Old Apr 14, 2012, 11:11 PM
FlyValue is offline
Find More Posts by FlyValue
USA, CA, La Canada Flintridge
Joined Dec 2003
how to install CA hinges
Hi folks,
I have been flying for years but fairly new to building. This is the first stick build I have done where I need CA hinges. Could you direct me to a how to on getting a good cut into the balsa to instal the hinges? What is the best tool to insure a straight cut. The instructions seem to think doing it is a given...
Thanks for your help,
FlyValue is offline Find More Posts by FlyValue
Old Apr 14, 2012, 11:50 PM
dmcquinn is offline
Find More Posts by dmcquinn
dmcquinn's Avatar
United States, MO, Chesterfield
Joined Jan 2004
Just use an exacto blade. force it into the surface and wiggle it back and forth to make the cut. Do not remove any material. Just slit the wood. Make the slit wider than the width of the hinge.
Force the dry hinges into both surfaces. Completely assemble the part (e.g. rudder) to the airframe (e.g. Fin). Apply 4 or 5 drops of super-thin CA glue to the joint from both sides. The glue will wick up into the hinges and they will never come back out.
dmcquinn is offline Find More Posts by dmcquinn
Old Apr 15, 2012, 12:16 AM
cynjon is offline
Find More Posts by cynjon
Retired USAF
cynjon's Avatar
USA, SD, Piedmont
Joined Jul 2005
The only thing I'd add to that is that I put a pin through the center of the hinge, that way I can be sure that it is centered between the flight surface and the control surface. Otherwise, the CA hinge will slide in further on the side with the least resistance. Once I get all hinges installed and ready to glue, I remove the pins before gluing.
cynjon is offline Find More Posts by cynjon
Old Apr 15, 2012, 12:26 AM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
It helps to trim a little off each corner of each hinge...easier to install in the slots.
Check your local hobby shop for a Great Planes Precision Hinge Marking Tool # GPMGPMR 4005
or equivalent tool. $4 and worth every penny.
This assures a centered slot.
lindart is offline Find More Posts by lindart
Old Apr 15, 2012, 12:23 PM
JohnSH is offline
Find More Posts by JohnSH
Joined Aug 2010
Originally Posted by FlyValue View Post
Hi folks,
Here are the instructions that Great Planes provides in their kit assembly manuals.
JohnSH is offline Find More Posts by JohnSH
Old Apr 19, 2012, 09:01 PM
DGrant is offline
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
IF.. I do say "if".. the surface is thick enough, so you can "center-cut" it.. you can use any straight-edge rule.. mark it.. slit it... otherwise the jig mentioned works very well too..
When you're positioning them.. the way I do it is to hold/tape/secure the surface itself to the component attaching it too.. then I simply lightly pencil my positions.. after that is when I start cutting slots to centers..
There is a tool made just for that too.. Its about $15..maybe $20.. maybe less if you can get one used.. I got one years ago.. when theres a bunch of slots(I'm talking 25-35 hinges or so..) multiply that by 2(one slot each side).. that's 50-70+ slots... the GreatPlane slotter just bores through them.. it takes a tad of practice.. as its a thin blade.. and can skew if its hurried.. but still takes about 4hrs or more work and gets it done in 15-20 minutes.. on the other hand if you like to tinker.. and enjoy the time spent doing it by hand.. that's cool too.. can't knock a craftsman.. so.. one other thing..
Be sure to use "thin" CA glue... it doesn't matter whether its odorless or not.. just make sure its thin.. I put about 5-6 drops on one side while flexing the surface.. then same on the other.. just working the surface for about 5 minutes. it doesn't take alot of glue.. but just be careful to not get too much too quick.. and watch for runs.... less is probably best.. and I do a second app of a few drops after about 15minutes..
There's some good instructs in this thread.. so use whatever works for you.. I'm just sharing what/how I do hinges/slots.. Good luck.
DGrant is offline Find More Posts by DGrant
Old Apr 20, 2012, 02:40 PM
macro is offline
Find More Posts by macro
Portland, Oregon
Joined Oct 2001
I've had very good results with the setup shown in the attached photos. You obviously need a drill press, but I expect that many of the builders have one. I use the thinnest little circular saw blade I have, about .015 thick, on a mandrel. It's set above the table the right distance to center the slot, or offset it if that's what you want. Just move the control surface toward the saw until it's the right depth. For parkflyers, I just cut the CA hinge into a circular shape. If it's a bigger model, I use either an Xacto or my Great Planes hinge slotter to deepen the slot. Once the cut is started with the saw, it's easy to assure that it continues through the center of the workpiece.
I've used this technique successfully on material as thin as 1/16, and for other types of hinges that neeed a slot. As long as you keep the same side of the surfaces down, a few thousandths error will not affect the alignment of the hinges, They should always come out perfectly aligned. If the material is tapered, you can either make the slot parallel to one of the sides, or shim the piece to cut on the centerline.
