Apr 16, 2012, 08:41 AM
Frederick, MD
Joined May 2002
Originally Posted by 2lo
I have 10s that I've had for about 3 yrs. works great.
I'm now running two A123's in a 100cc setup. with a failsafe receiver. I've made up my own charge harness with servo style connectors just to eliminate the hassle of dragging the node board into plane during charging.
OK strange part her. I can charge either battery with either harness going through the balance and( banana jacks) charge leads that come off the battery.(not the large discharge leads) one at a time. I can do this with or without the main discharge leads plugged into the receiver. But cannot do both battery's this way at the same time.
While trying to charge two batteries at the same time if I leave the main battery (large discharge leads) hooked up to the receiver, I get - "2 connection error" message. If I disconnect the main (large discharge)leads from the receiver, i get "plug not installed". If I go ahead and install the plug I can then charge both battery at the same time through the balance taps.
I just want to be able to charge both batteries at the same time.
Hi,
If you can, take a continuity reading between the two center banana jacks, this is the positive of channel 1 to the negative of channel 2, it should read a closed circuit. If it reads open, the fuse is blown and must be replaced. If you are capable of soldering, I can send you the instructions for changing this out. You can email me at howard@fmadirect.com.
