Old Nov 13, 2012, 12:08 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
so that weight is with out wings?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Nov 13, 2012, 12:26 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
No wings no stabs
Still need wings, stabs, tail, ducting, fasteners, wiring, etc, so I guess my low ball figure of 14lbs is out the window! Still, at 15lbs wing loading is 35.7oz sqft. and at 16lbs = 38oz sqft.
Thats why I am thinking closer to 15lbs-16lbs AUW
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 13, 2012, 09:56 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that should still fly real nice.
Old Nov 13, 2012, 11:40 PM
Joined Dec 2008
Thanks for the encouraging words. I suppose in reality, the sheeted foam cores don't weigh that much. It's only when you add all the goodies to them, is when the weight climbs. Maybe I can hit 15lbs?
Back in late Oct, Tam had a video out, http://www.rcgroups.com/forums/showthread.php?t=1757585
flying his big SM F-86 with his TJ90 and the Neu 1518/1.5Y. And even at 18.5lbs it flew it pretty well.
I don't know that much about Tam's TJ 90, but I would hope to guess using the same motor, the JetFan 90 should be comparable. As long as the accepted method for power is watts, 4.5Kw-5.0Kw will work, and thrust be damned!
Old Nov 18, 2012, 07:28 PM
Joined Dec 2008
It's been a while since I had a pic to post, so finally having the core blanks cut, thought I'd see what it going to look like. Now, I don't know if there is any way to figure what the final cores will weight once cut, but they all are 3" thick. So I took a guess, based on the airfoils I will use, and figured at least 55% waste. Core blanks weight 18oz-55%=8.1oz.for wings and stabs. Unsheeted of course. Will see how close I was when I cut them.
Got the servos all figured out. Should be able to put elevator servos in the stab, and rudder servo in the tail. Cleaner install, and no sloppy linkages.
Spars for the wings and stabs are all figured out, too!
Had been perplexed on what to use for mounting mains in the wing. BVM's flex plate cut outs were to wide for the Robart mains I plan on, and wasn't going to spend $150.00 more for their mains+ another $30.00 for the flex plates.
I happened across a deal I couldn't pass up for gear plates. 2- 4-7/8" x 7-3/4 "x3/32 thick carbon fiber plates. Another problem solved!
Old Nov 19, 2012, 03:03 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Wing area in m^2 * 0.66 * density of foam (in kg/m^3) should give a decent 'ballpark' figure for the mass of foam in kg.
Richard
This is a formula one of the guys gave me when I asked the same question .I haven't used it yet,be interesting to see how it works out.
Stuart.
Btw that was a deal!Some good guys on here.
Stuart A is offline Find More Posts by Stuart A
Old Nov 19, 2012, 06:16 AM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Nice! starting to look like a jet.
Boogie_ is offline Find More Posts by Boogie_
Old Dec 03, 2012, 10:28 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Lake hows it going ....hav'nt heard much latley??? dont give up the hard stuff is over.
Old Dec 03, 2012, 11:21 PM
Joined Dec 2008
Unfortunatly, I didn't win the lottery last week, so it will be awhile to accumulate the funds needed.
All the BIG ticket stuff is what I need now. I have a long list!
When you have been flying nitro, then add electric to the mix, there is a whole lot of stuff to buy.
In the mean time I might try my hand at at scratching me up a foamy. Some pretty nice one's have been built here. Can't just sit around, and not build anything!
Besides, I need to get up to speed on EDF's, at it will be alot easier on me crashing a foamy, than my F-86!
Old Dec 04, 2012, 02:48 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
try this one out, its right up your alley, cheap to build and flies good, takes crashes real well too
can use a couple fan options, SkyAngels 35mm (this is in the prototype), ArtTech 30mm (I plan to use this one in the next airframe), or enlarge it a touch and go 40-50mm...64mm..
http://www.rcgroups.com/forums/showthread.php?t=1765490
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Dec 04, 2012, 11:19 AM
Joined Dec 2008
I have looked at your thread. Nice, but oh so small! Not much bigger than some of the mosquitoes we have up here!
Actually my idea was to go with something to use my JF90 in. I know, a little bigger than most builds here, but as long as I need to get an ESC, batts, etc, might as well get some items I can use for the Sabre, too!
I had always figured the F-86 build would take a least a year or more, so no rush. I also made a promise to myself, that it would be a pay-as-you-go project.
NO cash-No build. So if the thread slips back a page or two, so be it.
Old Dec 04, 2012, 12:06 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
looking great man!
corsair nut is offline Find More Posts by corsair nut
Old Dec 04, 2012, 04:17 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Mark, if you want to build a first EDF,, take a look at Steve's bandit EDF.. He is jetset44, his plans are great, easy to build and fly very good.. I'm on my second bandit, put in a 64mm fan and ir flies really good.. Of course you'll need to build a bungee,, theyre easy and cheap to build though... Good luck!!!! W
Waltjg is offline Find More Posts by Waltjg
Old Sep 04, 2013, 06:17 PM
Joined Dec 2008
Minor up-date--
Should you happen to notice the last post date, it's been awhile.
A great many things have changed/happen since then.
At first it was not enough funds to finish it properly, then some serious medical issues happened. That said, the problem NOW is this BAD BOY seems to be "talking to me", ( Build me) from "his" perch above my monitor. (see photo)
To "appease HIM", I have been slowly, but surely aquiring needed parts.
I won't fully resurect the build untill my Scorpion build has come to a halt--for
painting, by that time it will too damn cold to do it. Perahps late fall/early winter.
It seemed like I was falling behind the curve, don't all builders have at least 2 projects on the table?
19,348
Old Sep 04, 2013, 07:13 PM
335driver is offline
Find More Posts by 335driver
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Cooler,,back on page1 of this thread, I knew Dick Rotkowsky, we're in the same club ARCA.
We used host the SWFF but years ago gave it to HOTMAC. That was a beautiful plane.
A story, you may not believe but it's true..after seeing the that plane, a guy offered to buy it for
10K, Dick turned him down and awhile later crashed the 86 and destroyed it. Honest
335driver is offline Find More Posts by 335driver
For Sale 1:4 Scale Shalish Patel F-86F Sabre RTF bvmflier Aircraft - Fuel - Jets (FS/W) 22 Jun 29, 2014 09:31 PM
For Sale Kyosho F-86f New in Box littlepiston Aircraft - Electric - Jets (FS/W) 12 Jan 16, 2009 05:41 AM
Discussion Skymaster F-86F in 6.5 scale Plastic Fan Electric Ducted Fan Jet Talk 0 Sep 02, 2008 02:34 PM
Yippee! FS/FT F-86F Sabre Ducted Fan RTF w/ Rx & Tx JDP Aircraft - Fuel - Airplanes (FS/W) 0 Aug 30, 2002 01:47 PM
Kyosho F-86F E conversion. bruff Electric Ducted Fan Jet Talk 10 Jun 10, 2001 01:25 AM
