Old Apr 15, 2012, 10:31 AM
vernon7026 is offline
Find More Posts by vernon7026
Return of the Warlord
vernon7026's Avatar
United Kingdom, England, Wallington
Joined Aug 2009
3DHS Osiris 47
Hey all
I have a Osiris by 3dhs, i have installed a Hitec HS-82mg Servo for the rudder and i am using pull pull.
My problem is, when move rudder to one side(using Tx) the rudder moves perfectly to centre, when i go to the other side, it does not centre, i have tried sub trim etc etc (DX7)
Any ideas what issue could be
vernon7026 is offline Find More Posts by vernon7026
Old Apr 15, 2012, 10:36 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
take off the tail wheel bracket and see if it stops.
Irg is offline Find More Posts by Irg
Old Apr 16, 2012, 12:10 PM
vernon7026's Avatar
Joined Aug 2009
I did release the tail wheel bracket, but still the rudder does not centre on one side, if i put in sub trim to correct it, it will centre, but then wont centre from other direction,
I have also noticed that the bracket for tail wheel is not quite correct ? the wire is not quite close enough to the pivot point ?? Could this be left off, and i can make a longer bracket out of carbon fibre and just have the pivot point hole further out ??
I am new to these , please forgive me
Old Apr 16, 2012, 01:02 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
pull pull cables tight at center?
jsmith285 is offline Find More Posts by jsmith285
Old Apr 16, 2012, 01:36 PM
vernon7026's Avatar
Joined Aug 2009
when you say Centre, where about , half way down the Fuselage ??
Old Apr 17, 2012, 11:04 AM
dumbthumbs53 is offline
Find More Posts by dumbthumbs53
Albany, OR
Joined Jul 2009
I think he means when the servo is at true center. Both cables should be snug but nowhere near taught. Off hand, It sounds like you might have one side that is significantly tighter than the other.
dumbthumbs53 is offline Find More Posts by dumbthumbs53
Old Apr 17, 2012, 11:09 AM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
If both cables are tight and the tailwheel bracket is not causing any binding then it could easily be the servo itself that is not centering..
I have lots of time on Hs82mg and they are terrible servos when it comes to centering. It wouldnt surprise me at all if it was the servo itself causing the issue.
joesmith285 is offline Find More Posts by joesmith285
Sold 3DHS 47" Osiris diggity2424 Aircraft - Electric - Airplanes (FS/W) 5 Apr 19, 2012 09:39 PM
Build Log 3DHS 47" Osiris jonathan7x70 High Performance 3 Feb 15, 2012 04:57 PM
Sold 3DHS 47" Osiris RED RTF DuaneV Aircraft - Electric - Airplanes (FS/W) 1 Dec 14, 2011 07:55 PM
Sold 3DHS 47" Osiris NIB LPU dawhale Aircraft - Electric - Airplanes (FS/W) 1 Oct 22, 2011 05:20 PM
