Old Apr 17, 2012, 05:21 PM
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Can Eagleeyes be used with another OSD
such as the Skylark Tiny 2?
D
daign is offline Find More Posts by daign
Old Apr 17, 2012, 09:31 PM
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
D
If you mean for data and antenna tracking and data for a ground station I doubt it very seriously. The video diversity function may work but that is all. The Eagle Eyes system requires the data info to be embedded within the video signal. The Tiny from looking at the makers website simply overlays the info on the video signal and does not work with the makers own antenna tracker either.
They have another product specifically for use with their own antenna tracker and it uses the audio channel for sending data to the tracker. Totally different and incompatible designs.
Rob
camship is offline Find More Posts by camship
Old Apr 19, 2012, 03:46 PM
daign's Avatar
Joined Feb 2011
Rob
thanks. looks like I gotta sell my Skylark and buy another eagletree combo.
Old Sep 10, 2012, 08:36 AM
"Watch this!.... Oh crap"
jhebbel's Avatar
United States, FL, Seminole
Joined Jan 2012
D
I doubt it as Eagle tree embeds their telem in a separate level of the video stream whereas others use serial over audio, The video stream is a higher fidelity and allows faster transmission of more data which is why eagle tree uses it. So i highly doubt eagle tree products are cross compatible.
jhebbel is offline Find More Posts by jhebbel
Discussion Can the Turnigy 9x with FrSky DIY kit be used with simulator genrlst Radios 2 May 23, 2012 01:19 PM
Discussion Can a RX battery be used in combination with a BEC? twinster2 Power Systems 8 Mar 23, 2012 04:52 PM
Discussion Can opto-isolators be used to get RSSI from RX to OSD at different ground potentials? cmanley_nl Video Piloting (FPV/RPV) 0 Jan 31, 2012 01:53 PM
Discussion can Blade RTF be used as BNF with Spektrum DX6i? azjerry Micro Helis 1 Sep 28, 2011 12:30 AM
Question Can a Gas engine Propeller be used with a Electric Motor? DL8698 Beginner Training Area (Aircraft-Electric) 18 Sep 23, 2011 10:58 AM
