Old Apr 17, 2012, 09:42 AM
coaxialnewbie is offline
Find More Posts by coaxialnewbie
Adelaide, South Australia
Joined Jun 2010
Newbie Q's on flying saucer
Hi, a friend of mine is doing his first year in aerospace engineering. He gets to keep a handful of motors and wanted to build a toy single-rotor or contra-rotating prop flying saucer. This project strictly isn't remote control but I just want to ask some questions about the power system and pointers to the right direction.
The motors are brushed and was bought from http://www.jaycar.com.au/productView...SUBCATID=983#1.
The propellers are GWS DD 7x3.5. We used a static thrust calculator and got that in order for one prop lift 240g, it needs to spin at 9000RPM.
We are using non-rechargeable batteries and not lipo. It's going to be tethered so carrying the batteries around in the backpack would not be the problem.
I read on a lot of pages that the RPM is controlled by the voltage of the battery, but from trial and error, I've found that with a new battery (some unknown brand) with 10.4V (multimeter) spins the prop slower than using an old 9V (measured to be 8.4V) Duracell battery. The load is the same. So does the voltage or current control the RPM of a motor?
coaxialnewbie is offline Find More Posts by coaxialnewbie
Old Apr 17, 2012, 11:20 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
The actual voltage UNDER LOAD, i.e. while the motor is running, controls the speed. So you need to measure those voltages WHILE the motor is running not before the battery is connected to anything.
All batteries will drop some voltage as you load them up. Different batteries drop by different amounts e.g. if you are trying to pull too much current out of the battery its voltage will drop a lot.
Steve
slipstick is offline Find More Posts by slipstick
Old Apr 19, 2012, 02:17 AM
Joined Jun 2010
Thanks. We just did a quick test and the battery is a 4.5V but the motor under load is pulling less than 4.5V. Is there a way to force the battery to pull more voltage and increase the RPM?
Old Apr 19, 2012, 03:15 AM
Staffs, UK
Joined Nov 2003
Not with the same load on the motor. If you want more voltage use a battery that starts off with a higher voltage or a bigger battery that keeps its voltage better under load.
Alternatively using a smaller propeller will be less of a load and so will not drag the voltage down as much. That should give you more RPM but probably with less thrust because the prop is smaller. It all depends what you're actually trying to achieve.
Steve
Old Apr 19, 2012, 09:19 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Steve
The internal resistance of the battery is what reduces the effective voltage at the terminals of the battery as you draw more current....
This is one reason LiPo's are so well liked - they typically handle pretty good (relatively speaking) current draws.
The prop will cause the current of the motor to go up based upon its load as well - do you have a way to measure the current? Maybe use a bench supply with voltage and current meters?
ScottSails is offline Find More Posts by ScottSails
Old Apr 20, 2012, 06:29 AM
Joined Jun 2010
I connected the multimeter in series with the motor and the battery. Is there a way to control the signal into ESC without using a receiver? Say if I want to have it tethered, not RC. Is there a page that tells what sort of signals get out of the receiver? Sorry if the questions sound a bit stupid.
Old Apr 20, 2012, 07:04 AM
Staffs, UK
Joined Nov 2003
Just use a servo tester. The ESC signals are exactly the same as servo signals.
Steve
Old Apr 20, 2012, 10:06 PM
Joined Jun 2010
Awesome. So with this servo tester for example, http://www.ebay.com.au/itm/3CH-ESC-S...ht_2825wt_1139, it has 3 pins, each for ins and outs. How do you connect these to the brushed motors?
I just watched a hobbyking video on a servo tester,
HobbyKing - Turnigy 3-Mode Servo Tester (4 min 52 sec)
, they still uses a ESC for the motor. So did you mean the receiver signal is the same as the servo signals? Does this mean I will still need to have brushed ESC?
Old Apr 21, 2012, 11:16 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Yes, servo tester output = receiver signal output. Wire your servo tester to ESC then ESC to motor.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Apr 24, 2012, 06:00 AM
Joined Jun 2010
Awesome, the servo testers can take in 4.8V-6V. 1 cell lipo has 3.7V and 2 cell lipo has 7.4V. So do I need to use a voltage regulator? For most inexpensive 5V regulators, they can pass through 1A maximum. I see a lot of tables and charts of motors perform at 20A, 60A, etc. If the motor does pull 20A, would it burn the 5V regulator?
Old Apr 24, 2012, 06:32 AM
Staffs, UK
Joined Nov 2003
If the ESC has a BEC then it will supply the 5V to the servo tester just the same it would have supplied the receiver.
Steve
Old Apr 26, 2012, 01:55 AM
Joined Jun 2010
Thanks Steve. Just another confusion, if I have 2 motors, would I need to connect a battery pack to each motor or is it ok to use 1 battery pack to connect to an ESC with BEC and use it to power the servo tester and the other ESC also?
Old Apr 26, 2012, 03:10 AM
Staffs, UK
Joined Nov 2003
You seem to be making this project a lot more complicated than it started off.
If the motors are brushed as you originally said then you only need one ESC to drive the two motors.
OTOH if you want to control the motor speeds separately then you will need two ESCs AND two servo testers.
In either case you only need one battery which is connected to the ESC or ESCs.
Steve
Old Apr 27, 2012, 02:44 AM
Joined Jun 2010
Ah, stupid of me I didn't know 1esc can control 2 brushed motor if they are travelling at the same speed .
Discussion SETUP Q's FOR 'SCALE STYLE' FLYING HeliGriff Scale Helicopters 11 Feb 28, 2012 09:29 PM
Discussion SETUP Q's FOR 'SCALE STYLE' FLYING HeliGriff Large Electric Helis 0 Feb 23, 2012 03:13 PM
Discussion first boat, newbie Q's 69zandar Racing Boats - Electric 38 Jan 27, 2012 07:49 AM
Help! Few newbie's question on flying wings? victor.. Flying Wings 4 Jan 15, 2012 09:14 PM
Question Voltage regulator for ignition? -Newby Q's Doubledog Engines 11 Dec 26, 2011 04:53 PM