One of the photos also shows the little guard I use with the saw, the other has the guard removed so you can see the setup better.
macro is offline Find More Posts by macro
Old Apr 20, 2012, 02:54 PM
StayQuiet is offline
Find More Posts by StayQuiet
StayQuiet's Avatar
United States, SC, Boiling Springs
Joined Jul 2011
[QUOTE=DGrant;21381789
There is a tool made just for that too.. Its about $15..maybe $20.. maybe less if you can get one used.. I got one years ago.. when theres a bunch of slots(I'm talking 25-35 hinges or so..) multiply that by 2(one slot each side).. that's 50-70+ slots... the GreatPlane slotter just bores through them.. it takes a tad of practice.. as its a thin blade.. and can skew if its hurried.. but still takes about 4hrs or more work and gets it done in 15-20 minutes.. [/QUOTE]
The Great Planes Slot Machine is worth every penny (about 2100 of them). Add in the available cutting guide for 4 bucks, and it makes it hard for even a klutz like me to mess the job up!
StayQuiet is offline Find More Posts by StayQuiet
Old Apr 20, 2012, 06:22 PM
JohnSH is offline
Joined Aug 2010
It is a great tool and there are blades for thicker hinges available. Also a cutting guide.
http://www3.towerhobbies.com/cgi-bin...Fb%3E+machines
Old Jul 31, 2015, 12:42 PM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
For simple hinge slots just make the 1st cut with a fresh blade, then flip the blade around in the handle so the blade bottom is now sticking out. Now wipe that back and forth inside the cut to make a square "slot" for your CA hinge to fit.
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Aug 02, 2015, 08:30 AM
pathfinder is online now
Find More Posts by pathfinder
Mach 1
pathfinder's Avatar
walterboro s.c.u.s.a
Joined Jun 2004
Get the Great Planes slot machine.I guarantee you'll like it.
pathfinder is online now Find More Posts by pathfinder
Old Aug 02, 2015, 09:59 AM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
Keeping the slot perfectly centered sometimes puzzles beginners... and some times you need the slots off center anyway.
The easiest way for either situation is with a woodworkers tool called a marking gauge. I made my own in a couple of different styles. Here is one. They can, of course, be purchased. If you buy one be SURE to get one with a cutting blade, not just a scoring pin.
It has two adjustable bars that slide in the body of the gauge so it can be set for two distances if necessary without having to stop and reset the thing. Not really necessary, but since I built it, I figured what the hell.
A setscrew on top tightens or loosens the bars for adjustments.
The blade is ground from an old hacksaw blade and is razor sharp.
Be sure to use the same side of the control surface as the guide so if you are off a tiny amount, it does not matter.
Tom
PS: It is also a great balsa stripper.
T_om is offline Find More Posts by T_om
Old Aug 02, 2015, 03:38 PM
ZAGNUT is online now
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
i clamp the blade down on my bench with shims under it to get the right height. then hold the part to be slotted firmly down on the bench and slide it into the blade. sorta the same idea as the higley hinge slotter....i usually use some funny looking double edged blades i found at a crafts store.
all those doodads that remove material are for thicker hinges, not CA hinges. and the best CA hinges by far are the ones from radio south.
ZAGNUT is online now Find More Posts by ZAGNUT
Old Nov 11, 2015, 03:11 PM
jpurcha is online now
Find More Posts by jpurcha
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
I trying this on a new build soon.
www.aerobroach.com
Jim
jpurcha is online now Find More Posts by jpurcha
Old Nov 11, 2015, 08:18 PM
ckimmey is online now
Find More Posts by ckimmey
Master of the 1 point landing
ckimmey's Avatar
United States, IN, New Palestine
Joined Aug 2011
I know these are CA hinges, but I have had some come loose. Probably builder error...ok...definitely builder error. But now I have discovered Super Phatic glue. I put a drop on the end of the hinge and spread it out on about 1/3 of the hinge. Then when I insert it to the 1/2 way point, the glue squeezes up to the 1/2 mark. I let it dry in either the control surface or the stab/wing. Then all I have to do is put another drop on the other end of each hinge and slide the joint together.
It ensures that there is glue all of the way into the slot and I get a rock solid hinge that way. So far, so good for me. SuperPhatic is a bit pricey, but totally worth it for applications like these.
ckimmey is online now Find More Posts by ckimmey
Question can i use CA hinges instead of robart hinges on a 65" edge 540? out of stock 3D Flying 3 Dec 07, 2014 06:37 PM
Question ca hinge source lectroglide The Builders Workshop 9 Apr 12, 2012 07:46 AM
Wanted Ca hinges lectroglide Aircraft - General - Miscellaneous (FS/W) 0 Apr 11, 2012 03:20 PM
Discussion How small can i make CA hinges? wopachop Foamies (Scratchbuilt) 5 Nov 24, 2011 08:36 AM
Discussion New Tuff-E CA Hing Too Stiff Keven_C Foamies (Kits) 0 Oct 09, 2006 09:35 AM
