Old Oct 06, 2012, 09:09 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Bob, I am sure you posted this already, what is a Clark Y airfoil?
Harry
Got to add this, flying scale, I don't much need to go past 1/4 throttle with my set up.
Harry H is offline Find More Posts by Harry H
Old Oct 06, 2012, 09:55 PM
bracketman is online now
Find More Posts by bracketman
United States, OH, Delaware
Joined Jan 2011
Originally Posted by Harry H View Post
I forgot to add, the Camel likes to climb with any more than 1/4 power. I think this is normal.
Harry
On my Waco I mixed in a small amount of down elevator with the throttle to counter act that. It worked out quite well.
bracketman is online now Find More Posts by bracketman
Old Oct 07, 2012, 09:38 AM
Bob Hunt is offline
Find More Posts by Bob Hunt
Mustang Fever
Joined Jan 2005
Harry:
The Clark Y is a really old, flat bottom airfoil. It was used on the Spirit of St. Louis and the Lockheed Vega. Has a very good lift to drag coefficient when scaled down for models, and the flat bottom makes it easy to build wings. Used a lot in model planes.
Here's a snap of Snoopy's new stab under construction, and an illustration of the perfect touchdown attitude- tail just slightly low, power a little above idle.
Bob Hunt is offline Find More Posts by Bob Hunt
Old Oct 07, 2012, 10:00 AM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Thanks for posting that Bob.
Harry
Old Oct 07, 2012, 12:41 PM
AndyCross is offline
Find More Posts by AndyCross
Joined Nov 2010
Interesting about the Y section.
Will have look into this a bit more.
Cracking weather here in the uk today, hardly any wind.
Flew the pup 7 times today. Each flight gets better and better. Takeoffs are getting better now and landings are so easy. No nose overs now at all and can steer her right to my feet. Absolutely brilliant to fly.
White scarf flapping in the wind just about sets it off.
Starting to input rudder in turns a little to help her round but she doesn't need hardly any at all. The diff on the ailerons must be sufficient.
Sorted out my constant climbing issue as well., ......Elevators were not dead level with each other. One was slightly higher than the other causing the lift.
Now corrected. Handsfree no prob now on half power.
Getting 14-18 mins before power starts dropping low and putting back 3800mah so really pleased with this.
Must get so picks for you to see her.
Lovely plane to fly.
AndyCross is offline Find More Posts by AndyCross
Old Oct 07, 2012, 12:42 PM
Joined Nov 2010
sorry meant to say "camel"
Old Oct 13, 2012, 01:24 PM
Joined Nov 2010
pictures of my camel set as promised.
Description:
Description: Pulso 4130-12 & 60amp scbec
Description:
Description: servos moved 4" forward
Description:
Description: T peice and lipo strap to keep the 6s stationary and secure
Old Oct 13, 2012, 01:33 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Andy, how did you get away with no extra weight in the nose??
Harry
Old Oct 13, 2012, 02:55 PM
Joined Nov 2010
Hi Harry,
If you look close you'll see about 5oz of the supplied lead weight zipp tied under the engine mount.
Together with moving the servos and lipos forward, swapping the rear rudd/elev rods for carbon ones it only needs 5oz up front.
It balances spot on and tipps the scale at 8lb 5oz.
I read on this website that the weight in the original position in the supplied box makes the landing very difficult and has like a pendulum effect while your trying to steer it on the ground.
I've not nosed it over yet !!!
Old Oct 13, 2012, 06:48 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
I did not see that. No nose overs!! Cheers!!
Harry
Old Nov 28, 2012, 05:47 PM
JustFlyIt is offline
Find More Posts by JustFlyIt
JustFlyIt's Avatar
United States, MD, Laurel
Joined Sep 2004
Ugh...
I have read the thread and now I need to change my G-20 Zenoah powered Camel to electric.
I have gotten rid of all my glow and have a couple of gas engines left but am really enjoying my electric flying.
This Camel is going electric with maybe a sound system.
JustFlyIt is offline Find More Posts by JustFlyIt
Old Nov 28, 2012, 10:30 PM
Bob Dunlop is offline
Find More Posts by Bob Dunlop
Fokker,I didn't even kiss her
Bob Dunlop's Avatar
United States, VA, Fredericksburg
Joined Apr 2011
Here are some pics of my H9 Sopwith and D7
Both Eflite Power 60
Pics taken by my good friend Salam
http://www.rcgroups.com/forums/showp...ostcount=11085
Bob Dunlop is offline Find More Posts by Bob Dunlop
Old Nov 30, 2012, 12:34 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
What size is the Fokker?
How is the aileron authority?
Much more detailed than my Global Hobby D-VII, and has the ailerons in the right place.
CNY_Dave is offline Find More Posts by CNY_Dave
Old Nov 30, 2012, 03:28 PM
Bob Dunlop's Avatar
Joined Apr 2011
Mine is the Hangar 9 Fokker ,it has a 65" wing and aileron authority is great
Both planes fly really nice and easy and land well .
The Fokker Dr1 that I'm working on has a 60" wingspan...hope it flys just as nice
Old Nov 30, 2012, 04:38 PM
CNY_Dave is offline
Joined Sep 2010
9 lbs! Mine's a baby next to it.
I just read this:
http://www.rcgroups.com/forums/showthread.php?t=916904
and saw this:
"At near-stall speeds the Fokker does suffer from its full-sized counterpart’s faults as well. The smallish rudder of the original is accurately reproduced in the Hanger 9 model, and at slow speeds the tail can drift with crosswinds just like the original. What this means is that crosswind approaches are best made at speeds comfortably above stall speed."
Which is exactly what I see with mine, but I thought it was just me sucking at crosswind landings (which I had down pretty good on my trainer).
For Sale Hanger 9 Sopwith Camel z1nonlyone Aircraft - Fuel - Airplanes (FS/W) 5 Dec 07, 2007 05:05 PM
For Sale Hanger 9 Sopwith Camel coloradoz Aircraft - Fuel - Airplanes (FS/W) 5 Oct 25, 2007 06:11 PM
For Sale Hanger 9 Sopwith Camel fudi50 Aircraft - Electric - Airplanes (FS/W) 0 Dec 19, 2006 01:51 PM
Discussion hanger 9 Sopwith Camel fudi50 Power Systems 5 Oct 02, 2006 05:14 PM
Discussion hanger 9 Sopwith Camel fudi50 Electric Motor Design and Construction 1 Sep 15, 2006 10:02 PM
