Old Apr 24, 2012, 11:45 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
or put a piece of 1/8 " balsa "shim" btween each station .make it smaller than your template and fill with light weight spackel....now how did i know about that .... i have the T shirt on that one
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 25, 2012, 01:38 AM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
That would be a lot of balsa! Already done with it. Picked up a can 3M-77, just big blocks, again.
CoolerByTheLake is online now Find More Posts by CoolerByTheLake
Old Apr 25, 2012, 11:31 PM
Joined Dec 2008
Just to let you know I'm still working out some details. But a teaser pic. This is just a rough cut, not final sections.
Old Apr 26, 2012, 12:43 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i know the "A"'s had a glass nose ring ,and later models had a stamped alum one but i think the shape was the same .....hand drawn 3 views may be different.
Old Apr 27, 2012, 05:10 PM
Depressed, Enraged and DF CEO
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Subbed
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 28, 2012, 06:50 PM
Joined Dec 2008
Good news, all foam sections are now cut. Just need to draw out the reference lines for assembly, and glue together. Does, how ever need a basic sanding before I will put up some pics. With any luck, in a few hours. Mark
Old Apr 28, 2012, 10:45 PM
Joined Dec 2008
In all it's glory!!!
Not what I had hoped for! But it is what it is, and will have to work with it. At least the intake looks good!. Now I remember why I dislike sanding white foam, it's every where. Get some mud on it tonight, and work on tail piece tommorrow. Mark
Old Apr 28, 2012, 10:56 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
getting there ,look at a lot of pics while your sanding . the nose looks a little square kinda like a fury inlet ....maybe it's just the photo.having a plastic model near by help too. lot of work but something you can take pride in
Old Apr 28, 2012, 11:34 PM
Joined Dec 2008
Thanks, AIR SALLY. The first two sections are on by double faced tape, just for that reason. The lower part of the intake didn't look quite right, wrong slope. I will work it out. Saw that video that stuarti had on the JetFan thread, of his F-86, moves right along. Will keep pluging along.
Old Apr 29, 2012, 09:14 PM
Joined Dec 2008
Intake assesment
After spending much time today, looking at this sad excuse for a F-86F fuse, I came up with a couple of pics, that better suit the intake area. ( Nose/intake remind's me of the giant worm in the Star Wars movie) Both are from F-86F's. The slick thing on the "Sky Balzers" intake is, after blowing up pic, that at the blue band, it's the exact same heigth as the section it would go in, and same station location. Convienent! Which do you like?
Old Apr 29, 2012, 10:59 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i like the balzer ...i see they really kinda look diff.....it could be the plosihed one is cause the diff.could be the inlet plug is reflecting more light inside the duct
Old Apr 29, 2012, 11:19 PM
Joined Dec 2008
The Blazer was my choice also. Just finished a template to shape outline and now to start sanding!
I have been getting all my pics, here--http://www.airliners.net/ They have 53 pages of just the F-86--all variants. Just about any angel shot you want , should be there.
Old Apr 30, 2012, 05:27 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i use that one too.
Old May 13, 2012, 07:52 PM
Joined Dec 2008
It's been a while, so time to report in. Finally, finally, I think I got the nose/intake to look like it should. Must have re-made it 4-5 times, but I'm OK with it! The next thing that puzzled me was the tail fairing. I know it looks out of proportion in the pic. I must have looked at hundreds of pics, 3-views, even got some pic's from stuarti, in the JETFAN thread, his is slightly smaller, and this is what it should be. Might be the "PINK". Still pretty rough, but plaster covers a lot, quick!
Havn't worked it out quite yet, but would like to incorporate the sub fin on the tail fairing. Will cut out for wing after fuse is done like the way J Morgan has done his. Have some ideas on how to do the hatch, and nose gear doors. Mark
Old May 16, 2012, 04:27 PM
Joined Dec 2008
Fuse is starting to look pretty nice. Would like some input on what you might think for an airfoil. I have come up with a couple I think might work well. The original is a N.A.C.A. 0009.5-64( don't know what the 64 is?) so I came up with a modified one from profili, just about the same. The other is one that the FLYFLY F-86 uses, RG-14. any thoughts?
For Sale 1:4 Scale Shalish Patel F-86F Sabre RTF bvmflier Aircraft - Fuel - Jets (FS/W) 21 Jul 26, 2012 12:31 PM
For Sale Kyosho F-86f New in Box littlepiston Aircraft - Electric - Jets (FS/W) 12 Jan 16, 2009 05:41 AM
Discussion Skymaster F-86F in 6.5 scale Plastic Fan Electric Ducted Fan Jet Talk 0 Sep 02, 2008 02:34 PM
Yippee! FS/FT F-86F Sabre Ducted Fan RTF w/ Rx & Tx JDP Aircraft - Fuel - Airplanes (FS/W) 0 Aug 30, 2002 01:47 PM
Kyosho F-86F E conversion. bruff Electric Ducted Fan Jet Talk 10 Jun 10, 2001 01:25 AM
