Old May 30, 2012, 09:01 AM
Davey NY is offline
Find More Posts by Davey NY
Ya gotta land eventually...
Davey NY's Avatar
United States, NY, Mahopac
Joined Sep 2010
Great idea. Much better i think anyway than punching through the firewall. All cgforward
Davey NY is offline Find More Posts by Davey NY
Old May 30, 2012, 09:12 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
Originally Posted by AndyCross View Post
Hi Harry, What size are they.....5" or 5.5"
Andy, I used the 5 1/4" ones, they are the exact same size.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWAB4&P=7
Harry
Harry H is offline Find More Posts by Harry H
Old May 31, 2012, 02:45 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
Hey guys, I am looking for one of these gems, Dave/ZEE
zeezee is offline Find More Posts by zeezee
Old May 31, 2012, 03:05 PM
Bob Hunt is offline
Find More Posts by Bob Hunt
Mustang Fever
Joined Jan 2005
Dave-
There aren't any on ebay right now, but if you're really desperate you can get all the pieces to put one together from Horizon for only 630 bucks or so.
Bob Hunt is offline Find More Posts by Bob Hunt
Old Jun 01, 2012, 11:39 AM
AndyCross is offline
Find More Posts by AndyCross
Joined Nov 2010
just getting to grips with the lower wing installation. What a complete faff.
Don't know how long the tapped 4-40 holes in the wing tubes are going to last , with constant assembly/dis-assembly for the car.
Poor design.
AndyCross is offline Find More Posts by AndyCross
Old Jun 01, 2012, 01:47 PM
Bob Hunt is offline
Mustang Fever
Joined Jan 2005
Andy: If you bore and tap them through both sides of the tube, they last OK. I leave the tube bolted into one wing panel sort of permanently. The tubes are still available from Horizon. I've been thinking about getting one as a backup, which will insure that my 4 year old one will never fail.
Old Jun 01, 2012, 05:44 PM
Joined Nov 2010
Hi Bob,
Yes thought of that and loctited one wing panel as you say. If I can get it in the car with both lower wings in then that's a bonus.
I've got spare tubes that will fit , just wish i'd got something with a thicker bore so there's more metal to tap into.
We've no spares availability at all in the UK so its direct from the U.S.
Old Jun 02, 2012, 12:15 PM
Joined Nov 2010
Just epoxed to top wing halves together. Gone together nicely and square with no gaps.
The only prob is while the 30min expoy is drying i stood back to admire it and noticed the one wing with the "U" on it is a different shade of green to the other.
Is it suppose to be or is this an error.
Andy
Old Jun 02, 2012, 12:30 PM
Bob Hunt is offline
Mustang Fever
Joined Jan 2005
Andy:
They probably used covering from two different rolls. The stuff does tend to vary a little bit from roll to roll.
Old Jun 02, 2012, 12:33 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
I bought a roll of the green for repairs an it is not even close the the color.
Harry
Old Jun 02, 2012, 12:56 PM
Bob Hunt is offline
Mustang Fever
Joined Jan 2005
This is the stuff they supposedly used:
http://www.horizonhobby.com/products...e-drab-HANU904
Matched OK on mine, at least so far. Haven't bought any in awhile.
Old Jun 02, 2012, 02:35 PM
Joined Nov 2010
Well its nearly finished. Wings are on. Aileron Servos are standard size futabas but high torgue jobbies. Just the tail feathers and rigging to sort.
Im pleased to say Auw is 8lb 4 oz with everything on. CofG is set at 3.75 and its balances perfectly straight, so I reckon 2-3oz of lead behind the dummy engine will get it slightly nose heavy.
Old Jun 03, 2012, 10:58 AM
Joined Nov 2010
Was expecting some brass tabs to be missing for the rear tailplane wires, but everythings there and correct ??.
Not overly confident and the tab of the fin the glues in the stab, so have pinned with Ali tube to make it more rigid.
Just setting c/f control rods to correct length and then will epoxy the ends on and pin as well to be doubly sure. Need to cyno a couple of guides in the fus to accommodate the extra length of control rod.
She sure looks nice and with the xoar 16x8 spinning she looks lovely.Surprised the wings lined up pretty well, just needed the cabanes to be tweaked a little but otherwise they went on ok.
Was a little concerned about getting in to access the lipos with the top wing on but no probs and it all works quite well.
Old Jun 03, 2012, 11:29 AM
Davey NY is offline
Davey NY's Avatar
Joined Sep 2010
Harry
I have since gone with doculam. 500 ft roll aka lifetime worth for 30 shipped. Goe zonclear and then paint to match.
My sopwith will be lightened and re covered with this stuff in black Maria style.
Just a thought...
David
Old Jun 05, 2012, 02:05 PM
Joined Nov 2010
Is there an easy way to tension the rear tailplane wires or is it just "on and off" until you get it just right. Its seems only able to adjust the wires once you disconnect from the brass fitting???
For Sale Hanger 9 Sopwith Camel z1nonlyone Aircraft - Fuel - Airplanes (FS/W) 5 Dec 07, 2007 04:05 PM
For Sale Hanger 9 Sopwith Camel coloradoz Aircraft - Fuel - Airplanes (FS/W) 5 Oct 25, 2007 05:11 PM
For Sale Hanger 9 Sopwith Camel fudi50 Aircraft - Electric - Airplanes (FS/W) 0 Dec 19, 2006 12:51 PM
Discussion hanger 9 Sopwith Camel fudi50 Power Systems 5 Oct 02, 2006 04:14 PM
Discussion hanger 9 Sopwith Camel fudi50 Electric Motor Design and Construction 1 Sep 15, 2006 09:02 PM
