Walkera QR Ladybird Review - Pictures, Video, Flight Times, and Thrust
Walkera QR Ladybird V1
First Impressions: The Ladybird looks nice. It is small in size and it fits in my hand. It is very light weight. It feels well built and should take a crash pretty well. It has a unique sound to it with the 4 motors. I have never flown anything but helicopters for over 5 years so I was curious how a quad would fly. I would say it is a bit like a coaxial helicopter in a way but also very different than a helicopter. The Ladybird is ultra stable and very smooth flying. It has good power with the stock motors. After I added some D/R and Expo I was able to fly it good for the first quad I have ever flown. The flight time is very good. I was surprised that the stock battery got the same flight time as the Hyperion 240 mah 25C battery and had the same power. Pros:
Cons:
Updates:
Transmitter Setup Guides: http://www.rcgroups.com/forums/showthread.php?t=1325037 Telemetry: I have found out that using the telemetry eats up the battery time. I went from 5 full minutes of flight time on my Master CP with telemetry inhibited in the TX to 1:25 minutes flight time with the telemetry enabled. I found the same thing with my Mini CP, 1:25 minutes flight time with the telemetry enabled and 3 minutes flight time with the telemetry inhibited. My friends Mini CP had the same results as I did with telemetry inhibited and enabled. Devo 10 I set the Sensor Setting - Voltage - External: V1- Alarm Voltage to 3.5V. This give me 3.72V per cell no load which is pretty good. Flight Time: - Walkera 240 mah 25C stock battery.
Flight Time: - Hyperion 240 mah 25C battery.
Thrust: 42.1 Grams - Walkera 240 mah 25C stock battery. Weights:
Specifications: 1). Onboard telemetry 2). Motors (x4): 0720RN57A-9M-130NL52 3). Receiver: RX2634H-D 4). Battery: 3.7V 240mAh 5). Dimensions: 8.5*8.5cm 6). Height: 3cm 7). Radio range: <=30m 8). Flight time: 6-8min Helircstore sent me the Ladybird to review. Thanks Bob for sending me the Ladybird! http://helircstore.com/
Your welcome, glad you liked the review.
![]() The stock Walkera 240 mah battery had a couple charge cycles through it and the Hyperion 240 mah batteries have dozens of charge cycles through it . Tom |
Latest blog entry: My RC Web Site
Thanks. Just tried your 150% on rudder and I added 125% D/R for rudder.
WOW! It really made the rudder response much faster. Too much for me now so I dialed it down until I get use to flying the quad. It is really good for indoor flying due to it is small and super stable. Tom |
Sounds fun!
![]() I haven't tried 3 axis flipping yet. Will try it tomorrow over my thick tall grass. Hope I got the newest version with the updated firmware to handle 3D-Flipping. It will flip with the fast roll rate and 3-Axis flipping firmware. This is what wow has posted on there web site. Tom |
Long as you van switch to the green light you have it. The original was permanently on 6axis.
The flipping gets addicting. They look a lot better when settings are tamed a bit too, nice looping flips opposed to super tight so fast they are blurry flips you get on high settings =) |
Thanks for the info. I can switch between red light and green light so I do have
the 3-Axis flipping firmware. Tom |
@Warrior0465: The gyros are switched depending on your gyro settings, please refer to Tom Z's post regarding the quad here: http://www.rcgroups.com/forums/showt...1325037&page=2
Mine is assembled from parts as it costs about 37% less than buying the BNF (I got the Ladybird in China off Taobao) but there are two things I've noticed: one being that the quad isnt as stable as I thought it would be.. even in six axis mode (not really coax stable.. I think even my MCP doesnt slide as much as the QR) another thing being that there really isn't a noticeable difference between three and six axis modes in terms of stability... am I the only one having these issues? |
I think a lot of that is relative to your gain setting...
so Tom, How you liking your first foray into quads? I still enjoy getting my #8 out. Amazingly fast...and tame enough for indoors. I won't bother to post vids of it. Marker lights double the fun. Makes night flying easier than day, except for those objects hidden by the dark. regards, Bill |
Hi Bill,
I like it. It is very stable, super fast, and fun to fly. Getting better at flying it on my second day. The problem I have is sometimes I can't tell which way the Ladybird is facing due to it is square shaped. Have any suggestions that can help with this? Your #8 sounds nice with the marker lights. Tom |
HD outdoor videos added
Just added HD outdoor videos to the review including flip attempts.
Also added setup for AERO mode in my setup guide. Now there are HELI mode and AERO mode setup options. Tom |
| Thread Tools | |
| Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade | Tom Z | Micro Helis | 663 | May 02, 2013 02:54 PM |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| Discussion Yet Another Newbie 5.8GHz Setup - A Catalog of Statics | ffranck | Video Piloting (FPV/RPV) | 199 | Jul 21, 2012 12:01 PM |
| Mini-Review Turbo Ace 915 V2 9g Motor with Pictures, Video, Flight Tests, and Thrust Tests | Tom Z | Micro Helis | 96 | Aug 12, 2011 07:48 PM |
| Discussion Short flight time (3 mins) with Walkera 5-5B | HeliDrew | Coaxial Helicopters | 1 | Jan 18, 2008 04:43 PM |
