Old Apr 16, 2012, 03:12 PM
Cdallas2 is offline
Find More Posts by Cdallas2
Cdallas2's Avatar
Kamloops B.C.
Joined Jun 2003
Electric Northstar
Planning on building another Northstar as I regret having to sell my old one with only ever getting a total of 11 flights on it before I was forced to sell it. This time I want to do it fully sheeted, glassed and painted with electric power.
I fly electric heli's but I need some help with figuring out the proper Motor/ESC/Combo i'll need. I want power equivalent to an OS .55
Suggestions?
Cdallas2 is offline Find More Posts by Cdallas2
Old Apr 17, 2012, 06:12 AM
bossee is offline
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
Hi,
Check how large diameter prop you can have to get prop clearance to the top of the wing.
Check with ecalc http://www.ecalc.ch/motorcalc_e.htm?ecalc
what temp, amp and watt (P(out) you get with various props.
Try APC Electric E prop. I checked briefly and with the motor, ESC (max 60 amp) and 6 cell 3700 25-35C LiPo I got with 16x8 prop 723 watt as P(out) and a mixed flight time about 8,7 minutes (minus 20% since You should not drain the battery more that you have 20% capacity left after flight, that mean about 7 minutes mixed flight time in your case).
723 watt is about 1 hp (746 watt = 1.0 hp).
Lets say the Northstar will weight about 7 lbs
http://shop.balsausa.com/product_p/455.htm
That will be 723/7 =103 watt per lbs and should work OK for sport flying.
/Bo
bossee is offline Find More Posts by bossee
Discussion Balsa USA NorthStar plasticjoe Glow to Electric Conversions 33 Nov 28, 2012 01:39 PM
Wanted need a busted or used cheap heli, electr or not... jaydag77 Aircraft - Electric - Helis (FS/W) 0 Aug 29, 2009 12:54 PM
Hobbico Press release - Carl Goldberg Husky 400 Park Flyer ARF & Mini Hold ‘em Electr Dave Lauck Product Announcements 0 Sep 28, 2005 02:46 PM
HOB Northstar Conversions??? Viper Pilot Power Systems 0 Sep 08, 2002 02:01 PM
