Old Apr 17, 2012, 03:14 PM
Capt. Kelso is offline
Find More Posts by Capt. Kelso
Capt. Kelso
Capt. Kelso's Avatar
United States, FL, Fernandina Beach
Joined Dec 2011
First time set-up help, Futaba 6EXP, can get things to work
This is my first RC Plane set-up. Bought a Futaba 6EXP with R168DF Receiver
(#42 Crystal),
4 Futaba servo's S3004. Charged the battery pack for both the radio and receiver, plugged everything in according to the manual, set PCM, turned on the receiver switch and get no response to the servo's.
Have been working on it for two days now, reset, recharged, what am I doing wrong?
Appreciate the help!
Capt. Kelso is offline Find More Posts by Capt. Kelso
Old Apr 17, 2012, 04:00 PM
crazy8s is offline
Find More Posts by crazy8s
crazy8s's Avatar
Pennsylvania, USA
Joined Sep 2008
(#42 Crystal),
You have an FM receiver but you have the transmitter set to PCM mode. That setting will only work with a PCM receiver. Reset the transmitter to PPM and you should be fine!
crazy8s is offline Find More Posts by crazy8s
Old Apr 17, 2012, 04:15 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
PCM receivers have a "P" in the name like R148DP, R168DP. Yours isn't one of those so it won't work with the Tx set to PCM mode.
BTW make sure you have a Dual Conversion crystal in the receiver....that's what the "D" in the name tells you .
Steve
slipstick is online now Find More Posts by slipstick
Old Apr 18, 2012, 03:33 PM
Capt. Kelso
Joined Dec 2011
Thanks for the help, got it working!
Discussion Wimped out on first time trying FPV on my hexacopter, any help to get over the fear jasper7821 FPV Talk 13 Mar 28, 2012 07:15 AM
Discussion Eurgle 9x - First time setting up neo__04 Radios 2 Mar 19, 2012 07:45 AM
Discussion Help with my first e power set up. Panther Power Systems 1 Mar 12, 2012 03:06 PM
Discussion setting up a giant for the first time Airplanedude Giant Scale Airplanes 3 Dec 06, 2011 12:13 AM
Discussion First time fpv1 need help with set up. ROD GARCIA FPV Talk 25 Jun 26, 2011 06:23 PM
