to keep the plane from nosediving after the initial 'apex'. Not sure why it tended to pitch up more in the beginning with a forward CG, maybe it was I being a bit 'rusty' in tossing gliders thus throwing it more upwards than I should have??? I checked to see where the CG actually is right now and found that it is around the 125mm mark. With the stab at zero degrees to the wing it seems to fly quite good 'hands-off' at that CG.
Then again, I have only tested it in 'normal' mode so far and you guys are right in that it needs to be trimmed differently (with regard to decalage angles) in the other modes. I figure that if I get it trimmed properly in one mode at a time it will be easier to keep track of any changes I make and their respective effect, right?
freddan2244 is offline Find More Posts by freddan2244
Old Oct 28, 2012, 02:02 PM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
The event of a hand toss as a test bed for CG "sweetness" might be less than desirable. I only use hand tosses for elevator initial trim just to make sure there is nothing rossly out of whack. Then I get it into the air and try to abserve the CG ataltitude.
I dont think im alone here.
webbsolution is online now Find More Posts by webbsolution
Old Oct 28, 2012, 03:00 PM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
+1
Hand tosses are only good for a quick sanity check.
I have no idea how one can make a solid judgment from a hand toss, I am generally planning the landing 2 to 3 seconds after the toss by starting the flare or considering whether I have enough altitude or speed to risk a turn to land closer to myself.
Also, with the model moving away from me itís difficult to judge the airspeed to get a good trim point.
Unless you thermal out from the hand toss you arenít going to get enough air time to trim the model.
At the very least make a short launch to 50 meters to get some air time and properly trim the model and fly it.
Also do a couple of tight turns to push the model to the edge.
roydor is online now Find More Posts by roydor
Old Oct 28, 2012, 03:09 PM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by roydor View Post
+1
I have new plane waiting for test flying. No question, I will do the first flying session with bungee. Bungee launch is quite safe even if elevator setting is not spot on, just have your right hand quickly on the stick. However, this time I maybe do a hand launch for testing since this is the first light(ish) Xp2 for me
Tuomo is offline Find More Posts by Tuomo
Old Oct 30, 2012, 10:59 AM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
They've gone and floaterised me. And cut off the nose
3.8m standard layup (spread tow). Electro fuselage.
Certainly light, but not the quality I would expect for a similarly priced f3b model, in some areas, to be honest.
satinet is online now Find More Posts by satinet
Old Oct 31, 2012, 08:11 AM
F3B
satinet's Avatar
Joined Sep 2006
weights:
centre panel: 569g
left tip: 257g
right tip: 255g
tails: 53g
joiners: 42g
Fuselage (inc bolts): 284
Total: 1460g before build.
Old Oct 31, 2012, 09:44 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
What sort of motor / prop / ESC are you going to fit?
Shedofdread is offline Find More Posts by Shedofdread
Old Oct 31, 2012, 10:09 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by satinet View Post
weights:
centre panel: 569g
left tip: 257g
right tip: 255g
tails: 53g
joiners: 42g
Your wing weights are within 2g tolerance to my spread tow 3.8
I am sure that in F5J fuselage you could safely use foam tail, thus saving some weight - if you have a light motor.
Old Oct 31, 2012, 10:19 AM
F3B
satinet's Avatar
Joined Sep 2006
I have this motor in mind:
http://www.reisenauer.de/artikeldetails.php5?aid=1437
I guess 18x10 or similar. Esc - nothing in particular in mind. 70amp or so. Space isn't that tight in the fuselage. 3s Lipo I think.
Old Oct 31, 2012, 10:22 AM
F3B
satinet's Avatar
Joined Sep 2006
It's pretty light already.........!
Old Nov 02, 2012, 07:46 AM
Joined Mar 2011
+1
I will fly it off a high-start to play some more with the CG and other settings...
Considering that I set the stab-decalage first and only then set the CG, I think I achieved what I set out to; Get the CG to somewhere reasonable for the decalage-angle I set. I know this may be very unorthodox method though I know I am not the first one to try it. So all in all we can consider what I did with a few hand tosses to be 'sanity checks' with regard to the CG as opposed to decalage... When the CG was too forward the plane needed some up-trim to fly at a reasonable glide-path, after I had shifted the CG back it was flying a bit fast but with a more reasonable glide-slope angle.
That being said, I realize I am nowhere near finished trimming the plane or setting the CG. I did this so that I have a better idea of where to start when I have finished with all the little details on the plane like something to hold the canopy in place, some better servo-plugs that I can install in the joint between the wing panels and also the installation of multi-locks for the wings...
Old Nov 02, 2012, 07:56 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
As long as CG is even remotely sensible, GC position has only very marginal on performance. You just have to adjust elevator accordingly... What we are talking here is handling. Everyone has his own preferences. You might also want to have slightly change CG according to weather.
Setting CG is easy. Have it somewhere and go flying. Add weight to nose or tail, just tape lead outside fuselage. When you are happy come home and finnish nose weight installation.
I have a positive problem with my foam tail Xp2. It balances at 120mm with 1400mah nimh rx pack. If I want to get CG behind this position, I need smaller battery.
Old Nov 02, 2012, 08:41 AM
roydor's Avatar
Israel
Joined Nov 2006
I have never measured my decalage, it is probably the last thing that concerns me in a model.
I balance my models to a safe forward position and start flying them. I add or take off nose weight and retrim the elevator as needed until I get the model to behave to my liking.
I will always prefer handling over a theoretical 5 seconds on a "temperamental" model.
Only good handling can give you the ability and confidence to take a low thermal at a distance.
With different people having different abilities, handling becomes subjective and so everyone needs to choose how stable or unstable is good for them.
I suggest you don’t force the decalage, try it, but if it doesn’t fly well enough then change the decalge as needed.
Old Nov 02, 2012, 08:51 AM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Tuomo, I had to switch to an 850 mah Life pack to get mine to CG, and it's still too stable.
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Nov 02, 2012, 08:57 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
New Zealand, Canterbury, Akaroa
Joined Sep 2008
cough cough ..... vixen. cough splutter ...
AlpineDSacro is offline Find More Posts by AlpineDSacro
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 05:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 09:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 01:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 04:35 AM
