Old Oct 15, 2012, 05:45 AM
medroller is offline
Find More Posts by medroller
Australia, QLD, Townsville
Joined Jul 2011
I should have mine by the end of the week. Hopefully have it in the air on the weekend. never flown this type of plane before. I reckon it might put a bit of excitement back into some flying.
I'll give you lot my expert opinion next week
medroller is offline Find More Posts by medroller
Old Dec 06, 2012, 05:11 PM
OldeMan is offline
Find More Posts by OldeMan
Faster is Better
OldeMan's Avatar
United States, AZ, Gilbert
Joined Jul 2012
I just saw this thread... sorry for the delay. I think most Dynamic-S owners are either here:
http://www.rcgroups.com/forums/showthread.php?t=1782069
or here:
http://www.rcgroups.com/forums/showthread.php?t=1194905
(keep in mind that the Hype Wow, ST Models Blaze, and Dynamic-S are *very* similar to each other)
I've cut out the foam "cheeks" inside of my Dynamic-S bay... and I'm able to slide a Turnigy 2450 way back under the wing. This leaves *just* enough room for a 6-CH Rx behind it. The plane balances beautifully... and it flies like a dream. For safety's sake, I added a little hot-glue dam, back by the receiver, to prevent further battery movement that way.
This leaves the factory installed velcro strip in place... and I've been able to borrow my son's 2200 and 1800 batteries and stick them in without trouble. I just velcro them further forward to keep the CG.
Frankly, I don't notice any difference in flight characteristics between the smaller and larger sizes. The plane doesn't seem to notice either way.
OldeMan is offline Find More Posts by OldeMan
Old Dec 06, 2012, 05:16 PM
OldeMan is offline
Faster is Better
OldeMan's Avatar
Joined Jul 2012
Originally Posted by OldeMan View Post
... I've cut out the foam "cheeks" inside of my Dynamic-S bay... and I'm able to slide a Turnigy 2450 way back under the wing. ...
To be clear -- I don't mean to imply this is an easy fit: It's very snug and requires a "creative" insertion technique. (Maybe I should post a little video? If there is interest, I'll give that a try.)
Old Feb 05, 2013, 04:19 PM
Terra is offline
Find More Posts by Terra
Terra's Avatar
Australia, VIC, Melbourne
Joined Jun 2012
I'm running a 2200 4s nano tech and its tight but fits.
Yea stock esc is fine for a stock setup as recommended, but if your looking at doing any upgrades it should be the first thing you replace.
Terra is offline Find More Posts by Terra
Old Feb 10, 2013, 01:06 PM
Kipling is offline
Find More Posts by Kipling
Kipling's Avatar
United States, CA, Isla Vista
Joined Dec 2012
Originally Posted by S2000442 View Post
Where did you get the prop? My dynamic s came in and the metal hub that attaches to the main motor was in pieces so the prop fell off as I was putting it together! Thanks Hobby King! Any recommendations on other props etc I can use with this model? Would a radian prop and some way to attach to the stock motor work? Sorry for the noob questions
Exact same thing happened to me! Broken prop shaft on arrival (along with both wing tips bent & cracked). Pretty disappointing!
Kipling is offline Find More Posts by Kipling
Old Apr 13, 2013, 10:08 AM
stevet1 is offline
Find More Posts by stevet1
Joined Jun 2012
A 2200 mah battery works great. I lay mine wide side down. There is a little foam cutting necessary. It's easy. I push the battery all the way back next to the receiver for a balanced CG.
stevet1 is offline Find More Posts by stevet1
Old Sep 05, 2013, 12:50 AM
herropreeze is offline
Find More Posts by herropreeze
Joined May 2012
Originally Posted by Lars N View Post
Hi.
Does anyone have any experience on the Durafly Dynamic-S fra Hobbyking. Thinking about ordering one and I am wondering if the 3s 2200mah battery pack will fit since Hobbyking is recommends the 3S 1800 batterypack.
it fits :-)
herropreeze is offline Find More Posts by herropreeze
Old Oct 10, 2013, 01:13 AM
Myko is offline
Find More Posts by Myko
fly 1 day, repair the next 3
Myko's Avatar
United States, CA, San Mateo
Joined Dec 2012
Did anyone have any troubles with the servo links on the v-tail? Mine seen to be hitting the sides.
Myko is offline Find More Posts by Myko
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
Discussion Regarding 4 Blade props for Durafly Mustang and Dynam Mustang P-51 flyby Electric Warbirds 3 Mar 03, 2012 03:56 PM
Discussion Buddy Code for HobbyKing - Durafly Micro Critical Mass??? ptflyer Micro Ready-to-Fly 0 Feb 08, 2012 10:10 PM
