Joined May 2012
I absolutely LOVE my LADYBIRD QR. quick question, i am using 8 rechargeable Energizer batteries in the Devo 7 TX. I've read both that you can, and I've read that you can't, plug the recharge cord for the energizer batteries directly into the Devo 7 to charge the batteries without constantly removing them (which is a pain). The cord does fit perfectly into the TX. On the cord it says:
Energizer AC/DC Power adapter Model CH15MM-ADP Input: AC/CA 120V--60Hz 85W Output: DC/CC 16V=4A Class 2 Power Unit Its the normal rechargeable batteries that you get form walmart, target, etc. the box that the cord would normally plug into (the box that holds the 4 batteries that it charges) says DC 11-16V INPUT. Using this plug would be a lot better than taking out and charging 4 batteries at a time, but i do not want to damage my Devo. I don't know much about electronics. Do you know if I can safely use this cord to charge the batteries while they remain in my Devo 7 TX? |
Joined Nov 2007
There is an option called Power Amp (AMPLI) in Model Menu which can reduces the signal power of Devo, I am using lowest value, I can have longer operation time for each charge and still can control Ladybird within visible distance. |
Joined Nov 2007
Joined May 2012
i created a second profile name and changed the 3g from the Aux2 to the mix. my LB was flying funny so i deleted the second name and changed the 3d back to Aux2 using the instructions that i originally used when it was working fine. now the ladybug is not connecting with the TX at all. ive tried everything i know. any suggestions?
Joined Jun 2011
Good luck! Chris |
I have greatttt news!
Well not actually news, I just haven't posted it on here till now cos I'm lazy AND busy... but Walkera has other multicopters coming out real soon (These are ALL flying examples) ANYWAYS, can you imagine the maintenance bill on these things? a little overkill I think..but the more the merrier I guess!
Latest blog entry: The Walkera QR W100 review (Wifi based...
United States, NC, New Bern
Joined Apr 2012
something about the new multi copters compared to the lady bird.... they lack character?
i am interested to see how the tricopter (or would it be hexicopter?) performs as a result of its design... thanks for the update mr schen! hopefully they will not be super expensive |
Joined Jun 2011
Thanks for posting, Mr. Chen. Chris |
Joined May 2012
i used the binding plug but for some reason i needed to use it every time to bind. i used the fixed id as requested by helipal customer service and it binded once for about 15 seconds then disconnected. since then i have not been able to get it to bind at all. I've tried the bind cord again several times, creating new models, etc and nothing seems to be working. just a fast flashing red light. it honestly worked better without the fixed ID on. I'm going to turn it off and use the binding cord again? any other suggestions. when i got it i flew it all day with no problems. a couple of crashes but all in high grass.
Canada, ON, Ottawa
Joined Jun 2009
Joined Apr 2012
| Thread Tools | |
| Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade | Tom Z | Micro Helis | 663 | May 02, 2013 02:54 PM |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| Discussion Yet Another Newbie 5.8GHz Setup - A Catalog of Statics | ffranck | Video Piloting (FPV/RPV) | 199 | Jul 21, 2012 12:01 PM |
| Mini-Review Turbo Ace 915 V2 9g Motor with Pictures, Video, Flight Tests, and Thrust Tests | Tom Z | Micro Helis | 96 | Aug 12, 2011 07:48 PM |
| Discussion Short flight time (3 mins) with Walkera 5-5B | HeliDrew | Coaxial Helicopters | 1 | Jan 18, 2008 04:43 PM |
