Old Sep 16, 2012, 02:56 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the measures for 90 mm fan .
Claus
clausxpf is offline Find More Posts by clausxpf
Old Sep 16, 2012, 03:23 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I have been checking my measures against your, so far pretty close. For the inside dia, you got 78.80, My figures came up with 79.375. It was just guess work, but close!.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Sep 17, 2012, 11:31 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
right now.
mine have got wings and elevator now.
Claus
Old Sep 19, 2012, 12:37 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
duct.
I have compensated a little for extra surface by giving it a little more area at the slim point.
I just have to figure out to make PDF files of the duct-formers.
Claus
Old Sep 19, 2012, 12:51 PM
Joined Dec 2008
claus, that looks fantastic!! Just to double check, the 1463mm, is the measure from lower intake lip to end of bottom of thrust tube exit.
I will be the first kid on the block with this style intake!!
Old Sep 19, 2012, 05:49 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
no it is from the very nose of the plane and to the tail at the end .. the little s-formed end.
Claus
Old Sep 19, 2012, 06:24 PM
Joined Dec 2008
Mine measures from same points as you used--61.25" or 1555.75mm. Total length of fuse only.
Total length of intake to thrust tube exit would be 1463mm.
Old Sep 20, 2012, 11:05 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Geometric change..
The difference was 6 %
But the same duct fits ok
Claus
Old Sep 20, 2012, 02:18 PM
Joined Dec 2008
claus Nicely done! Amazing work. I re-checked my measurements, and had to re-scale the fuse, so the area where I have the L.E and T.E of wing is off a bit.
This pic is to give you a better sense of the length of intake to fan location.
Based on the PDF we both used, your cad/drawing is a perfect reproduction, where my fuse, although very close , is not. To this point the only minor issue I will have is in the nose gear area. You have 34.03 mm from fuse bottom to intake, where from fuse bottom to clear retract, mine is 42mm. Once I assemble intake sections, I will have to modify that small section.
Mark
Special Note--claus the 736.6mm length DOES NOT subtract the 50.8mm length of molded in, intake tube.
Old Oct 07, 2012, 11:26 PM
wind1234 is offline
Find More Posts by wind1234
United States, OH, Fairborn
Joined Jan 2012
looks like you got a very nice build going on here....really makes me want to try a scale build of a harrier jump jet....looks like you have put alot of time and care into this buid cant wait to see this all painted.......
good luck man
wind1234 is offline Find More Posts by wind1234
Old Oct 08, 2012, 03:54 PM
Joined Dec 2008
Thanks, Steve. Glad to see your back at your build.
Progress has come to a halt until I get the building fund back up there.
Still debating on which type of wing, built-up, or foam. Either will be glassed. But before that happens I need to get the main gear, struts, and wheels so I know all the right measurements for mountng retract units and gear door clearence. Lots of stuff to keep me plenty busy until then.
Having seen the two builds pekos is doing, and D_Fast's one, I should use the down time to learn how to use Sketch-Up!
Sadly, although I have made progress, it seems I will miss my target date of building an EDF before I hit the BIG 60. Even if I worked at the breakneck speed C/N has on his T-38, it won't be done by tomorrow!
Old Oct 08, 2012, 04:39 PM
wind1234 is offline
Joined Jan 2012
hey man sketchup is cool and really dont take no time to learn.....well i mean well enough to do some modeling..its got a nice simple interface...and its got cool addons like sketchy phyisics wich will let ya do cool things like animate...
another program thats free is blender realy cool but the interface is kinda daunting alot to take in but with it you can render your models and they look as real as anything heck you can even make movies with it..
ive spent alot of time on youtube they got some great tuts on there that makes it easy but still alot to learn
Old Oct 14, 2012, 07:50 PM
Joined Dec 2008
Should have a pilot!!
While I was messing around with the hatch/canopy area got to thinking again about a pilot for this. For the Korean war era pilots there is not to much around, but I did come up with two that might work. Just thought I would run it by you guys to see what you thought. Both 1/7th scale.
Old Oct 15, 2012, 01:02 PM
JLLayton is offline
Find More Posts by JLLayton
Lansing, MI
Joined May 2002
I like those, where can you get them ?
I did a search for mag-men but could not find them
JLLayton is offline Find More Posts by JLLayton
Old Oct 15, 2012, 03:18 PM
Joined Dec 2008
Thanks for stopping by. The full bodied one is here:
http://centuryjet.com/index.php/cPath/46_38_28
I had to e-mail them to even see if it was avaliable, as it shows no order number. In 1/7th scale is, did not check on other scales. Waiting on e-mail to see if it has a # and to make sure prices are same.
Pilot bust is here: http://www.rcuniverse.com/market/item.cfm?itemId=874499
Scroll down to post for the ad and it gives width and height. He may have smaller ones too.
Here's there size chart. Century Jets
------------------------------------- Head to--- Seat to--- Chest---- Weight
------------------------------------- Seat-------Toes----- Width----- (Ounces)
1/10th Jet Pilot Bust------------ 2.25"------------------ 2" --------- 0.7
1/10th Jet Pilot Full Body------3.5"--------3.75"----- 2"-------- 1.7
1/9th Jet Pilot Bust------------- 3.25"------------------- 2"---------- 1.7
1/9th Jet pilot Full Body--------4" --------- 4"---------- 2"---------- 3
1/8th Jet Pilot Bust------------- 3"----------------------- 2.625"---- 1.2
1/8th Jet Pilot Full Body--------4.5"------- 5"--------- 2.625"---- 3.4
1/7th Jet Pilot Bust ------------- 4.5"-------------------- 3"---------- 3
1/7th Jet Pilot Full Body-------- 5.25"------ 5"---------- 3"---------- 3.4
1/6th Jet Pilot Bust ------------- 6"-----------------------3.5"------- 3.3
1/6th Jet pilot Full Body-------- 6.375"---- 5.5"--------3.5"------- 3.7
1/5th Jet Pilot Bust ------------- 5.5"---------------------4"--------- 5.1
1/5th Jet Pilot Full Body-------- 7 .25"----- 8.5"--------4"--------- 5.6
For Sale 1:4 Scale Shalish Patel F-86F Sabre RTF bvmflier Aircraft - Fuel - Jets (FS/W) 22 Jun 29, 2014 10:31 PM
For Sale Kyosho F-86f New in Box littlepiston Aircraft - Electric - Jets (FS/W) 12 Jan 16, 2009 06:41 AM
Discussion Skymaster F-86F in 6.5 scale Plastic Fan Electric Ducted Fan Jet Talk 0 Sep 02, 2008 03:34 PM
Yippee! FS/FT F-86F Sabre Ducted Fan RTF w/ Rx & Tx JDP Aircraft - Fuel - Airplanes (FS/W) 0 Aug 30, 2002 02:47 PM
Kyosho F-86F E conversion. bruff Electric Ducted Fan Jet Talk 10 Jun 10, 2001 02:25 AM
