Old Apr 17, 2012, 09:05 AM
skypimp7572 is offline
Find More Posts by skypimp7572
Joined Apr 2012
power setup for skysurfer
Hi i am running a turnigy d2826/6 2200kv with a 35amp speed control and 6x6 prop and 3 cell 2200 bat. it seem that in flight wot the motor sputters the esc is somwhat warm and same with the motor it also seems under powered any suggestions thanks...
skypimp7572 is offline Find More Posts by skypimp7572
Old Apr 17, 2012, 09:32 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Too much prop... drop down to 5.5x4.5 or 6x4 at most...all you are doing is bogging down the motor and turning input power (25A-30A?) into heat. That motor is only good for around 150W-200W at most. What RPM are you getting?
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 17, 2012, 09:42 AM
Joined Apr 2012
I really do not know thw rpm but i tried a 5x5 and it does the same thing as well as a 4.5 x 4.5
is this motor a good match for this plane??
Old Apr 17, 2012, 02:08 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
The motor should be fine.
Are your electronics getting air flow? If not, that very well could be your problem.
I have a Easystar which is basically the same plane. I upgraded the system similar to yours. Everything was inside the fuse. The first couple times I flew it everything was very hot. Could not hold my finger on the ESC!
I cut a opening in the front of the canopy and cut an air passageway thru the back of the cockpit area and up and out thru the wing. Now everything stays cool.
As the others have said, a 6x6 prop is to much. I run a 6x4.
Here are some pics that show the openings.
tacx is offline Find More Posts by tacx
Discussion HK Skysurfer eq 9eagles Skysurfer eq robbe Skysurfer (eq robbe arcus airy) hamburger Electric Sailplanes 4 Mar 02, 2012 06:08 AM
Discussion For sale - 3 aircraft and a high-power EDF setup JohnAsaPrice Charlotte Area Flyers 0 Feb 27, 2012 04:31 PM
Discussion Swift 16 power setup for scale use? jimm1962 Large Electric Helis 15 Jan 13, 2012 12:08 PM
Discussion 3D Power setup for new extra 260? HELP!!! KrashTestKev 3D Flying 5 Nov 22, 2011 11:42 PM
Discussion Common Sense Check - power setup for Chrysalis EHLG TTC Electric Sailplanes 5 Oct 10, 2011 07:52 PM
