Old Apr 17, 2012, 08:58 AM
bigtruck169 is online now
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
Help!
brush 6 volts motor using lipo
hi all,
can anyone tell me how or is it possible to use lipo with 6 volts brush motor.
our club is making a fun fly/ or RC event next month and we are trying to build some RC stuff for kids to play with. We have lots of these 6 volts brush motors, mostly 450, ( size is about half our thumbs). As we all using lipos, 2 cells will be 7.4, even we put some charge and limit the run time, it will be over 8 volts and kill the motor.
I know in cars, they using 540 motor, the bigger one, we can use 2 cell without issue. what about these little 450 motors with a 6 volts limit?
thanks in advance
bigtruck169 is online now Find More Posts by bigtruck169
Old Apr 17, 2012, 09:24 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If they are that small they can't be 450..maybe 150 or 250?.... Speed 300 weighs 50g+, Speed 400 is 70g+. Voltage is not what kills motors... amps do that!
Problem with 6v motor on 2s will be premature brush wear... but if you can keep the prop/amps low enough and they'll be okay for a short time at least..
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 17, 2012, 10:25 AM
Joined Dec 2009
for a short time probably won't work for our event as we need the RC cars to survive for few hours. will it be possible to connect two brush motors in parallel to lower the amp draw? as we will be using much smaller props or we using some resisters ( or some LED lights in series) to lower the voltage from lipo 8 volts to around 6 volts ?
Old Apr 17, 2012, 07:42 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
By "short time", the Doc likely means at least a few days...not a couple of hours. In reality, how long total will the cars run?
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Apr 17, 2012, 09:07 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Putting motors in parallel won't help, as they all get the same voltage. LEDs are only good for about 0.1A, so they will burn out unless your motors are drawing very low current.
A resistor is probably your best option. You need to choose one that drops about 2V at whatever current the motor draws (eg. 2 Ohms at 1A) and an appropriate power rating (eg. 5W). Use Ohm's Law to calculate the correct value, or just try different resistors until you get 6V at the motor. Note that this only works when the motor has a load on it, but a free running 6V motor is not likely to be damaged by 8.4V (as Dr Kiwi said, it's the Amps that kill).
One advantage of the resistor over other methods such as diodes, is that if the motor is blocked then current draw and output torque will be limited. As well as reducing the likelihood of burning out the motor, it may be safer for the kids.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Apr 17, 2012, 09:49 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Run 'em 'til they drop... you may get 10 short runs, you may get 100 short runs...but I can't see several hours continuous... if that is what you need.
Old Apr 18, 2012, 08:16 AM
Joined Dec 2009
thanks for the suggestions. I will get some diodes ( radio shacks? ) I never due with brushed motor + Lipo combo when i get in hobby 2 years ago. Too bad i didn't take my high school physics seriously back in the days and hopefully i will catch up this time.
for brushed motor, if i want to run 2 motors, i can use only one esc but both motors need to be parallel or series?
we are going to build the flying cart
http://www.rcgroups.com/forums/showthread.php?t=1094114
but ours won't be flying, just running in baseball field. so CG is not important at all. The best part is to let the kids involved in making something and hopefully it will work or duct tape it again.
If anyone has any unused old radio systems ( 27mhz, 72mhz ), brushed esc or old motors, and would like to pass to next generation for one sunday afternoon fun, i be happy to take them off ur hand
mike
Old Apr 18, 2012, 07:47 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I borrowed (and slightly edited) this from another forum: (As you can see, "series" connection would resolve the problem of over-voltage... since you are concerned about using 2s (7.4v nominal) on 6v motors... but power would be seriously limited!)
***series, is running one motor after the other....The voltage is split (theoretically) equally, so you wont have full power, like you would with one motor. Say with one motor it runs off about 7 volts. With two in a series, the voltage is split, so each motor only runs off about 3.5 volts....see???
***Parallel, is running two motors side by side hooked up to the same battery. 7 volts goes through the wires on the battery, which go through the motors. If 7 volts goes through the battery wires, and the leads of both motors are connected to the battery, 7 volts now runs through the battery wire, and both the motors....you follow??? So each motor is running off of 7 volts. The consequence of this is, since two motors are running off 7 volts, the battery is using amps twice as fast.
Old Apr 19, 2012, 09:48 AM
Joined Dec 2009
base on the information from dr kiwi,
my setup will be 2 cell lipo ( full charge to 8.4) + a small resister diode to drop 2 volts to 6.4volts + 2 brush motor in parallel with brush esc.
Now another quesion, the 2 volts resister diode should soldering on the red ( +ve) wire or black ( -ve ) wire of the esc? i remember back in high school days, they did mention there is a difference to which wire for the resister for the voltage drop.
Will or should the diode get hot at all in this application?
Old Apr 19, 2012, 06:35 PM
Joined Jan 2001
It doesn't matter which lead you put the diodes in. Conventionally they would go in the positive lead, but this is not important unless the battery is also used to power some other device with a common ground.
Yes, the diodes will get hot. How hot depends on how much current is drawn and the size of the diodes. They should be rated at least 50% higher than the maximum current draw, eg. if drawing 2A (1A per motor) you should get 3A diodes (eg. 1N5402). You need 3 silicon diodes in series to drop 2V.
A problem you may find with putting diodes in the battery lead is that the ESC's LVC (Low Voltage Cutoff) operates too soon. If the ESC can be set for nicad cutoff then it should be OK, but you should check to make sure that it won't let the battery run too low.
If the LVC can't handle diodes in the battery lead then you can put them in the motor leads, but you will need to wire a Schottky diode across the motor terminals (with reverse polarity!) to handle back-emf at part throttle. A resistor would be cheaper and easier to wire in.
Old Apr 23, 2012, 12:08 PM
Joined Dec 2009
thanks all for great lecture.
Discussion how many volts can a 550 size BRUSHED motor take? big_poppa4904 Racing Boats - Electric 13 Jun 21, 2012 03:54 AM
Idea Using lipo charger to power laptop from 12 volt sammyc Batteries and Chargers 0 Apr 13, 2012 11:50 PM
Wanted Looking for new or used lipo ready brushed esc for a 480 motor Chipped Rotor Aircraft - Electric - Power Systems (FS/W) 7 Jan 16, 2012 07:33 PM
Discussion LiPo cells at 6.28 volts per cell? bionicbone Batteries and Chargers 2 Dec 30, 2011 01:57 PM
2s or 3s LiPo for 6 volt Speed 400 motor ? Armchair Bronco Batteries and Chargers 5 Jul 17, 2004 03:24 AM
