Old Apr 18, 2012, 06:46 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
inlet lip radius
unclecrash is offline Find More Posts by unclecrash
Old Apr 18, 2012, 07:22 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
best would be about the size of your little finger ..but somewhere @1/4" to 3/8" would work too . look at the BVM sport jets they had really good inlet duct radii.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 18, 2012, 08:29 PM
unclecrash's Avatar
white lake michigan
Old Apr 19, 2012, 01:33 AM
Aethertek is offline
Find More Posts by Aethertek
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
K~
Aethertek is offline Find More Posts by Aethertek
Old Apr 19, 2012, 02:25 AM
EJETS-II is offline
Find More Posts by EJETS-II
TeamSiam
Graz
Joined May 2007
Originally Posted by Aethertek View Post
K~
Hi, please remember that the drawing is only valid for a VDE-Inlet lip, used on the test bench to be comparable with other tests from other brands.
The tip to use around 5mm radii at an inlet at the fuse is right.
The drawing above is also not good for an OPEN DUCT SYSTEM (no place for it in the fuses). Here you can use an laying ellipsoid shape, 10mm and 15mm radii.
BR, Rainer
www.ejets.at
EJETS-II is offline Find More Posts by EJETS-II
Old Apr 19, 2012, 09:13 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
its easy just make the lip as big as you can and still make it look good. the real truth is air can only bend around a curve of a given size depending on the speed it is moving. and no model will have a intake lip radia that will work at max power in most cases..so just make it as nice and round as you can and live with it...it really only makes a big diff for take off run once your flying there will be little speed loss. infact if done correctly the sharp intake will be faster as high speed
Old Apr 19, 2012, 11:22 AM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
Make it as big as is practical and scale. A sport model designed from the ground up may very well have 1/4" plus radius on the inlet lips. I have flown 90mm size rigs with as little as 1/16" radius. The smaller radius will get you more noise and turbulence at lower speeds. One you get up to flying speed this goes away. But it will return as the jets forward speed is reduced and then power is applied. You will lose some take off thrust with the sharper inlets also. I try to go a minimum of 1/8" radius on my scale 90mm stuff.
Doug Bateman is offline Find More Posts by Doug Bateman
Old Apr 19, 2012, 10:34 PM
unclecrash's Avatar
white lake michigan
Old Apr 20, 2012, 09:40 AM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
if your after speed you need to remove the cut out infront of the intake(naca shape) it will cause too much turbulance intering the duct
Old Apr 20, 2012, 01:56 PM
Ron Pogue is offline
Find More Posts by Ron Pogue
United States, AZ, Phoenix
Joined Jun 2002
So, let's see ~
A large radius is best for low speed acceleration. A sharp or small radius is good for high speed.
Electra has a short radius on the outside of the inlet, that grows to a larger radius as it goes towards the inside diameter. Best of both worlds??
Ron Pogue is offline Find More Posts by Ron Pogue
Old Apr 20, 2012, 02:05 PM
Joined Dec 2004
You are describing an elliptical shape. That is the ideal cross section shape of the intake lip. But i have done plenty with just a circular shape with a certain radius. Fairly easy to do if you are just filling and sanding.
Old Apr 20, 2012, 02:11 PM
Joined Jun 2002
Yes on elliptical shape.
Old Apr 20, 2012, 06:50 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
I don't agree with this statement at all. not trying to start anything, I just do not agree with this and neither would the designer of it. the whole idea of the NACA inlet is to take advantage of almost zero losses due to the physical design. the whole idea of the NACA inlet, is that the walls of the duct and the ramp angle create a swirling vortex that discard the sluggish and turbulent boundary layer. this allows better quality air to be drawn in and allow pressure recovery inside the duct. the reason I designed them into the Chimera was for two reasons. firstly, it decreases total frontal area by having some of the inlet area to be depressed into the fuselage. secondly and most importantly, it is for pressure recovery. as you know, there are two types of inlet. pitot style and NACA style. pitot style recover energy ahead of the intake lip, which is why a properly shaped inlet lip is so important. the NACA inlet recovers its energy inside the inlet, by using generated vortex to draw in a higher energy column of air. this has a sort of ram effect. this hybrid inlet was designed to get the best of both worlds. good ram pressure of the pitot inlet, with boundary layer ejection for high speed flight.
the whole thought of this inlet drawing in turbulent air goes against everything the designer of the inlet intended as its purpose. it was designed to do exactly the oppposite.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Apr 20, 2012, 07:02 PM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
Rich, can you post a drawing of a pitot inlet Vs. a equivalvent NACA inlet please?
rfodor is offline Find More Posts by rfodor
Old Apr 20, 2012, 07:05 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Yes but that is not a NACA duct..they were tried on inlets for full size and it did not work then with real naca designers doing the work....
Wanted 70mm fan inlet lip/inlet ring PaulDaniel Aircraft - Electric - Jets (FS/W) 2 Dec 10, 2011 06:39 PM
Discussion Good Cheater Ring?/inlet lip Ron101 Electric Ducted Fan Jet Talk 3 May 11, 2008 04:30 PM
WTB: Midi inlet lip.... foss1997 Electric Ducted Fan Jet Talk 1 Jan 02, 2005 12:02 AM
EDF inlet lip DaleM Electric Ducted Fan Jet Talk 2 Feb 28, 2004 06:13 AM
Help with inlet lip/fan shroud on Alpha Jet buzzfly Electric Ducted Fan Jet Talk 5 May 02, 2003 02:10 PM
