This thread is privately moderated by argo-2, who may elect to delete unwanted replies.
Old Apr 17, 2012, 06:21 AM
argo-2 is offline
Find More Posts by argo-2
Maiden>Confident>Cocky>Crash!
argo-2's Avatar
New Zealand
Joined Feb 2010
Bigbird Swept Wing
Corflute 2.4m swept wing.
Build log is at my local here: http://www.parkflyers.org.nz/modules...C&type=&mode=0
argo-2 is offline Find More Posts by argo-2
Old Apr 17, 2012, 06:50 AM
argo-2 is offline
argo-2's Avatar
New Zealand
Joined Feb 2010
Attached:
CG Calculator & Wing Loading. Wing loading is inaccurate as AUW is anticipated to be 3.1kg now.
Old Apr 17, 2012, 06:59 AM
argo-2 is offline
argo-2's Avatar
New Zealand
Joined Feb 2010
Zipped DWG file of full plane from top view.
Zipped SKP file of plane.
Old Apr 17, 2012, 10:33 AM
SCREWYFITS is offline
Find More Posts by SCREWYFITS
As SCREWY as I wanna be!!!
SCREWYFITS's Avatar
United States, CA, Livermore
Joined Feb 2011
Hey, thanx a bunch for sharing these!!!
Dirk
SCREWYFITS is offline Find More Posts by SCREWYFITS
Old Apr 17, 2012, 01:11 PM
RCSquale is offline
Find More Posts by RCSquale
Sometimes it work some don't
RCSquale's Avatar
╔mirats arabes unis, Ras el Kha´mah, Ras Al-Khaimah
Joined Oct 2010
Thanks Argo, any updates on this one? completed? Maiden?
RCSquale is offline Find More Posts by RCSquale
Old Apr 17, 2012, 03:14 PM
argo-2 is offline
argo-2's Avatar
New Zealand
Joined Feb 2010
@ SCREWYFITS - You're welcome
@ RCSquale - Far from maiden sadly. Just glued up the 2nd wing
Next up is fus which I'm thinking I'll have 6 fus-ribs (running lengthwise) and part formers crosswise. Underbody Coro skin should be ok, but top skin may need to be done in sections due to the compound curving.
Old Apr 18, 2012, 06:47 AM
argo-2 is offline
argo-2's Avatar
New Zealand
Joined Feb 2010
Hi RCS
Just looked at your blog - you've been building and flying wings for quite sometime Can you see any major errors in my design or thinking?
Also I see on your blog you built a Tuffy. That was my first build - wonderful plane that I still get a kick out of flying, even without ailerons. Here's mine before it trained me (looks a lot more weary now )
Cheers.
Old Apr 19, 2012, 03:34 AM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Argo, thanks for appreciating my blog, I missed to place many of my build and I should update when I have time
Let me sit down quitely and look more carefully into your build and if ever I see something that might raise question I will definitly let you know buddy.
But I'm no master, it will only be my 2 cents questionning or advise
I will have a look tomorrow as it is my weekend here in the UAE.
Old Apr 19, 2012, 03:40 AM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
I see you are using Coroplast and you placed a central flat spart made out of plexyglass right?
I will go for Depron build myself and do all my ribs with depron too, as for the spar wing stiffener I will use those cable tray puller, which basically are flat wires of 3mm in height and flat. They are acting the same way as carbon fiber flat spar and should keep the build at a reasonable weight.
I have right now several unfinished project unfortunately and need to complete them before I go for something else otherwise I will never finish anything. My work load is very high right now so I don't have any time to put my nose on my build ;(
But as soon as I start this build I'll definitly post my log into your thread.
Old Apr 19, 2012, 06:04 AM
argo-2 is offline
argo-2's Avatar
New Zealand
Joined Feb 2010
Sounds good RCS. Yes to central flat spar, but sandwich of plexiglass and Coroplast (aka: Correx) either side. Plexiglass is a brand name for polycarbonate, right (not acrylic)?
Be intersted in seeing a pic of the cable tray puller. Have pulled a few miles of cables in my time but not come across this.
__________________________________________________ ________
Hey Screwyfits - how goes your MIG-7? did you get that roll-rate sorted? Hoping I've got enough aileron built into Bigbird - she's got more than the MIG-7 so should be ok.
Old Apr 19, 2012, 07:40 AM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Yes argo but it was in reference of the material
Here is the cable puller wire I was talking about:
Description:
I got a brand new roll of 20m for about 3$ here in the UAE! Can't really go cheaper then that can I? Lol
Now the only thing I have to make sure is if it will create interference or not. I think it should work out fine.
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Ooopppsss Tapatalk goofed up there with many similar pics on my post! Sorry about that.
Old Apr 21, 2012, 04:36 AM
argo-2 is offline
argo-2's Avatar
New Zealand
Joined Feb 2010
Added wing root ribs to drawings collection.
Made the wing root ribs today. I drew around the wing, scanned into Visio and then used the offset function to reduce by the skin thickness. Reckon they came out well. Will finally finish the wing root with an external polycarbonate cover rib. Still to drill the CF tube holes and fit them, so can't glue these ribs in just yet.
Discussion Landing gear- Fun Jet/ Swept Forward wings? RCvertt Flying Wings 3 Sep 26, 2014 03:10 PM
Discussion Forward-swept wing + V tail Design mixjsj Scratchbuilt EDFs 24 Jan 05, 2014 08:40 PM
Discussion Calculating MAC for twisted swept wings kcaldwel NurflŘgel 127 Jul 11, 2013 07:54 AM
Build Log Forward Swept 36" Wing build log Dowquest Flying Wings 5 Oct 18, 2011 09:38 PM
Discussion Do KF airfoils work on swept forward wings? RCvertt Flying Wings 10 Oct 04, 2011 03:27 PM
