Old Apr 16, 2012, 10:16 AM
ithia is offline
Find More Posts by ithia
United States, GA, Smyrna
Joined Oct 2011
Question
Flaps on a CG eagle 2
Was thinking about doing flaps or maybe flaparon on a carl goldberg eagle 2. Good idea or bad idea?
ithia is offline Find More Posts by ithia
Old Apr 16, 2012, 07:26 PM
H&H is offline
H&H
Find More Posts by H&H
H&H
H&H Hobbies
H&H's Avatar
Old mystic CT U.S.A.
Joined Nov 2003
I wouldn't consider it a good idea or a bad idea. just an Idea. My question is why?
What are you looking to gain performance wise?
H&H is offline Find More Posts by H&H
Old Apr 16, 2012, 07:46 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
It's an eagle... its a trainer... .. people still do things for fun. I turned mine into a V-Tail for fun. Looks really cool and flies just like the orginal. Go with flaperons.. nothing required building wise.. just mixing..
The V-Eagle. Full screen makes it easier to see.. phone cam so not the best.
Maiden Flight of the Veagle (1 min 50 sec)
Thermalin is offline Find More Posts by Thermalin
Old Apr 16, 2012, 10:12 PM
H&H is offline
H&H
H&H
H&H Hobbies
H&H's Avatar
Joined Nov 2003
Agreed 100%. This is however, the beginner training area and the op has only 16 posts.
I thought it a good idea to see what he was thinking.
A beginner probably won't be served as well by modifying his/her trainer as they would be be by simply learning to fly it.
Old Apr 16, 2012, 10:13 PM
hogflyer is online now
Find More Posts by hogflyer
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
ithia,
Converting the ailerons into flapperons should work great - keep them full span so you don't lose any aileron control when just above stall. I did that to a NextStar, and with them down just a 1/4" it made the plane fly better. While they didn't appear to allow for a steeper approach, they did make for a slower touch down. Plus I couldn't get the plane to spin no matter what I tried, with the flappers up or down. You can also reflex them jut a bit to see what that will do for the speed side.
Thermalin,
I like that v-tail conversion. Have any close-up pictures? How did it handle stalls and spins? (This may be better off being answered in a new thread so we don't highjack ithia's thread, unless it's ok with him.)
Hogflyer
hogflyer is online now Find More Posts by hogflyer
Old Apr 17, 2012, 08:26 AM
ithia is offline
Joined Oct 2011
H&H,
This is my 2nd plane, I loged about 6.5 hrs on my last plane till I had a radio problem that end with a bad crash. Still learning but I'm not brand new. I hoped to gain shorter landings and take offs. My flying area is 12ish acre field, but the runway is kinda short, and I have Futaba 6j TX. Kinda wanted to use the extra channels. Maybe I should fly it stock for a bit then mod it. I'm installing the two servos in the wing any how.
Thermalin,
I read your build log on the eagle 2, very nice. I used alot for your ideas on mine.
hogflyer,
Highjack away I want to see some close ups
Old Apr 17, 2012, 01:49 PM
H&H is offline
H&H
H&H
H&H Hobbies
H&H's Avatar
Joined Nov 2003
What's nice about flaperons is that that they are easy to do. Good luck with your project. The Eagle 2 is a great plane. It's what I taught my kid to fly on. Have fun with it.
Old Apr 17, 2012, 07:22 PM
Thermalin's Avatar
Joined Jan 2005
HH - good point.. didnt realize where I was or the post count.
Ithia...
Generally flaps allow for slower flight.. not short landings but will decrease take off roll providing more lift
Old Apr 18, 2012, 12:43 AM
jjkupinski is online now
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Flaperons on an airplane with full span ailerons can be a crap shoot. True, it decreases liftoff speed and landing speed. But due to a number of factors, it also increases the probability of a tip stall on constant chord trainer wings (and crash). Learn how to "flare".
jjkupinski is online now Find More Posts by jjkupinski
Old Apr 18, 2012, 07:34 AM
ithia is offline
Joined Oct 2011
Hmmm, I think I'll skip the flaparons for now, and fly it stock for a few weekends. I'm all set up for them I'll just have to change the TX mix setings at some point down the road. Thanks for the input.
Old Apr 18, 2012, 10:31 AM
epoxyearl is offline
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Might I suggest you set up your flaps,and practice with them at a good and safe altitude? Slow it waaaaaay down,and either mix in some trim,or just trim it to fly slowly.....if it tip stalls,which I don't think it will, pull the flaperons and continue as before.
Do some "landings" at 200', before you try them at 2'. get the 'feel' for them.
...and the airplane DOES slow down with flaps.
When you're ready, try them,it's not irreversible you know.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Old Apr 18, 2012, 02:40 PM
ithia is offline
Joined Oct 2011
Good point epoxyearl. I didnt think about trying them at altitude. I will try them this way, and if they do not work out I will just turn them off and fly with ailerons. Thanks.
Old Apr 18, 2012, 08:42 PM
Thermalin's Avatar
Joined Jan 2005
The eagle does slow down nicely on landing where you can actuall touch the mains first and let the nose come down..
Old May 21, 2012, 09:08 AM
ithia is offline
Joined Oct 2011
Well 5-20 was the first flight of the eagle mk2 with flaparon mod. It worked great! Thanks urbody
Old May 21, 2012, 09:44 AM
epoxyearl's Avatar
Joined Oct 2011
Good job-they're lots of fun.
Now-start taking off with them,using the same amount of elevator trim you land with.
Help! help regarding deploy flaps with Futaba 10 CG Johnsmith122 Radios 14 Apr 13, 2012 10:08 AM
Question 2-position Flaps on Sanwa/Airtronics Geoffnet Radios 0 Jan 04, 2012 03:32 PM
Sold CHEAP CG Eagle 2 FlattyFlier Aircraft - Fuel - Airplanes (FS/W) 7 Nov 30, 2011 08:22 AM
Discussion CG 2.6 ounces off on j3 piper? schusterjo Electric Plane Talk 9 Nov 20, 2011 11:05 AM
For Sale CG Eagle 2 kit NIB free shipping lower 48 nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 19, 2011 12:56 PM
