Old Apr 15, 2012, 03:15 PM
giuseppe10091989 is offline
Find More Posts by giuseppe10091989
giuseppe10091989's Avatar
Joined Aug 2011
Cool
Dead of my grafas from 6500 feet
Guys,
the dead of the my grafas..
The crash from 2000meter - 6500 feet (INTEGRAL VIDEO)
on 13m:25s through the clouds
on 21m:50s broken of the wing
http://www.youtube.com/watch?v=o-2g8...B5JonwUB2jz7w=
giuseppe10091989 is offline Find More Posts by giuseppe10091989
Old Apr 15, 2012, 04:01 PM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
Impressive altitude. So it was a wing failure caused by?........out of control dive?
rcbif is offline Find More Posts by rcbif
Old Apr 15, 2012, 04:06 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
I am curious of the crash scene, did you recover whats left?
metalfred is offline Find More Posts by metalfred
Old Apr 15, 2012, 05:52 PM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
It looks like the covering on the top of the left wing came loose at the trailing edge at about 75kph during the nose over. Recovery would have been impossible because of the flapping covering.
Sorry about your loss. Can you think of anything that would have compromised the covering in that location?
Like metalfred asked, was any of the gear recoverable? I sure hope so!
Rob
camship is offline Find More Posts by camship
Old Apr 15, 2012, 06:39 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
ouch
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Apr 15, 2012, 06:47 PM
quix-fz is offline
Find More Posts by quix-fz
Basel, Switzerland
Joined Mar 2008
half of the left wing broke away (also tearing apart the covering on the rest of the wing) because of too much speed&load in that dive.
nice video!
quix-fz is offline Find More Posts by quix-fz
Old Apr 16, 2012, 10:51 AM
Joined Aug 2011
You know that I arrived with the zephyr at 2800 meters. (9200 feet)
yes wing failure,
the next glider will be fully of fiberglass.
I have them, place asap...
for gear everything works, except for batteries dead and motor destroyed.
instead pixim, gopro, tx vd, ezosd, rx uhf, also antenna cp SPW are working perfectly.
Rob
batteries dead and motor destroyed... instead pixim, gopro, tx vd, ezosd, rx uhf, also antenna cp SPW are working perfectly.
nice video!
very thanks quix!
Old Apr 16, 2012, 11:22 AM
Joined Aug 2011
Old Apr 16, 2012, 11:29 AM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
Sorry for the loss of your plane but thanks for posting the video.
You're lucky the field was soft and the battery didn't catch fire. A few years ago I had a plane nose in from a couple hundred feet on to rocks and the force of the impact caused the battery, esc and motor to try and occupy the same spot. Big short and everything went up in smoke.
milo12 is offline Find More Posts by milo12
Old Apr 18, 2012, 12:36 PM
Joined Aug 2011
next glider model
Guys,
I'm looking for a glider that does not have speed limits. I would go to my next model:
1) Big Ceres E by baudismodel http://www.baudismodel.com/big-ceres-technical-data.php
2) Supra-E by kennedycomposites http://www.kennedycomposites.com/suprae.htm
3) Xplorer E by nanmodels http://www.nanmodels.com/
4) open to other models (suggested by you)
In your opinion which the much resistant? and which has a large fuselage, so I can insert large battery packs for FPV long range.
Old Apr 18, 2012, 07:24 PM
henkvdw is online now
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Seems as the motor/prop kept spinning after the failure.
Was it spinning by itself or did you not cut the power?
henkvdw is online now Find More Posts by henkvdw
Old Apr 18, 2012, 07:45 PM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
I would look at a cross country sailplane. They are big & fast, but not cheep.
NO aircraft has no speed limit, well maybe a DS sailplane.
I've only had my fpv plane up to 3600 meters
Pixturethis is offline Find More Posts by Pixturethis
Old Apr 18, 2012, 09:25 PM
David22 is offline
Joined Apr 2008
this one would be a great choice
one I have and about to set up for fpv
lots of room for business hehehe
very sporty and fast and glides well
http://www.soaringusa.com/Experience-Pro-E.html
lots of power as well
Experience Pro E watt and amp. testing (0 min 23 sec)
here is a video of non fpv testing
xperience pro maiden, ran out of video but landed no problem (2 min 22 sec)
this is the ultimate fpv glider no doubt anyone has taken fpv to this level before
I will be the first hehehe
unbreakable in the air
Originally Posted by giuseppe10091989 View Post
Guys,
Old Apr 19, 2012, 12:46 PM
Joined Aug 2011
the propeller spins alone in the opposite direction of pull. Cut the power, the air do turn the prop in reverse.
You can see the amperage rating is 1A. That is only tx video osd and etc. ..
Old Apr 19, 2012, 12:48 PM
Joined Aug 2011
https://vimeo.com/10509501
here is a video of non fpv testing https://vimeo.com/10599928
beautiful but at what speed max can resist it... for example 180km/h with base wind of 16-19 km/h it can?
Video Camera drops 100 feet from my Bixler! nonamerc Electric Plane Talk 0 Apr 05, 2012 01:40 PM
My school from a few hundred feet CAFplanekid Aerial Photography 9 May 10, 2005 10:23 PM
Voyager Flying at 6500 Feet cactus Electric Heli Talk 9 Nov 22, 2003 01:23 AM
My Dandy plummeted from 300 feet! blakbird Parkflyers 4 Apr 21, 2003 02:02 PM
how do i get my zagi from being stuck in a tree 50 feet high?? compuatic Electric Plane Talk 12 Jun 09, 2002 09:36 PM
