Old Apr 15, 2012, 11:54 PM
out of stock is offline
Find More Posts by out of stock
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
Help!
tail wheel wire. please have a look.
k,
im currently building a 30cc mxs breitling. the instructions kinda sucks. the photo below represents exactly what i have minus the shaft that the arrow is pointing at.
am i supposed to bend that wire 90 degrees up into the rudder and epoxy/thick ca it?
red aero mxs 30cc breitling.
out of stock is offline Find More Posts by out of stock
Old Apr 16, 2012, 12:02 AM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
That part that the arrow is pointing to is supposed to be glued into the bottom of the rudder and the small metal wire will steer the tail wheel and provide a bit of bump resistance. If you don't have that part, the ball link from a helicopter will work just as well.
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Apr 16, 2012, 07:40 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
What he said. Looks like a typical tailwheel. DO NOT bend the wheel wire 90 deg. It must pass thru the small hole in the post and "hang" free. You do not want the steering qeometry of the wheel binding the rudder. GOOD LUCK !
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Apr 16, 2012, 07:51 AM
DONT PANIC! :)
Joined Jan 2012
What does a ball link from a heli looks like? Sorry I'm very limited on this phone. I guess o was shorted that piece. thanks people!
Old Apr 16, 2012, 01:20 PM
dumbthumbs53 is offline
Find More Posts by dumbthumbs53
Albany, OR
Joined Jul 2009
http://www3.towerhobbies.com/cgi-bin...&I=LXFPW7&P=ML
Just drill a hole in the bottom of the rudder big enough for the plastic end and epoxy it in place, then just run the tiller from your existing tail wheel through the brass eyelet in the bottom of the ball link.
Virtually any local hobby shop should carry ball links of some kind.
- Attached an image from a 3DHS Extra manual for reference -
dumbthumbs53 is offline Find More Posts by dumbthumbs53
Old Apr 16, 2012, 04:29 PM
DONT PANIC! :)
Joined Jan 2012
Thank you so much
For Sale Electrifly SU-31 Wheel pants, Mail Wheels + Tail Skid NIB $12 Shipped CONUS parkflyer215 Aircraft - General - Miscellaneous (FS/W) 0 Feb 26, 2012 10:51 PM
Question Front Wheel vs Tail Wheel tolice Fuel Plane Talk 25 Jan 31, 2012 01:44 AM
For Sale Electrifly SU-31 (41 inch) wheels, wheel pants and tail skid parkflyer215 Aircraft - General - Miscellaneous (FS/W) 0 Nov 12, 2011 12:13 PM
Discussion Tail wheel wire binds rudder on HZ Super Cub Mopower71 Beginner Training Area (Aircraft-Electric) 5 Nov 07, 2011 11:44 PM
How to attach wire for tail wheel? Daddy-O Foamies (Kits) 10 May 03, 2005 02:31 PM
