Old Sep 30, 2012, 04:48 AM
freddan2244 is offline
Find More Posts by freddan2244
Joined Mar 2011
Thanks, I think I got it to work, though I filed a small arc into the clevis so it sort of reaches around the wiper. I got the aileron travel I expect to use and then some... Everything beyond 30-35 degrees is too much, right? If I need more than that I think I am doing something wrong... I know it depends on ones flying style but there has to be some limitations where deflection angles just creates too much drag to be useful, am I way off on that?
freddan2244 is offline Find More Posts by freddan2244
Old Sep 30, 2012, 09:41 AM
Joined Mar 2011
What is a good starting point for the CG?
Old Sep 30, 2012, 10:16 AM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
125 - you will likely feel like it gets really good there but you will find a lot of pilots reporting it gets even better at 128 - 131.
I am using the molded stab on a 3.5/8 x2 variant at 126 right now and its rock solid. If I use the larger stab (4.0 area size) im sure it would be fine al the way back to 131 + but ive not gone that far back because it would require adding tail weight - you will likely hear form the US team members on that CG range.
webbsolution is online now Find More Posts by webbsolution
Old Sep 30, 2012, 10:19 AM
Joined Jul 2007
Originally Posted by ak79 View Post
Also if you use the standard clevis's you must remove enough of the wipers to be able to spread the clevis and attach them or remove them. If you don't do this, and you try to force them on you will shatter the wipers.
I like to use MP jet clevis with pins so I can avoid making the slots in the wipers to wide, and the clevis's are much easier to attach and remove.
Nice and clean -
DW
Old Sep 30, 2012, 04:43 PM
ak79 is online now
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
I fly mine at 119, it is a 3.5 X2, the weight is down to 59oz now. I find with a further aft CG and the plane being so light it gets way to wobbly and bobbly. I always have to push down to keep it tracking, especially if there is any breeze. I prefer to be nose heavy with this model.
ak79 is online now Find More Posts by ak79
Site Sponsor
Old Sep 30, 2012, 11:54 PM
DrFragnasty is online now
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
59oz is 1672g.
I had to do a double take; that's amazing. A full 600g (21oz) lighter than my full-carbon X1.
I was debating whether to get the 3.8 X2 or the 3.5 X2.
I prefer an agile glider. Anyone flown both the X2 3.5 and X2 3.8 and can comment on their handling differences? Is it worth getting the extra span if the 3.5 is so light?
Chris.
DrFragnasty is online now Find More Posts by DrFragnasty
Old Oct 01, 2012, 12:44 AM
Boagy is offline
Find More Posts by Boagy
mmmmm....BEER
Launceston, Tasmania
Joined Jan 2010
Originally Posted by DrFragnasty View Post
59oz is 1672g.
Chris.
Go on Chris........buy both! You've got bucket loads of money anyway.
Boagy is offline Find More Posts by Boagy
Old Oct 01, 2012, 02:40 AM
Thermal Wrangler
Launceston Tasmania
Joined Mar 2004
mortgage vs X2
Doh!
Old Oct 01, 2012, 11:17 AM
Joined Jul 2007
59oz is 1672g.
Chris.
The factors in the air to me at least are negligable - they both turn really well and are agile enough to hand launch into light lift and get to spec alt.
If you only plan on buying one then go for span - You will not regret it
Old Oct 01, 2012, 01:30 PM
ak79 is online now
Flightcomp.com
ak79's Avatar
Joined Apr 2006
I'm just finishing my X2 3.8 so I can try to make some comparisons this weekend.
Site Sponsor
Old Oct 01, 2012, 03:46 PM
SoaringDude is offline
Find More Posts by SoaringDude
Team Hello Kitty
SoaringDude's Avatar
near Sacramento, CA
Joined Aug 2010
On CG, from posts here the X2-3.8 seems to fly well in the 120-130 range. I'm curious how the X2's CG settings compare to the X1-3.8ST? With a different wing planform I'd expect different CG settings for similar stability but was curious by how much.
Has anyone done dive tests to confirm what the X2-3.8 does at 130mm? Neutral stability?
Chris B.
SoaringDude is offline Find More Posts by SoaringDude
Old Oct 01, 2012, 10:27 PM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Russia, Tomsk Oblast, Kargasoksky District
Joined Sep 2008
hhhmmmmm X2 3.8 ??? I also feel like Homer
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Oct 01, 2012, 11:56 PM
ak79 is online now
Flightcomp.com
ak79's Avatar
Joined Apr 2006
Well I can say that red paint is heavier than white! My 3.8 red center panel is about 1.5 oz heavier than the white 3.5. Same part, and the 3.8 has lighter wire in the harness.
Total flying weight of my X2 3.8 is 64oz. I would guess if it was white it would be 61 or 62.
Site Sponsor
Old Oct 02, 2012, 01:34 AM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Hmmm..... I have been told that white paint is heavy???
Me and my friend just got orange and red 4 meter Xp2s. There was slight difference in center panel weight between the two planes, but otherwise weights are within 2g difference per part. Difficult to say if color has any effect on final weight. Perhaps they just use same amount of all paints. Other colors may cover the structure better than others.
If you are worried about weight, why not order naked carbon?
Tuomo is online now Find More Posts by Tuomo
Old Oct 02, 2012, 01:46 AM
ak79 is online now
Flightcomp.com
ak79's Avatar
Joined Apr 2006
I'm not worried about weight with these. I think any Xplorer under 70oz is going to fly fine.
Just some observations, I would have rather had white, but none in stock at the time. You have a X2 4000? I guess they have released them finally!
I would never get naked carbon, for me it is not worth the hassle of keeping the plane cool and warping parts, etc... it may look good, but in the end a few grams of paint are not worth the trouble in my opinion.
I do want the new style fuse with paint and kevlar nose! That is what I would want in my next plane. I would like the bigger rudder, but I don't want the DLG stab's either, I want regular ones.
I think silver would be the best choice for lowest amount of paint to cover the structure. I was thinking of special ordering a silver plane.
Site Sponsor
New Product 0.9g Retracts Mk.II *NOW LASER CUT* Yellow Baron Scratchbuilt Indoor and Micro Models 2 May 29, 2012 04:38 AM
Wanted Hangar 9 Spitfire MK II 60 Parts cessnajfb Aircraft - Fuel - Airplanes (FS/W) 2 Mar 11, 2012 08:47 PM
Sold *Price Reduced* Saito FA-45 MK II sscherin Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 11, 2012 12:06 PM
For Sale: Carl Goldberg Classic Falcon 56 mk II and Skylark 56 mk II kasra Aircraft - Fuel - Airplanes (FS/W) 2 Nov 22, 2004 03:35 AM
