Old Apr 17, 2012, 08:44 PM
omer921 is offline
Find More Posts by omer921
The trees are my hangar
omer921's Avatar
United States, NY, Queens County
Joined Dec 2010
Whoops!
Another FPV newbie story
Went to do my third FPV flight with my SkyWalker today. The forecast said winds around 13 mph so I thought to my self that it would not be a problem for the SkyWalker. I took off checked that the RTH was working and began my flight. I've only been out 700 meters so I decided to fly 1km. I reached 1km woohoo! I turn on RTH and it starts to come home. Around 600 meters the video goes white. I asked my spotter if he saw the plane. After a few seconds my spotter saw the plane it was a spec in the air. He slowly managed to bring it down but the plane was extremely hard to handle. It seemed very nose heavy and we still had no image from the video transmission. Barely missing the trees the Skywalker touched down unharmed. We went to inspect the plane, both the motor and the camera were gone. They fell off the plane in mid air . I think I mounted the motor wrong. But I still can not figure out how the camera fell off.
omer921 is offline Find More Posts by omer921
Old Apr 17, 2012, 08:52 PM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Wow!
You are one lucky guy. The motor broke off mid flight and it still came home?
BushmanLA is offline Find More Posts by BushmanLA
Old Apr 17, 2012, 08:57 PM
omer921 is offline
omer921's Avatar
Joined Dec 2010
Yes I feel very lucky but i'm really shaken up, can't wait to get up in the air again.
Old Apr 17, 2012, 09:21 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Yeah, I used CA to glue all of the parts of my SW except the motor
mount because when I tried with CA it broke off in a minor crash involving a
bench. Now with the epoxy it's on there really good.
I suspect that when the motor shook its way off the mount it rattled the whole
plane and since your camera was mounted so high up on that P&T it shook it
off as well.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Apr 18, 2012, 12:07 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i used 5min epoxy under the motor mount with screws going into the foam.... then I used hot glue around the edge of the motor mount..
I used a Turnigy 3530 motor with out any issues
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 18, 2012, 12:14 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The motor mount on my SW is held on with ZAP thick CA and has no extra screws/pegs/whatever
going into the foam. The mount itself has withstood crashes that have ripped the entire
back of the wing pylon off. If you had so much vibration that it shook both the motor and
the camera off the plane, then something is seriously out of balance.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 18, 2012, 12:39 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Did you have any vibration when you were flying with your goggles/monitor ? Did you record the footage? If you did you should wack it up
Locko is offline Find More Posts by Locko
Old Apr 18, 2012, 08:40 AM
omer921 is offline
omer921's Avatar
Joined Dec 2010
There were no vibrations during the flight but I will definetley check balance issues.
Old Apr 18, 2012, 08:46 AM
BushmanLA's Avatar
Joined Dec 2005
gorilla glue would probably be better for the motor, it isn't as brittle as CA.
I mounted mine using a standard X shaped motor mount cut to size of the wooden disk. It is screwed on with extra long screws that penetrate into the foam, then I put glue on the wood and protruding screws and stuck it in.
When it crashed the big block of foam came off with it and that's all you can ask for
Discussion Yet Another Newbie 5.8GHz Setup - A Catalog of Statics ffranck FPV Talk 202 Feb 13, 2014 09:50 AM
Discussion Another hobbyking suck story spacecase Multirotor Talk 23 Apr 17, 2012 10:31 AM
Discussion Newbie Questions and Crash Story magudaman Multirotor Talk 8 Apr 13, 2012 10:22 AM
Discussion CNN front page story on FPV... replayreb FPV Talk 2 Mar 16, 2012 12:21 AM
Discussion Newbie's First 3 flights story...this is good... wootenelli Electric Plane Talk 6 Dec 05, 2011 08:38 PM
