Lt599, thanks for asking. First let me say I got a lot of info from reading John Morgans builds. Also great info from Tumbler ( Molding the blaze) on the resin etc. I did learn what NOT to do, and what I would change.
I used 3- layers of glass, 4oz, really only figures out to be 3.7oz. Next time around would only use 2 layers of heavier glass. J Morgan suggests around total galss weight 10-12 oz sqyd. This would of course depend on size of fuse. Two layers will give you the same strenght, but you lose the weight of the extra coat of resin. When I glassed the plug originaly I just used some bondo glass from Menards, when it cured, I sanded it down and put on a thin layer of resin, sanded, wet sanded and filled as needed. Came out smooth as a babys butt. I didn't do it on the final pull, ( my mistake) too easy to sand through the glass. What you would use for resin is your choice. I know lots of guys here like the West Systems. I used US Composites #635 4:1, a little less working time than the 3:1 http://www.uscomposites.com/epoxy.html Theres a great thread in the composits forum on different resins. http://www.rcgroups.com/forums/showt...mparison+tests I used the Partal #10 release. http://www.uscomposites.com/moldrelease.html I did make a jig to hold the plug. Nothing fancy, just some ply I had for a base and put 2 uprights on the ends. Inserted (epoxied in) two large dowells into the intake and exhaust (drilled for 1/4" rod as axels) so I could remove them. It worked Ok, but broke loose in the white foam I used. From now on, only PINK foam for me! Much better in so many ways. As for primer, I used Rust-Oleum Painters Touch Ultra Cover 2X. wonderful stuff. Guess that covers it. If you have any more questions, just ask . Mark |
) I assume you used a brush? Thanks again, your build is looking great. Greg
| Thread Tools | |
| For Sale 1:4 Scale Shalish Patel F-86F Sabre RTF | bvmflier | Aircraft - Fuel - Jets (FS/W) | 21 | Jul 26, 2012 12:31 PM |
| For Sale Kyosho F-86f New in Box | littlepiston | Aircraft - Electric - Jets (FS/W) | 12 | Jan 16, 2009 05:41 AM |
| Discussion Skymaster F-86F in 6.5 scale | Plastic Fan | Electric Ducted Fan Jet Talk | 0 | Sep 02, 2008 02:34 PM |
| Yippee! FS/FT F-86F Sabre Ducted Fan RTF w/ Rx & Tx | JDP | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 30, 2002 01:47 PM |
| Kyosho F-86F E conversion. | bruff | Electric Ducted Fan Jet Talk | 10 | Jun 10, 2001 01:25 AM |
