Joined Jun 2011
Thanks, username. This stuff is not my forte. I'm not sure what kind he sent me but I know he has resistors on them. Last time he sent them to me for free, but this time I had him make like 30 of them for me so I send him some money for his trouble. Makes everyone happy, but especially me because my eyes aren't what they used to be up close and this is so small for soldering that it is certain to put me in a bad mood real quick if I have to attempt doing this by myself. I think I could do it easily, only if I could see the darn things.
![]() Best, Chris |
Joined Jan 2012
Tom
I am new to the forum and have appreciated your efforts. I have a Devo 10 Tx, A genius CP Pro and Ladybird I just bought. I think my Devo 10 is in a firmware infinit loop and was wondering if you have any experience with the Devo Tx's. My question is how to reset the Tx so I can bind to models and make setting changes to them. When I power the Tx on the only thing is does is display "Flight Switch". I have tries all three settings for the FMOD with the Throttle stick all the way down as WOW suggested. No change. Any help would be appreciated. Dale |
EDIT:::: Which on mine is the MIX switch it has to be on (0).. If you need me to I'll go to the truck and get my Devo 10 and see which switch it is.. Heck I'll go get it anyways and the LB and sit here and fly it.. |
Joined Jan 2012
I dont have a devo10, but I have a devo7 and when you power on the TX you can go into your different setups ie ( minicp, and ladybird on mine ). I can store up to 10 models in memory. |
Joined Jun 2011
There is nothing wrong with your transmitter. You just need to learn how to use it. I suggest you read up about flight modes on programmable transmitters. Chris |
OK the LB batteries are all gone,, no answer from him so I'm going to bed.. It's still Sunday night here... ![]() ![]() ![]()
Joined Jun 2011
Chris |
Hi Dale, I only have the Devo 7 TX and would have said what Chris posted that the FMD switch has to be on (0) when you power up your transmitter. Try what bob posted, have the MIX switch set to (0). Tom |
Latest blog entry: My RC Web Site
Well it fooled me also. I went to the truck and got it as I also thought it would be the flight mode switch.. I had to sit here and flip switches and turning it on and off till I finally found the right one to give me the FLIGHT SWITCH warning... I only have the LB in it and it came with it installed,, which is why I pointed this out as it might have some bearing on it,, as It's using the FM switch to go from 3 to 6 axis. And I would think that the MIX switch which is in the same spot as the GYRO switch on the 2801 is, would be the one I would of picked to use.
Joined Jun 2011
On the Devo 8, it's using the mix switch to go from 3 to 6 axis. The FMOD switch is working as usual. Other people have reported using the FMOD switch to switch fro 3 to 6 axis but for me that didn't work, which, to me, is better if I use the mix switch because I can then use the FMOD switch to program different throttle curves and D/R settings. It's more versatile that way, I think.
I have to say, though, I'm already getting bored with this bug. Not much skills required to flip it and roll it, and it doesn't have enough power to do big loops or inverted drops with last second recoveries. It simply doesn't have enough thrust for its own weight so it cannot perform as well as larger quads with brushless setups. It's a toy. It's good to mess up with the cats and dogs around the house, though. I attach a cat toy to a string on mine and play with my cats. That's quite fun. I'm waiting for parts to put together a 450 quad that will have almost three times more thrust than its own weight. Now that will be a whole other ball game... Chris |
Joined Oct 2006
I spent all weekend filling hobbyking/spark fun shopping carts and tearing apart a wii motionplus and nunchuk. |
Joined Jun 2011
Best, Chris |
| Thread Tools | |
| Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade | Tom Z | Micro Helis | 663 | May 02, 2013 02:54 PM |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| Discussion Yet Another Newbie 5.8GHz Setup - A Catalog of Statics | ffranck | Video Piloting (FPV/RPV) | 199 | Jul 21, 2012 12:01 PM |
| Mini-Review Turbo Ace 915 V2 9g Motor with Pictures, Video, Flight Tests, and Thrust Tests | Tom Z | Micro Helis | 96 | Aug 12, 2011 07:48 PM |
| Discussion Short flight time (3 mins) with Walkera 5-5B | HeliDrew | Coaxial Helicopters | 1 | Jan 18, 2008 04:43 PM |
