Old Apr 15, 2012, 09:13 AM
djlewis is offline
Find More Posts by djlewis
Joined Apr 2012
CB180Z Tail drive shaft problems
Is there an easy way to remove and replace the keyed plastic gears onto the fiberglass drive shaft on the Walkera CB180Z Helicopter without breaking the shaft?
They are press fitted onto the shaft and hard to remove and replace.
Any suggestions would be appreciated.
djlewis is offline Find More Posts by djlewis
Old Apr 15, 2012, 10:02 AM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
I have the same issue, I think a pinion puller might be the best way. I have a gear to replace on my 4f180 and its the same tail drive as the cb180z so I feel your pain. Also the shaft is carbon fiber not fiberglass so its a little tougher than you would think. Try a pinion puller and maybe some light oil to help it slide off.
afloyd82 is offline Find More Posts by afloyd82
Old Apr 19, 2012, 05:57 PM
djlewis is offline
Joined Apr 2012
I finally got the new tail shafts and I buffed them down with some very fine sand paper and coated the ends with oil and wiped the oil off. The new gears went on quite well without having to put a lot of pressure on them.
I guess that will be my technique from now on. Thanks for your reply.
Help! Belt Drive vs Shaft-Drive kingofking1 On-road Cars 17 Jan 20, 2012 07:52 AM
Discussion Shaft drive or Belt Tail Torch8 Mini Helis 5 Sep 15, 2011 02:57 PM
Sold New Trex 500 belt tail case with metal hex pins + tail drive gear + tail shaft $25 Tomy. Aircraft - Electric - Helis (FS/W) 0 Jun 21, 2011 02:57 AM
Build Log DIY brushless submicro FP with shaft drive tail (originally CP belt tail 4#3) oobly Micro Helis 178 Aug 24, 2009 04:15 AM
Discussion belt drive or shaft drive for the tail microhelirc Micro Helis 15 Dec 22, 2005 04:20 PM
