I guess you have made no attempt to look this up? Use the search, and read, read, read. Try here. http://www.bing.com/search?q=thrust+...11&sp=2&sk=AS1
Joined Mar 2012
Basicallly its a tapered tube that runs from the back side of your EDF unit to the exhaust portion of your aircraft. Ive made them extend from the back of the exhaus up to an inch, or flush with the opening, or even just inside the opening. Just to experiment with the results.
There are a wide variety of materials that can be used. But from what Ive seen and found out myself is that mylar works very well. But dont want to use the super thin stuff. I believe what I use is .005-.010 transparencie sheets that can be found at your local office supply store. Now as for the dimensions that are required that is the trick. And it requires a little math to do which I suck at. But there is a program for it. http://www.rcgroups.com/forums/showthread.php?t=1160865 Click on that link then you'll have to do some poking around. when you find the excell spread sheet input the information it asks of you. This is what I use and it works pretty good. |
Here's the free app for making and printing a flat pattern for your thrust tube.
www.pulserate.com You need to ad 1/4" to the length (for overlap when taping together with shiny Scotch tap on the insdie and out side) and add 1/4" to the "EDF" end for slipping over the EDF and taping. We use .005 thick Acetate ("mylar") for jet's up to 100mm EDF size. Here's a few pics of the process. The tube ends about flush with the end of the models exhast pipe (or up to 1/8" beyaond if you like. Steve's FSA calculator is great.
| Thread Tools | |
| Discussion Thrust tube questions for the Guru's | SilverState RC | Electric Ducted Fan Jet Talk | 4 | Apr 05, 2012 01:06 PM |
| Help! thrust tube | ian.c | Electric Ducted Fan Jet Talk | 3 | Mar 31, 2012 08:44 AM |
| Wanted WeMotec Midi Fan 10" thrust tube | hole digger | Aircraft - Electric - Jets (FS/W) | 0 | Mar 17, 2012 01:50 PM |
| Question Anyone vacuum forming thrust tubes? | boredom.is.me | Micro EDF Jets and Power Systems | 7 | Mar 11, 2012 10:16 PM |
| Mini-HowTo How To Design a Custom Thrust Tube (Tailcone) for your EDF | cutty01 | Electric Ducted Fan Jet Talk | 14 | Sep 28, 2011 06:20 PM |
