Old Apr 15, 2012, 08:03 PM
Svede is offline
Find More Posts by Svede
United States, CA, Lemoore
Joined Nov 2008
Little Airboat
Been working on this for a few days, made out of blue foam, plywood and fiberglass. Goes like snot and the electronics don't stay dry. Fortunately I have a few more ar6400's, I think I'll try some corrosionX on it and see if it'll last more than two minutes .
Micro Airboat (1 min 7 sec)
Svede is offline Find More Posts by Svede
Old Apr 17, 2012, 03:25 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
to be technical about it.....its not the water that is the problem.ive run electonics in pure water and they work fine. the problem is with the minerals and contaminents that short out the traces on the board. the ar6400 is hard to water proof. usualy what i do is use some cool melt hot glue and do the board that way. the ar6400 is hard cuz the servos. try petrolum jelly. might work.
nemoskull is offline Find More Posts by nemoskull
Old Apr 26, 2012, 05:27 AM
WallaceConway is offline
Find More Posts by WallaceConway
United States, OR, Tigard
Joined Aug 2011
Waterproofing electronics...
Years ago(20 plus), my nephew and I were battling the same issues keeping the electronics dry and from corroding. We dipped the receiver pack and servos in ATF. After that we never had ANY issues with moisture or corrosion... And things kept working fine...FYI
WallaceConway is offline Find More Posts by WallaceConway
Old Apr 26, 2012, 10:23 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
I have used clear Krylon spray for years.
Remove the receiver from case hold by the antena and spray untill the paint runs off. let dry for 2-3 days.
You will have to clean the connections.
For a servo open and spray the board the same as the receiver. When dry reassemble using light grease under the output gear and RTV between the case sections and seal the wire leads.
Most of my 114 boats are done this way. I have not lost a receiver in over 35 years.
GILL RC is offline Find More Posts by GILL RC
Old Apr 26, 2012, 04:47 PM
nemoskull's Avatar
Joined Sep 2009
ATF?! that is funny! never thought of that.
Old Apr 29, 2012, 03:51 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
spraying anything on an ar6400 would not be a good idea as the resistive strips for the servos' feedback will get coated and mess up the movement. it would be much better if you could tape up the hatch to keep the water out of the hull. only other option would be a separate receiver like a Deltang or one of the HK oranges. then you could coat it in waterproofing, or a small balloon etc.
it does look like it goes very well, must have a good power to weight ratio
derk is offline Find More Posts by derk
Old Sep 03, 2012, 10:51 PM
Archi Bald is offline
Find More Posts by Archi Bald
United States, TN, Crossville
Joined Aug 2012
12 inch Brushless airboat
My Home Made 12 inch Brushless RC Airboat With 3s 11.1V Lipo Verry Fast (7 min 58 sec)
Archi Bald is offline Find More Posts by Archi Bald
Wanted Help help plzzzzz looking for Foam plans for an RC Airboat Madd_Trucker Boats (FS/W) 6 Apr 28, 2012 10:09 AM
Idea mini aquacraft aligator airboat:eek: dostacos Dock Talk 5 Mar 22, 2012 12:34 PM
Sold AquaCraft Mini Alligator Tours Airboat EP RTR used jeepcrawler08 Boats (FS/W) 0 Mar 18, 2012 01:43 AM
Wanted Nitro Airboat/ Swamp boat Curt308 Boats (FS/W) 0 Mar 09, 2012 05:49 PM
