View Poll Results: Would you recommend the HK-5320 servos?
Yes 24 100.00%
No 0 0%
Voters: 24. You may not vote on this poll
Old Apr 16, 2012, 12:38 PM
Free is online now
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Poll
HK-5320 servos?
Hi guys,
Would you recommend the HK-5320 1.7 gram rotary servos?
Free
Free is online now Find More Posts by Free
Old Apr 16, 2012, 12:44 PM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
Absolutely! They are FAR superior to Spektrum linears, and as they keep adding weight to the linears the 5320's are alot lighter to boot. ( out of over 30 of them they weighed in at 1.82-1.87 grams right out of the package ) I use these for all my micros, including every new HH micro I buy, they get whacked as soon as they come out of the box and get these installed in place of the linears. Cant go wrong man, try some out.
Mendo
Mendo is offline Find More Posts by Mendo
Old Apr 16, 2012, 08:46 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i use them cuz of the lack of noise. i hate the linear noise. and the spektrum started off at, 1.5 then 1.7 now 1.9. stock new twin screw hk5320 is 1.88g if you are psyco you can get them down to 1g.
menudo: id love to see some pics!
nemoskull is offline Find More Posts by nemoskull
Old Apr 16, 2012, 11:35 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
What rx's are you guys using with these 1.7 servos??
Butch777 is offline Find More Posts by Butch777
Old Apr 16, 2012, 11:43 PM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
415 and 6400 RX and they work good on one or 2 cell.
JCS
miatamama is offline Find More Posts by miatamama
Old Apr 16, 2012, 11:54 PM
Mendo is offline
Mendo's Avatar
Joined Dec 2011
I use and have used ar6300's, 6400's, and hk415's. the 1.25mm molex connector that comes on the 5320s is plug and play with the 415 rx's, any other rx's you need to change connectors and make sure you have the pin arrangement correct. I also recomend running them on 4.2-4.3 volts over 5v. They do work at 5v and I personally havent had any problems at that voltage, but others have had them get hot, so as a precaution I slip a diode inbetween my esc and rx to drop the voltage around .7 volts.
Mendo
Old Apr 18, 2012, 02:46 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Neither of mine center and one rocks/shake if you release the stick. Is this normal? I only have two so my opinion really doesn't weigh much.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Apr 18, 2012, 03:41 PM
Free is online now
Free's Avatar
Joined Jan 2012
Thank you for all of your feed back, I think that I will get one of these servos and put it on the ailerons of my UM Osiris V2
Free
All my servos rock/shake when I release the stick because it the bounces between the spring things that keep the stick in the center, not sure if this is what you were talking about.
Old Apr 18, 2012, 03:43 PM
gklein is offline
Find More Posts by gklein
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Believe it or not, I just used these on a Gravityhobby Zero with a ZX technology 72MHz rx. and a 10 gram motor. I yanked the linear servos on the ailerons (one on each aileron) and replaced with the 5320 for more throw. This plane is very fast. I just got more of the servos for my micros. I will use up my stock of linears but I anticipate that new orders will be for the 5320's.
Oh, I did put a diode in the supply circuit to cut the 5 volt supply down to 4.3 just to be safe.
gklein is offline Find More Posts by gklein
Joined Nov 2007
The servo its self continues to jitter until I move the stick away from then smoothly back to center.
Old Apr 18, 2012, 03:45 PM
Free is online now
Free's Avatar
Joined Jan 2012
Thats not good
Free
Old Apr 18, 2012, 03:46 PM
Free is online now
Free's Avatar
Joined Jan 2012
Had that same problem with a Spektrum 3.5 gram servo.
Free
Old Apr 18, 2012, 04:02 PM
Joined Nov 2007
HK-5320 Jitter (0 min 34 sec)
Old Apr 18, 2012, 04:22 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
that is one anxious servo... a jumpstyle servo!
BIM - I have 2 dozen and not a one behaves like that. how about if you switch ports does the other act the same way?
elvill is offline Find More Posts by elvill
Old Apr 18, 2012, 05:35 PM
Mendo is offline
Mendo's Avatar
Joined Dec 2011
Pull the bottom of the servo case off and try a squirt of freon on the exposed internals to blow out any debris, then put it back together and see if your servo is still twitching...
Mendo
Discussion Any Info on: HK-5320 Ultra-Micro Digital Servo 1.7g Tim Cullip Scratchbuilt Indoor and Micro Models 189 May 04, 2014 06:29 AM
Discussion Genius - HK-5320 servos. FIXED SadSack Micro Helis 18 Jan 25, 2013 12:15 AM
Sold 3 N.I.P. hk 5320 servos - 16 shipped CONUS nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Apr 14, 2012 12:59 PM
Discussion HK 5320 servos Speedfreak Micro EDF Jets and Power Systems 6 Mar 06, 2012 09:09 PM
Sold N.I.P. HK-5320 2 grams rotary servo. $6 shipped CONUS nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 12, 2012 10:34 AM
