Old Apr 15, 2012, 03:26 PM
Huck Norris is offline
Find More Posts by Huck Norris
Joined Apr 2011
4.0 update problem
I have been trying to update to 4.0 ever since the firmware was rereleased.
I install 4.0 on both HFP(black board) and GPS. Recalibrate Temp, ACC, and Compas. Recalibrate throttle range. Lower Gain to 40% Read to Fly.
I try and take off and it looks good at first but there is no rudder. The quad just starts to flat spin to the right. I try to trim but no luck. Rudde has no athority.I can reinstall 3.00 and the quad flies great (all trims @ zero) This is the 3rd time I have reflashed to 4.0 with the same strange results. What could I be missing.
next level quad frame
cobra 2826\12
turnigy 60 amp
hfp black board
hf gps
4s 4000 lipo
cheers
Huck
Huck Norris is offline Find More Posts by Huck Norris
Old Apr 15, 2012, 03:30 PM
Joined Apr 2011
flight log here
Old Apr 15, 2012, 04:58 PM
JZSlenker is offline
Find More Posts by JZSlenker
JZSlenker's Avatar
United States, PA, Harrisburg
Joined Aug 2011
Did you uninstall both the firmware and setup clients from your computer? You need to download the newer versions of the software (both). Then update your firmware and pick your configuration type in the setup client. Then do your calibrations. You will need to adjust all of your gains again for version 4.
JZSlenker is offline Find More Posts by JZSlenker
Old Apr 15, 2012, 08:48 PM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
Firstly, make sure your rudder channel is working in the setup client.
If it is then it could be an issue with your setup running out of yaw authority. Essentially the newer firmware handles yaw limiting better which is important if you don't want to flip. To fix this, you need to rotate your motors the opposite direction of the spin you are seeing.
cobra 2826\12
turnigy 60 amp
hfp black board
hf gps
4s 4000 lipo
cheers
Huck
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Apr 15, 2012, 09:24 PM
Joined Apr 2011
I think I found my problem.
I was caliberating the ACC, TEMP and Compas BEFORE I had chosen my motor layout.
I suppose a flying machine does not like that.
Thanks for the time
Going to the test field tomorrow AM.
cheers
Mike Hagadorn
Huck
Old Apr 15, 2012, 10:38 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
good find! I am sure you are not the only one that it has happened to.
I got some good use out of your MKTR today Huck!
Ill post the video soon.... still editing
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 16, 2012, 03:50 AM
elossam is offline
Find More Posts by elossam
Joined Feb 2006
Thanks for the time
cheers
Mike Hagadorn
Huck
That was the only change you did and now itīs working? it has not much sense the calibration is related to the flying configuration you choose. In any way will do it like you not to get any risk but could be fine to know from HF if it has any relation or not.
elossam is offline Find More Posts by elossam
Old Apr 16, 2012, 10:52 AM
Earl E Adobtr is offline
Find More Posts by Earl E Adobtr
USA, CA, Mountain View
Joined Dec 2008
Thanks for the time
cheers
Mike Hagadorn
Mike, Check your esc's carefully. Sometimes the solder pads leading to the motors start to detach partially. Hard to see or find and only intermittently causes the yaw problem. For some reason it exhibits on the newer firmware more readily. I finally replaced all esc's as a desperation move and that's when I found the loose solder pad. HF could chime in here but I don't think calibrating before you set config would make a difference.
Earl E Adobtr is offline Find More Posts by Earl E Adobtr
Old Apr 16, 2012, 05:47 PM
Joined Apr 2011
Update.... Problem is not resolved. Tried to fly today Too windy out side so the parking garage would be great to set my AL trims. Started flying at 25 gain and was flying smooth. I upped the gain a bit to about 40 still smooth. Throttle seems a bit more sensitive with 4.0 for me. I was flying about 1-2 minutes and all the sudden I lose yaw control and the quad starts spinning to the right again. I land drop gain back to 25 take off and I regain yaw for a brief period then lose it again. I change batteries for a new lipo try to take off and no rudder control at all quad spinning to the right. Remember this is a quad that has over 50 flights on it and flies great with the previous 3.6 firmware.
I am using Turnigy Plush ESC and all the brains are covered by heat shrink.
thanks
Old Apr 16, 2012, 08:21 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Dang, we need to get your issue fixed so we can get some more awesome videos! Although, I don't have any ideas, sorry...
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Apr 17, 2012, 02:38 AM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
Mike,
You need to to do a few things.
1. Move your throttle trim all the way down.
2. Set your throttle endpoints to +-100%
3. Re-calibrate your ESCs manually using the RX.
4. Fly
If you are still having trouble with yaw, rotate your motors in the opposite direction the multirotor spins when this happens.
This information is here:
https://hoverflytech.zendesk.com/ent...ng-yaw-control
thanks
Site Sponsor
Old Apr 17, 2012, 12:11 PM
Adidas4275's Avatar
Joined Mar 2011
George, if we are using square booms and not round booms do you have a suggestion on how to rotate them?
I do not currently have this issue, but it has been something that I have not had to deal with when using Rusty's frame with round 5/8" booms.
Old Apr 17, 2012, 01:46 PM
Joined Apr 2011
yeah I am rocking square booms on my quad. I guess you would go with chims.
Old Apr 17, 2012, 06:35 PM
canopus1970 is offline
Find More Posts by canopus1970
Sokratis
canopus1970's Avatar
Ελλάς, Κρήτη, Ηράκλειο
Joined May 2009
This is that you need ...
https://www.mikrocontroller.com/inde...108c0c5c869ef0
canopus1970 is offline Find More Posts by canopus1970
Old Apr 17, 2012, 09:17 PM
Adidas4275's Avatar
Joined Mar 2011
i have seen those before.... i think I would need to make something. I use RC-Carbon frame which I dont think i could use those sims like they are. Good idea, perhaps I will do some more looking at shimming my motors.
Discussion OPTIC 6 SPORT 2.4 - Firmware update V1.02(0) A.T. Hitec/Multiplex USA 4 Apr 11, 2012 07:24 PM
Discussion Problems with Futaba T8FG and 4.0 Jeos72 Hoverfly Technologies 3 Apr 11, 2012 03:36 PM
Alert OPTIC 6 SPORT 2.4 - Firmware update V1.02(0) A.T. Radios 0 Mar 05, 2012 02:58 AM
Discussion Pheonix Simulator update 4.0.F Problem Cfly100 Simulators 2 Feb 29, 2012 04:41 PM
