Old Apr 15, 2012, 09:06 PM
Bonzer1 is offline
Find More Posts by Bonzer1
Joined Sep 2011
ESC Calibration with 4.0 Software
After calibrating the escís on my hexacopter with the new 4.0 firmware, I noticed that one motor begins spinning just slightly before all the others begin to spin. This difference is so small that the other 5 motors begin spinning 1 or 2 clicks on the throttle stick after the 1st motor. Is this something to be concerned about, should all motors begin spinning exactly at the same time or is it ok for there to be a slight difference
Bonzer1 is offline Find More Posts by Bonzer1
Old Apr 16, 2012, 01:12 AM
ed.ge is offline
Find More Posts by ed.ge
Joined Oct 2010
Maybe the board isnt standing exactly level? But Im not sure if that affects it. Here they all start the same time.
#odd
I recalibrated with the new feature (all at the same time) - and the gain suddenly dropped from 26 on TX to 16 on TX to make it flyable. Motors starting the same before and after.
ed.ge is offline Find More Posts by ed.ge
Old Apr 17, 2012, 02:32 AM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
There is a small bug in that feature which gives an incorrect range. We have a fix and it will be released soon.
In the mean time, it makes sense to calibrate your ESCs manually with your receiver.
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Apr 17, 2012, 03:27 PM
Huck Norris is offline
Find More Posts by Huck Norris
Joined Apr 2011
by manually do you mean not all at once but one at a time?
Huck Norris is offline Find More Posts by Huck Norris
Old Apr 17, 2012, 03:33 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
I mean one at a time while connected to your RX. Not connected to the HFP.
Site Sponsor
Old Apr 17, 2012, 11:06 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i just wired up a 6 way Y to connect all ESCs to my Rx throttle channel
works every time
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 21, 2012, 02:24 AM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
works every time
Genius!
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Apr 21, 2012, 05:38 AM
ross_badger is offline
Find More Posts by ross_badger
SuperX Hex and X8 Flyer
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
works every time
Great idea! I'll have to get out my solder iron today and make one!
ross_badger is offline Find More Posts by ross_badger
Old Apr 21, 2012, 09:48 AM
Adidas4275's Avatar
Joined Mar 2011
To be honest it was a recommendation by multiwiicopter.com when I built my first quad (scarab)
And it makes the feature of doing it through the board almost unnecessary.
I can see a little convenience, but I like not having to worry where the throttle is on my tx when I plug in my battery
Unlike every other RC I have
Old Apr 21, 2012, 10:55 AM
aka Helidaho
Joined Jun 2010
Yeah I accidentally went into throttle calibration mode once after they had changed the firmware. The throttle stick wasn't even that high. So then I had to do it again and it was still not right (apparently a known bug). Once I went through one by one with the Rx all was well again.
Paul
Old Apr 21, 2012, 12:05 PM
Adidas4275's Avatar
Joined Mar 2011
Yeah really I think it is an unnecessary feature that is solving a problem that doesn't exist.....
But perhaps I am in the minority and they have had a lot of requests from people who are recalibrating their ESCs regularly...... I have only calibrated them once... When I built the heli and connected the Rx.
Is there something that I am missing.
Old Apr 21, 2012, 04:46 PM
JZSlenker is offline
Find More Posts by JZSlenker
JZSlenker's Avatar
United States, PA, Harrisburg
Joined Aug 2011
I have never had to re-calibrate. I use the opto isolated RCT escs and have them all set to fixed throttle points. Works great!
JZSlenker is offline Find More Posts by JZSlenker
Old Apr 22, 2012, 01:38 AM
michael f is offline
Find More Posts by michael f
Adelaide; Aus
Joined Jan 2006
Taking about ESC calibration, I have built five multi-rotors, one hexi, one octo and three Y6's and have never had to reduce the throttle trim on my Rx to get them to arm properly. It is only now after George mentioned it that I have started to use full minus trim. I was just wondering what problems others were having by not using minus trim on their TX's?
Also I use all the power wires connected from the ESC's to the Pro board on all my builds and never had a problem, I was also wondering what the benefit is of just having one power wire connected besides reducing the redundancy to the main board?
michael f is offline Find More Posts by michael f
Old Apr 22, 2012, 09:52 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
It's more to make setting up new quads easier. Especially with 8 motors. There really isn't ever a need to re-calibrate.
Site Sponsor
Old Apr 22, 2012, 09:58 PM
Adidas4275's Avatar
Joined Mar 2011
good to know, i like my 6 way Y that I made up
For Sale Mini Vbar 5.2 with 1 spektrum sat & cables (4.0 black upgrade to 5.2 software) SOLD skyking1 Aircraft - General - Radio Equipment (FS/W) 2 Feb 08, 2012 11:46 PM
For Sale Mini Vbar 5.2 with 1 spektrum sat & cables (4.0 black upgrade to 5.2 software) skyking1 Aircraft - Electric - Helis (FS/W) 0 Feb 07, 2012 05:28 PM
Discussion calibrate ESC with board & 3.1.515 software gweleps Hoverfly Technologies 4 Dec 20, 2011 11:53 AM
Discussion How do you calibrate ESC with S-bus? milo12 Multirotor Talk 5 Oct 19, 2011 09:25 AM
Help! calibrate ESCs with throttle or use fixed setting? JZSlenker Hoverfly Technologies 3 Sep 22, 2011 04:18 PM
